Nautique WONT START!!!! |
nautiman
Newbie Joined: June-22-2008 Location: United States Status: Offline Points: 9 |
Posted: June-22-2008 at 2:36am |
Ive got a 79 ski nautique, ive replaced the starter, ring gear, battery, and plugs. The boat ran perfect until i somehow grinded some teeth of the flywheel (why i replaced the teeth). The engine turns over and get a good spark it just wont fire up. Ive used starting fluid and everything, just wont start. It coughs every now and then just wont start. boats been sitting for 2 months, im dying to get on the lake.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5768 |
If you haven't touched anything other than plugs tuneup wise and it ran before you changed them is it possible you messed up the plug wires?
You didn't change points and move the distributor did you? |
nautiman
When i replaced the plugs i did it one cylinder at a time. Same points and distributor. Im stumped. ha
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6101 |
this is a long shot, but based on your description, are you sure you have a right hand rotation starter?
eric lavine
75 i think you nailed it, they will cough out the carb with the wrong rotation starter
nautiman
Well when i replaced the starter i went to the auto parts store and got one there and yes when it does cough it comes from the carb. how can i be sure of that?? thanks
eric lavine
the cool thing would be is if it started and you put it in forward you would go bacerds
eric lavine
I would say you found or 75 found your problem, kick the sarter and see which way the engine turns
eric lavine
it should turn to the right from the front or CW
nautiman
Yes it does turn clockwise looking at the pulleys, Ive also have a ski centurion and the motor turns the same way...i bummed thought I solved the mystery...lol
I think we need to make a permanent posting. DO NOT go to Autozone (or the equivalent) for marine parts!!!!! |
eric lavine
I apoligize!!!!, if you have a right hand engine it should turn to the left from the front!!!!!!!!!!! CCW looking at the flywheel it will go C.W
75 Tique
Also Rob, what they have failed to mention is that you want to avoid auto store starters for two reasons, one, they go the wrong way and two they are not sufficiently spark resistant for boats (just like alternators). Go to SECC, they will fix you right up.
(I was going to question that Eric, but you caught it) |
nautiman
i believe you guys and it does make since, i just dont understand how my ski centurion with an Indmar 351 turns the same way as the nautique does, and it runs perfect...
75 Tique
Depends on the year. Newer boats turn to the left, older boats, like your Nautique turn to the right.
nautiman
the only reason i question is because a new marine starter is not cheap....
75 Tique
Very good point, they are a fortune. If you're not in a hurry (and since you have the other boat) maybe you can have your old one rebuilt. I had mine redone about 4 years ago, I think for about $80.
bkhallpass
Nautiman,
Centurion's were one of the only boats besides correct craft with reverse rotation. I'm not even sure if Centurion still uses reverse rotation, but at least through the early 90s, it did. Yes, a marine starter and alternator is more expensive, but if you've ever seen a boat catch fire, it's worth the insurance. BKH |
Livin' the Dream
nautiman
Good point, thank you guys for the great advice. Without you guy, my head would be up my A$$....
nautiman
<----Very stupid question, and i looked in the help forum, but how do i post pics of my boat??
bkhallpass
If you are uploading from your computer, the photo needs to be small. Most people have there pics on photobucket, flicker, or another photo hosting site, and do a link to that site. There is a sticky post at the top of the forums with instructions how to post a pic from photobucket.
BKH |
Livin' the Dream
75 Tique
If you want to post a picture of your boat in a post/thread, do what BKH said, but based on your arrow, I am guessing you want an avatar under your name. To do that, you first have to post your boat in the diaries. Go to diaries and follow instructions under "post your story". It might take Keith or Brad a day or two to add it. Then go to your profile and enter your posting number (in your diary URL, the four digit number) in the designated spot in your profile.
Good luck with the starter issue and welcome to the site. |
nautiman
Just wanted to thank you 75 tique....absolutely nailed it. I went to Southeast Correct Craft and got the right starter and went out on the boat today, no problems!!!!!!!!
behindpropeller
what did you do with your old starter??? I'mlooking for one to rebuild.
Brktracer
Senior Member Joined: December-20-2007 Location: South Carolina Status: Offline Points: 387 |
Starter mistake isn't so bad. I built the engine to run CW and figured out it should be CCW when I had everything in and started to adjust the valves! It took me a minute to figure out why the valves weren't opening at the right time!
I had to pull it back out, change cam and seals and reinstall! Not the first time or the last I've had to pull a "new" engine! Matt |
Brktracer
Oh, almost forgot...I had to buy two marine starters.
The gear was burned off the first one when the relay hung up. I was starting the engine for the first time and starter stayed engaged. 2,000 RPM with the starter engaged didn't let it last long. By the time I figured out what that noise was it was too late! It literally burned the teeth off the starter gear! I got really lucky, I still don't understand why, it didn't damage the teeth on the ring gear at all! So my first starter lasted about 5 minutes. The second one is still going strong! Matt |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13511 |
Supras switched somewhere in the late 80s, alongside the Nautiques. |
bkhallpass
Your right. The centurions probably changed rotation of motor in the late 80s and spun the prop reverse with the transmission as did the others. Not sure. I do know when I drive them, they back up "bacerds." BKH
Livin' the Dream
