GT40 engine loping |
Post Reply | Page 123 4> |
slmskrs
Posted: February-12-2012 at 5:10am |
I have always had a bit of a problem with engine loping. It will do it when very cold (winter) when launching, and also do it when the engine is hot and it has sat for a while (30 minutes or so with the engine compartment closed). The warmer it is, the worse it is (really bad in the summer).
When it is cold, it can last for 30 seconds or so but then smoothes out without doing much of anything. When it is hot, it can last that long or up to a minute and be bad enough that it stalls. Giving it throttle helps and speeds up it getting back to normal. I have no idean on the problem when it is cold, but I would suspect vapor lock when it is hot. But with MPFI and high pressure pump, I don't know how that would happen. I have not put a pressure gauge on it to see if the pressure is going up and down when it is loping (I am in the process of replacing my original GT40 heads with new ones, so it will be a week or two before I can put it back in the water and test). I did have my low pressure pump fail last year and I replaced it (made no difference for this problem), and have not seen any problem with the high pressure pump in the fuel canister. But since it is a continual and ongoing problem, I'm hoping someone has a suggestion. Thanks, |
Gordon '97 Ski Nautique, GT40
Luchog
it's normal on cold starts, have you cleaned the IAC valve?
Idle air control, as Luch suggests
slmskrs
Good idea. I did that recently on one of my cars. Since I already have the throttle body/plenum off and am ready to take the intake manifold off in preparation for replacing the original GT40 heads, it will be really easy (much easier than the car), I'll go ahead and do that now.
Thanks! |
slmskrs
Okay, so I pulled the IAC (ISCV) and cleaned the orifices in the throttle body, including the screen. The ISCV I pulled out of my car actually seats in the throttle body, so it is easy to clean where it seats after you've pulled it out. However, since the valve seat is part of the IAC, I can't clean that part.
My question before I start spaying the inside of the IAC on either side of the closed valve seat, I wanted to make sure it is fine to spray throttle body cleaner in there. I don't want to short it out, so would appreciate advising the best way to clean the valve (and seat). Thanks, Gordon |
Luchog
You could use a Q-tip soaped in body cleaner.
Bri892001
It also comes up with these motors that the fuel control relays can be troublesome.
I've also read that there is some kind of a clear tube within the Fuel Control Cell (if your boat has one) that can develop a crack and cause fuel pressure problems. Also, fuel pressure regulator has come up as something to check. But, usually problems that are related to temperature are often electrical in nature. |
slmskrs
I've replaced the tube in the fuel control cell (it developed a pin hole and lost pressure at higher speeds--the engine needed more fuel and too much fuel was going out the pin hole to supply it). That is always something to look at if you loose at power on the MPFI engines with the fuel control cell. I'm going to put my fuel pressure gauge back on it once I have the engine back together and watch it when it is loping when hot. That should help determine whether it is the regulator or something electrical.
Thanks! |
slmskrs
On the cleaning with a cotton swab, how can you clean around the valve seat since the valve is closed? Is it possible to carefully open it manually to clean the seat?
slmskrs
So, I got my new heads back on and it is running great. However, I still havd the warm loping issue. I took the ISCV out of the throttle body and cleaned it. I also cleaned the orifaces and the screen, hoping that it would go away. No such luck. The conditions for this are:
* Engine warm (usully pulling at least one set first) * Warmish air temps (used to need to be hot, but it is getting worse; today with air in the low 60s it was doing it) * Sitting for at least 20 minutes (engine cover closed, warm day, no air flow around engine). I have not yet put the fuel pressure gauge on it yet to see what if anything is going on with the pressure. I don't think it is the high pressure fuel pump since when cold and once it has run for a minute, it is fine If the pump had some sort of thermal issue, I guess it could happen--but if that was the case, I would expect it to not start at all until cooled. I replaced the low pressure fuel pump last summer, so I doubt it is that. Someone mentioned about a fuel relay. Does someone know where that would be on a GT40 MPEFI? Also, it was mentioned that the fuel pressure regulator could be another item to check (I believe it is on the starboard side fuel rail). How would that be checked? Would it be popping wide open to bleed down the fuel pressure, then close, and keep going open and closed? Thanks, |
boo
Newbie Joined: January-25-2012 Location: San Diego, CA Status: Offline Points: 20 |
Gordon,
My 2002 SN GT40 has the same problem. We used the Star Tester to extract fault codes from the engine's computer and the codes were all 11 which indicated the systems were fine. The next procedure the manual recommends is to check the fuel pressure regulator and the vacuum system. Today we connected the fuel pressure gauge at the wash ramp. (We ski in saltwater.) By the time we pull the boat out of the water and drive to the wash ramp the engine has cooled down enough to have the idle problem. It was unbelievalbe that the engine didn't lope. Tomorrow, we'll be connecting the gauge again. I have a thread going on Planet Nautique and have yet to have anyone some up with a solution. Sincerely, Tom T. |
Tom T.
