Lost Prop AND part of shaft |
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
Posted: May-17-2015 at 12:58am |
So I was safety boat today, right in the middle of the show, with the ballerinas ready to come off the far dock, and the glider having a malfunction. Just as I touch reverse to hold position, I hear a "thunk" and I have no propulsion. I have to call on the radio that I am dead in the water, and I have to be drug out of the way. Muy embarriasso.
Anyway, I get it out of the water, and see this: ]shaft 1[/URL] Sigh. It was running pretty good. So, anybody got a good deal on a new shaft for a 75 SN? Was the Acme 542 too much for the shaft??? I will defiantly be getting a new 542! Tom |
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
DrCC
Probably from someone torching a prop to remove it.
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2852 |
That really sux. I feel your pain. From the "glass is half-full" perspective, this gives you a good excuse to put in new strut bearings...
FWIW, Sebastian (aka "kapla") in Buenos Aires had a similar issue: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=35715&KW=&title=prop-gone-to-the-bottom-of-the-river-and-back |
Todd,
I have thrown a blade off a prop but never lost one but both aren't a good feeling. Sorry to hear about the loss. From the picture, I can see a couple things. From the shaft not centered in the cutlass, it looks like there is an alignment problem. The keyway is chewed so the prop has been running on the shaft loose for some time. The prop to shaft contact area also looks like the prop wasn't lapped to the shaft. No, the 542 is not too much for the boat. I'd look more towards install and PM. I suggest an ARE shaft. |
seacamper
Dang it! The last thing I want to hear is that its my fault!.............However, you are right on all counts. I do not think I lapped the prop correctly and it went on so well (and the old one came off so easy) I just tightened her down and went on to other problems. I do not think I ever checked it after the install. I used a nylock instead of a castle nut. I am sure you are right about it being loose based on the pictures. So it looks like a new prop, A.R.E shaft, and cutlass bearing. I am fine with the old style packing, should I consider the gland type? Tom |
seacamper
Oh, yeah, Backfoot was in the crowd laughing at me drifting to shore. To make it funnier, the boat that came out to get me threw me a ski rope that was all tangled up, and the guy did not hold the end, so he threw the rope at us, and we had to hold one end and throw it back. We looked classy!
Orlando76
I'm afraid of the nylock. Had a brand new one back off to just one thread showing after an hour run in the '93. There's a used prop shaft that came up on the forum yesterday I believe.
seacamper
Well, the shaft came out pretty easily, and it is stamped "50". I have to believe that with the end still on it, that would be the length. I have some friends that have offered me a shaft out of a 74' SN, and I left a message for the guy on the parts for sale thread with the 80'. How much better are the A.R.E. shafts? I may dive for the 542 in 20' of water today or tomorrow.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5767 |
Not sure I would spend much money on a 35 year old shaft. Also since you say the old shaft came out pretty easy I'm guessing the fit in the coupler is shot. I would pony up for the ARE and do it. Once and done. And it sure is worth trying to find that 542 if you have access I some tanks.
I totally agree with Alan. If the shaft came out of the coupling easy, it too is shot. It's another indication of bad alignment. I'll bet if you look at the coupling it's got smut from fretting. Yes, go for the ARE.
I will comment again that the prop nut doesn't hold the prop on. It's the taper fit. The nut is there to seat the prop on the taper and then there in case the prop wasn't properly lapped/fitted. I have seen several boats come out of the water without a prop nut, the prop still on and how long the nut was missing was unknown. |
seacamper
That is what I am thinking as well. After a bunch of research, it looks like the A.R.E shaft is the way to go. I am going to get the new prop as well because someone already took a chunk out of my 542 by hitting a ramp cable. I will dive for the old one, but it will go to the shop and be a spare if I find it. Tom |
IAughtNaut
IAughtNaut
sorry, thunk. way different. that could have been a manatee in which case at least you get a snack
kapla
Wow Tom deja vu!
Same exact situation....i was able to dive prop back even in muddy waters...only had to wait a low tide 3" deep and voila... |
seacamper
I almost took a peek today, but we started practice early. The new prop is already in the garage with the bearing, packing and nyloc. Just waiting for the shaft to show up Monday. I took this time out to chase down a fuel dip tube problem and got educated on vent lines.
phatsat67
I have been using the same nylock for darn near 6 years or so with multiple prop changes and it's never backed off.
With everything new it will be all buttery smooth like it's supposed to be. |
seacamper
When I knew the prop was gone, but did not know the shaft broke, I was cursing my choice of using the nylock. When I pulled my boat, and saw the shaft, I realized I was cursing the wrong thing! Tom |
seacamper
Hey Guys,
I just wanted to let you all know some divers found the prop!!! Now I have a back up 542.. |
IAughtNaut
