82 Floor Repair (I need help) |
Post Reply | Page <1234> |
SkiBum
Gold Member Joined: November-17-2006 Location: United States Status: Offline Points: 587 |
Seems like every few weeks we have the same discussions again. This is one of them. Others include: use of foam, composite stringers, wood floors, and more.
Anyhow, the epoxy resin is more expensive. I concur. Whether or not the boat was built with epoxy or not doesn't matter. The epoxy is better than polyster for structural repairs. Vinyl Ester resin can be used over epoxy resin to allow follow on with polyester gelcote or resins. Ultimately it is your decision. Will your boat saturate with water and/or fall apart because you use polyester resin instead of epoxy? I don't think so. I used epoxy resin and a variety of glass materials and fillers in my construction. That is a technique. Take it for what it is worth. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21131 |
Are you sure? What year did CC start using epoxy? I know my '90 used AME 400 epoxy resin, and shortly thereafter (1993?) CC went to AME 5000. Regardless, the epoxy is the superior resin, correct? |
Jon, Pictures?
jon4pres
Senior Member Joined: September-19-2005 Location: United States Status: Offline Points: 275 |
I took the motor out last night. I can see where the PO tried to do some repairs. It looks like from the front motor mounts forward he tried to make everything worse.
scott8370
Gold Member Joined: November-30-2005 Location: United States Status: Offline Points: 872 |
I use a plastic spreader and a roller. I don't see the need for epoxy resin. (cost) It's great stuff, and it certainly won't hurt to use it. Your boat wasn't made using epoxy. And once you use it, you can't go back to polyester resin in that area. I think Eric would agree, because we both use the same materials and techniques in boat repairs. You might want to remove all the bad wood and foam. Clean it up, then get an estimate.Unless you want to do the work yourself.A pro will have all the tools,and material to do the job. It may or may not be cheaper for you to do it yourself.
Scott
I used resin I got from the rot doctor website, liked it a little better than the west system stuff.
you can soak the paint brushes in thinner right after each use, I used a total of 3 brushes, not mineral spirits...
79, Some epoxy manufacturers do list the mix ratio by weight and that can be used. However it typically is used for large batches so you don't have to pump the pumps for long periods of time. The pumps are cheap and not as messy as pouring from a can but most important on small batches very accurate. One drop in a small batch will make a difference.
boat dr
79, Just pulled out direction sheet,West Systems,they have no listings of mixture by weight. The ratio is stated for use with their pumps,But you may have used a different brand..............boat dr
SkiBum
Sorry, forgot to list the pumps. Just cost a few dollars worth every penny and then some. Too easy. Pump three times move the container pump once and repeat. Also you need a good roller. I tried cleaning mine after each use but it only lasted about three stringers. Buy a few of those as well.
I thought I recall in the instructions when I did some years ago they also listed the weights as well as volume for mix ratio's.
It is by volume and not weight so don't use a scale!! The pumps are less than $15 and well worth it. You can mix real small 1 stroke of each pump batches plus they are allot neater since you're not pouring out of can. The pump kits fit all containers up to the 5 gal. size by using extention tubes that fit on the bottom of the pumps.
Depending on the manufacturer and the type of hardener you use, the mix ratio can vari. Read the instructions and get the proper pumps. The small batches really come in handy when you are adding fillers. The mixed volume really increases especially on the fairing fillers to the point that you sometimes can't use it fast enough before it sets up. |
boat dr
79, You ain't going to use my Ohaus for epoxy, I have to weigh letters and such. Don't know for sure but is the ratio 2:1 by volume and not weight? Maybe I am wrong but component A and B have different weights, if so, you would use the volume method of mixing as per directions??????
87BFN owner
when you only have one boat and a limited amount of time, I am pretty sure findind someone like Eric to do a fantastic job on your stringers and floor is the way to go.
Now a project boat, I definitely would like to try this wonderful task myself. I admire you guys that do this task yourself to your only boat. |
If you have a good digital scale then you can use it instead of the pumps if you want.
damn that was slow typing on my part
For applying the epoxy, they arent worth cleaning off the epoxy after so they end up hard as a rock... a one shot deal.. you will easily use 25.
