  New Posts New Posts RSS Feed - strut bearing
strut bearing
84bare12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84bare12 Quote  Post ReplyReply Direct Link To This Post Topic: strut bearing
    Posted: March-05-2008 at 4:34pm
is there an easy way to remove the strut bearing?? 84 barefoot i believe it's one large seal instead of two smaller seals!!
Mark 84bare12"
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 5:23pm
If you mean the cutlass bearing(brass tube w/rubber inset), it has 2 set screws. You may be able to tap it out with something of the same size, but it's not steel so be careful. The set screws can be stripped easily as well. Maybe some penetrating oil overnight? Heating it may also help.
1988 BFN-sold
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 5:29pm
Are you asking about the strut bearing? I dont know of a strut seal.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 6:07pm
it's much easier cutting it in two pieces than trying to drive it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 7:09pm
Mark, No such thing as a strut seal! If you are thinking of the cutlass bearing, Chris (79) is correct that the easy way to remove it from the strut is to cut it out. Take the hacksaw blade out of it's frame and put it through the inside of the bearing. Put the blade back on the frame and start sawing! Try not to cut into the strut. When you get the brass shell of the bearing almost cut through, you can use a chisel and hammer to curl the bearing inwards. It will fall out.
Did someone tell you that this "seal" is two pieces?
Did you get the shaft out?
I think you need to start posting some pictures so we can guide you with your project.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 7:14pm
Pete, sometimes nowadays you install 2 2" strut bearings, one at each end, so he may think there is two, which may be
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 7:34pm
Eric, I've seen those but my 88 is a 1 piece...2 set screws.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 9:11pm
Eric, Thanks for bringing me up to speed on the current cutlass bearings. It's been a while since I've had to replace one. I just went to Skidim and took a look. They only have the 2 piece type. I also noticed a new plastic. Has anyone used them?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2008 at 9:44pm
You can still get 4 inch long bushings from Deep Blue Yacht supply:
Blue Water
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2008 at 9:01am
It's been about 10 years since I bought the last cutlass bearing but I've always gone to the power transmission (gears, sprockets, sheaves, bearings, etc,)distributor that I use. They are a standard component and without the word "marine" attached to them qiute inexpensive. I remember paying about $9.00 for the last 4" long and 1" ID
