Trailer Tires |
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
Posted: March-09-2007 at 12:18pm |
I am going to tow my boat further than the 2 miles to the ramp that I normally tow. I need new tires since they look like they originals that came on the '78 CC trailer.
I also need to do the bearings and or hubs since I don't want a bearing failure while towing to ME. So, what should I look for in a tire? I'm going to use the rims that are on there now. I see that there are bias ply and radial? What load rating should I look for? Should I just get new hubs since I'm not sure how old these are? What kind of hub should I look for? Thanks. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21135 |
Mark, Ive read very good things about Goodyear Marathon tires- you can get them at tirerack. Just make sure you get the proper load rating.
Goodyear marathon trailer tires is the only way to go for tires. Hubs you really don't need to replace them just the bearings, races and seals. But sometimes it is cheaper and quicker if you buy new hubs, you will just need to match up the spindel sizes for the bearings and the lug pattern for the rims. If it is an orginal trailer I'm sure someone will know exactly what you need if you can tell them what trailer model it is.
I like adding bearing buddies if you can, thats me though, I like them because as your walking by if the spring is all the way in you know they need grease and with the little spring pressure that is on the grease it has a tendency to keep the water out
jon4pres
Senior Member Joined: September-19-2005 Location: United States Status: Offline Points: 275 |
Definitely go with bearing buddies. I burnt up a bearing on each side before I discovered the bearing buddies.
When you go to buy the new bearings, races, and seals go ahead and get a complete hub with everything you need as well and when you are going to travel throw it in the back of the truck just in case. I do this now and it could have saved a day and a half of my vacation last year if I didn't have to tow the boat and then spend half a day looking for the parts I needed. |
Speaking of trailering, I have another comment. In another thread, we discussed forgetting to put in the drain plug when launching. When it comes to trailering, don't forget to REMOVE it if you trailer without a cover. I know 2 people who forgot this, drove in a rain storm, filled the boat with water and blew tires or bearings from the extra weight!! I do not trailer with the boat covered because especially with my wood boats the cover flapping around can do some scratching of the deck. I've never seen even the best custom covers not flap to some extent.
The hub Idea is good pre-coutionary measure but if you inspect and re-pact the bearings regularly then you really don't need too. But just because there are bearing buddies on it doesn't mean the bearings are going to last longer and if water did get in which it will that will eat up the races faster than anything else.
All this is great info I personally use the bearing buddies but don't do the hub deal but it's still a good idea especially if you do have trouble on the road. |
Mark Mel
Thanks,
Which load rating should I look for? Mark |
Just get the same size or maybe one size larger on the tread width and you'll be ok.
You don't need to worry about the load rating as long as you get the tires suggested and the key word is TRAILER tire not passenger car tire, TRAILER, ,if you don't get trailer tires then the load rating needs looked at but basicly your load is around 3000 lbs and then that would be split by the number of trees on the trailer same thing with springs. |
Mark Mel
Thanks 79, in looking at the goodyear marathon tires it looks like the rating is dependant on the size.
So I'll just get the size I need and it should be load rated correctly. Doh, I just noticed I got switched to a senior member. |
the larger the tire the heavier the load it can handle, I believe mine are 195 or 205/75R14's but i don't have an orginal trailer either.
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6108 |
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
On my 88 trailer it has a grease zirk in the end of the axle with a pilot hole drilled to the inner bearing so as you pump grease in it flushes the old out from the inner race. When did CC start using this style and do they still? Seems like it works very well.
Also, I would like to upgrade the wheels on the cuddy trailer. Can you make out on price by buying online and paying the extra shipping, or is better to buy local? |
Buy local if you can, you never know when you might need that shop in an emergency...
boat dr
Mark, go with at least a LOAD RANGE C,or better yet LOAD RANGE D. The C's should do what you want,
contrary to what 79 says here: the larger the tire the heavier the load it can handle, I believe mine are 195 or 205/75R14's but i don't have an orginal trailer either. The load range is stamped on the tire C&D are trailer rated,buy trailer tires to go on a trailer............Marathon is top of the line.......boat dr |
There's nothing worse than seeing a family or a big group of guys ready to take in some bass fishin on the side of the freeway with the trailer tire off and the hub smokin
Another good thing to do regarding tires is if you can have then inflated with nitrogen then you won't have to worry about adding air to them unless you have a leak or someone has let the air out of them.
Nitrogen is not effected by temperture changes like compressed air is. You can still add air to a nitrogen filled tire if needed while on the road and your don't have access to nitrogen. A lot of the tire dealers have the nitrogen systems. |
rleinen79
Gold Member Joined: December-16-2004 Location: New Carlisle IN Status: Offline Points: 733 |
I've never heard of that. I guess it makes sense though. BTW, my old Shoreland'r had load range D, but I can't remember the size. I thinks the new tandem has Ds as well. Rob |
bkhallpass
I believe that if Nitrogen has been used, the installer will typically put green caps on the valve stems. BKH
Livin' the Dream
Remember that air is already 80% nitrogen. I dont doubt that tires are less suceptible to fluctuations in temperature with 100% pure N2- but I wouldnt pay much of a premium for it.
87BFN owner
Nitrogen, not worth the extra money. The minute you put compressed air in the tire that was nitronized you have changed the make up of air. Your still going to have to check the air and reinflate over time. Save the ten bucks or twenty.
The story behind nitrogen is a good song and dance, but I chalk it up there with syn. oil. Up the each individual, my two cents is don't bother. |
I thought it was blue they used. From what I have seen there isn't a charge and like I said you don't need to add air to them. |
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
Hey 79, watch the language. My son doesn't need to see that sort of stuff on this site. There's enough of that out there on the web already.
The Dr is offering the same info that you (a FREE opinion to help a fellow CC owner), so check your ego at the door. I'm not trying to (and I don't want to) get into the middle of whatever the two of you have going, but come on, give us a break!! |
GN6027
1987 Ski Nautique 2001 |
boat dr
2 Nautiques, the axle that you have is a very good system, tho pricey. They are called Accu-Lube or they were the first to offer this set up.
Allows you to service the hubs and not get dirty.This is the system I have on all my trailers..........boat dr |
guess I must be reading different post than you have there buddy how is making personel comment about one's physical appearance offer any kind of help? Not seeing something are you? selective reading maybe on your part? Don't see the connection there sure seems like a personel attack to me so I respond accordingly |
87BFN owner
79 Pretty sure Bell Tire charges like four bucks a tire to nitronize them. Discount Tire has not gone to this method.
Some of the places down by you may offer it for free, but in Michigan you pay for it as of right now. |
gn6027
Looking back at Dr's response on page 1 of this post, all he says is
"contrary to what 79 says here:" and you go off on him. Is this a personal comment about one's appearance??? Not in my book, it is a simple disagreement with an opinion. 79, I'm not trying to start anything with you, I wanted my opinion known as I bet others have the same. You offer a great deal of help to fellow CC owners, and that is what participating on the site is all about. I see someone took care of the offensive language from page 1. Thank you! If I offended you, please accept my appology as that was not my intent. |
GN6027
gn6027 you should expand your horizon and not limit yourself to one topic or one responce and should look at it as a whole in all topics and all postings.
that would be me, Keith would have only edit test not removed any. |