Jon, You can also take a look at:
www.masepoxy.com They actually have a on-line store |
The paint brushes are used to apply the epoxy resin to the mat and cloth. Once it dries, theres no saving the brush, so buy a bunch. In addition to SkiBum's list, I used a grooved roller to get the air bubbles out of each layer of glass. Buy a bunch of those too. I also liked the hand pumps- makes it easy to get the right ratio of epoxy to hardener and makes less of a mess than pouring. BKH is right, go with US Composites. I guess its not really a "material" but dont forget to pick up a box of latex gloves from Home Depot. You want to keep the resin off your skin if you can. |
bkhallpass
I remember reading that Bill ordered from US Composites.
BKH |
Livin' the Dream
jon4pres
Bill, where did you order all of the fiberglassing stuff from?
I would like to go ahead and get supplies so that I have them when I need them. 25 paintbrushes?? |
SkiBum
To replace the stringers this is a pretty good list of materials:
quan item 5 gal Epoxy resin 635 thin 3:1 ratio 1 roll 50 yds 2" E-glass tape 1 roll 50 yds 4" E-glass tape 1 roll 50 yds 8" E-glass tape 5yds Epoxy mat 5qts West 404 filler (fine glass) 5qts Aerosil-Cabosil thickening agent 5qts Fairing compound 25 ea 2" wood paintbrushes 25 ea stir sticks 5 ea 1qt mixing containers 2ea 2"x10"x16' 2ea 1"x6"x12' Each stringer consumes about one gallon of epoxy resin from start to finish. Use the epoxy mat to laminate both sides of the stringers. Seat the stringers with 2 layers of epoxy mat and clamp until cured. Fill gaps with 404 filler and epoxy. Then use 2", 4", 8" strips along the joint. Use 404 and epoxy to make a bead 1" above and below the joint 1/4" to 1/2" thick. That is all it takes to laminate and install the stringers. |
Great Jon, I don't think you will not have a problem with this project. I too was Industrial Arts student of the year in high school. Of coarse that was in 1969!!!
jon4pres
I got the woodworker of the year award when I was in High school. That doesnt really mean anything but I am very conifident that I can do what I need to. My grandpa has a great shop full of tools that I can steal.
Jon, I think the best way is to take you through some steps so you don't get to far ahead of yourself. Get the floor cut out and start cutting out the old stringers. Post some pictures and we'll start talking wood. I know that Bill (skibum) is going to be your most valuable asset in this project.
You have said that you have never touched wet fiberglass before but don't worry since it isn't real hard. How are you woodworking skills? |
jon4pres
Can someone give me a shopping list. Like I said I have never touched wet fiberglass or epoxy in my life. I looked at the Pete's website and it only confuses me.
If you guys have a list of what kind and how much of everything I need it would definetly help. When I am done I will have to take all of the information that I learn and write a book "Rebuilding Stringers for DUMMIES" |
Jon, Take a look at this:
http://www.masepoxies.com/index.htm Yes ,the two rings are lifting points. You may ned to do some playing around if you use a short piece of chain between them to get the engine w/ tranny balanced. There are screw adjustable balancers that the pros use but they are pulling engines almost every day. |
jon4pres
I did not get the engine pulled but I did start it last night just so that I would know that it made it through the winter. The oil looked black and it looks like it survived. Then I unhooked everything. The only thing left to do is take it loose at the motor mounts.
I spent a good hour driving the skid loader across town at 15 or 20 mph. My motor has two rings that come out of the motor. One on the front right and the other on the rear left of the block. I am assuming that these are made to pull the motor. Can anyone tell me any different. Where are you guys getting supplies? If you have a good online place that would be ideal because I know I wont be able to find anything local. |
Jon4, Make sure you use the "E" glass cloth with the epoxy resin just as Skibum did. It's made for it.
Did you get the engine pulled? |
SkiBum
Really dont see the need to use 3/4" treated plywood for the floor. Glass would be fine. I almost used 1/8" 3ply. 1/2" normal plwood would be enough. Just apply epoxy resin, 10oz or more glass cloth, and resin to the underside before you install. Then apply two layers of epoxy resin and glass on top. When the floor attaches to the side of the hull and to the stringers it actually provides some increase in the structural integrity of the boat. There have been several clever modifications to allow water to flow out of the floor area. I am of the opinion that a properly constructed floor and stringers will seal water out. The only way it will get in is through years of neglect or acute damage.
As for cost, figre on one gallon of resin per stringer. 10yds of glass for all four stringers. Then I used five gallons on the floor as well as 30 yds of glass (10 ea Eglass cloth, epoxy mat, and biaxial mat) Good luck with your project. |
