Gas Type - Leaded / Unleaded |
Post Reply | Page 12> |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
Posted: February-11-2008 at 11:45pm |
Can anyone tell me what year CC started using motors that were designed to run on lead free gas.?
What do you guys with older motors use.? Lead replacement gas aditives.? Cheers, |
eric lavine
I would think in Australia that you guy's still have lead in the gas, correct me if im wrong, I know in other countries they still have lead in the gas....how about your gas Kristoff??? |
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
I still use a lead substitute in my '87. Maybe I'm over-cautious, but IMO for $2 a tank, it's cheap prevention.
GN6027
1987 Ski Nautique 2001 |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3391 |
No leaded fuel here anymore...
We also have to use additives... But then again my boat runs on propane . much cheaper! |
eric lavine
there is no lube in propane at all for the top end, nice clean oil though
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
My 85 454 gets a shot o' lead every fill up. I've been told that it also improves the octane.
Steve |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
Kristof
Most ski boats here run on propane, because gas is expensive here (explained that somewhere on another thread)
None of them ever had a problem that I know of. Mine does so for more than ten years and never had a problem and runs like a swiss clock. You do loose a few HP tho. |
Brktracer
Senior Member Joined: December-20-2007 Location: South Carolina Status: Offline Points: 387 |
Lead substitute additives = waste of money.
Kristof: You can get most or all of your HP back by increasing the compression ratio. Propane is the equivalent of about 110 octane gasoline, therefore compression could probably be increased to 11-12:1 without a problem. Matt |
Kristof
Thanks Matt, another thing we can work on this weekend!
All you guys keep helping me like that, I'm gonna become the boat specialist in the neighbourhood here on the Maas |
Most of you are too young to remember the before leaded there was marine white gas. Straight run gas. nothing whatsoever in it. The engines ran fine.
Save the money you are spending for one of the chemical company scams for the good hardened parts or heads. The time will come when a top end job is needed and a so called lead substitute isn't going to prevent it. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5770 |
Yep, For your Ford guys if your heads have the small spark plugs you've got hardened seats. Not sure what year that started but if you're putting that crap in a mid 80's boat it isn't neccesary. |
Chopper
Eric,
Unleaded gas was intruduced in Australia in about 1987. leaded Gas was phased out probably 10 years ago, and replaced with "lead replacement" gas, then that too was phased out a few years ago. |
eric lavine
Kristoff, since you are pumping propane in its gas form, see if you could get a nitrous/propane mix, that would solve your HP problem jk just a thought
racerdoc
Newbie Joined: October-07-2007 Location: United States Status: Offline Points: 11 |
I recall my dad running Amoco White gas in our 1960 CC Starflite with Ford V8. He gained a couple of mph over the previous High Test.
Waterman
Brktracer
Trying to compress nitrous and propane into a bottle...you just invented a diesel engine...can you say kaboom? Would be cool if it would work though! |
Chopper
Feel free to correct me if I am wrong, but doesn't propane only have high octane rating when it's a liquid.? during the liquid / gas conversion process doesn't it drop right down.?
Kristof
Here are my propane tanks... I will repaint them tho, otherwise Eric is gonna tell me I should watch "Brokeback Mountain" again
Oh , and I'm not too fond of kaboom's... The loss of HP is aproximatly 5 HP... not worth a kaboom |
Kristof
Nowadays, there is a new system, called "LPI" or Liquid Propane Injection.
The propane is injected into the engine under high pressure. The engine consumes less, no loss of HP anymore and better lubrication. |
eric lavine
Kristoff, your not thinking of painting those pink are you?
Kristof
Hmmmm, let's see Eric.... Since they are pink I don't think so! Not by a long shot!
Think they will be red, to macth the rest of the boat... Little question on the side: why you keep spelling my name with two f's Ericc? LOL |
eric lavine
I was thinking again that when you use propane it gets cold, so why not run it thru a heatexchanger and fan, and you'll have a air conditioned boat
Oh no!! We had the C and the K issue now it's going to be a double F and a double C problem!! |
eric lavine
In america, if you use 1 more letter on the end of someones name it means, admiration, good friend, it means you've been accepted into a small circle of friends
Kristof
Well then, by all means keep calling me Kristoff Ericc (thanks for the friendship!)
for the air condition thing, I could reverse the blower hehe |
79nautique
that was a bunch of BS from eric you just ate.
SNobsessed
Did you mean Ericc?
eric lavine
i went back and looked at the pictures again, they are pink, i thought they were white
Kristof
Sure sure, have a laugh at the little Belgian... But, I do love a good portion of BS from time to time.
Eric, I sure hope you won't do that when I have a transmission question, wouldn't want my boat to go backwards when I push the leaver forward Thanks for the heads up 79Nautique and SN, I'll be more carefull with Eric(c) in the future LOL |
eric lavine
pink bumpers for the side of your boat will match those propane tanks,
Kristoffff you seem like a pretty nice guy |
Kristof
You seem like a nice guy too Ericccc
Maybe I'll think about the pink bumpers... and some fluffy pinks cussions on the back seat... LOL!! |