2002 SN GT40 |
PN? Tom, You have got to be kidding me!!! Is that site sill around? If so, do you really expect a technical question being answered? Give me a break!! The only reason the site is still on the web is because it is corporate sponsored!!! |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Online Points: 4237 |
I have pretty much the same problem on my Sport, will be tackling the problem in a month or so, so this thread could be really helpful to me!
It didn't give me any trouble when skiing, but definitely at hot idle and a few times after near open throttle runs. |
slmskrs
My theory is that it is heating up, not cooling down. With then engine off, there is no flow of air, so the air surrounding the engine gets hot (even without the blower on, then engine pulls a lot of air through the bilge). Also, if I've been having the problem, if I open the engine compartment when I know I'll have to start it in 20-30 minutes when it would definitely lope with then cover closed, it won't lope but will run fine, Therefore, since it gets hotter, maybe there is some vaporizing of gas somewhere, such as in the fuel rails, at the regulator, etc. Murphy's Law it didn't lope for you today. I probably won't have my boat back in the water for 3-4 days, but will try to remember to take the pressure gauge with me to test it as well. Where do you ski (salt water)? |
slmskrs
NEVER happens for me during normal operation; only at hot start up when it has sat for a while. Once I give it some throttle to keep it running and once it settles down, there is no problem whatsoever. Actually, as I write the above, I'm starting to think about the ISCV again, simply because by opening the throttle, it runs better. If the ISCV is having an issue, opening the throttle would "cover up" that problem. Of course opening the throttle could also cover/mask the source of other problems as well. I wonder if there is a way to get data on the operation of the ISCV if fuel pressure is okay since I have no idea how to test it. |
lewy2001
Gordon I am chasing a similar problem on my GT40 Sport. It is a heat related problem also. The intermittent problem I have is when turning the engine off after a run it will not restart like normal with no throttle. After you crank it a few times you then have to hold the throttle wide open and clear the flooded condition. It can take up to 2-3hrs of running before the problem surfaces.
Sometimes the idle will fluctuate just before it happens which makes me suspect the ISC-BPA solenoid. I have found if the engine is not turned off between runs the problem never happens. This is a bit weird but the ISC-BPA could just be sticking when it gets hot due to a weak solenoid. So when the power is reapplied to the solenoid on restart it fails to operate. The more you turn the engine over without it starting the more fuel that will be dumped into the cylinders. This is why it exhibits a very flooded condition on restart and requires the full open throttle to restart. I also purchased a ford code reader but it had no fault codes stored for KOEO,Continuous or KOER tests. The EEC does not store a fault code for the ISC-BPA so it is still a suspect. I have previously cleaned and tested the ISC-BPA. Yesterday I removed the ISC-BPA assy from the engine again. You can see the solenoid actuate when you turn the key on and off. This is a good test for proving the correct operation of the ISC solenoid. The engine was warmed up when tested but not for the 2-3hrs it can take for the problem to exhibit. I also found that with the ISC-BPA removed the engine will start and run with a slightly higher idle. I plan to use this as a test to eliminate the ISC-BPA as the cause of the problem next time it occurs. By removing the ISC assembly you allow airflow behind the closed butterfly via the now open port. It could also be a ACT,ECT or MAP sensor but I should have had a stored fault code for those items. Will let you know the outcome via this thread. I hope this gives you some where to start looking yourself. |
the temp sender can also heat up and send false info to the computer, when its warmed up this may overfuel because the senseor is telling the engine it is still cold...i believe there are 2 sensors, one for the gauge and one for the computer
boo
Gordon,
Regarding the ISC-BPA, the manual states if the valve is bad, upon rapid deceleration there would be an idle problem. That makes sense becuase the throttle body butterfly valve closes completely and the ISC-BPA needs to open to allow air around the butterfly valve for idle purposes. I don't have that problem and it sounds like you don't either. Today, we're skiing again and will put the fuel pressure gauge on the fuel rail at the wash rack. If we can't duplicate the idle loping again today, then I will test the boat tomorrow evening after work when the engine is totally cold. We ski in San Diego. Stay tuned, I'm determined to troubleshoot this issue until it's resolved. I forgot to mention that the fuel pressure yesterday, when the engine would no lope, was 34 psi, which is within limits at proper idle. At idle it should be 31 plus or minus 3. Tom T. |
Tom T.
2002 SN GT40 |
slmskrs
Is the connector a ODBII? If so, where is it? I have an ODB reader (although for this problem, as you said, there are no error codes. But it would be nice to diagnose other issues. [/QUOTE] You can see the solenoid actuate when you turn the key on and off. This is a good test for proving the correct operation of the ISC solenoid........ I also found that with the ISC-BPA removed the engine will start and run with a slightly higher idle. I plan to use this as a test to eliminate the ISC-BPA as the cause of the problem next time it occurs. By removing the ISC assembly you allow airflow behind the closed butterfly via the now open port.[/QUOTE] Great info!! I will try removing the ISC-BPA (for my car it's called an ISCV) and then starting it when it has the problem. Only issue will be doing it fast enough that it doesn't cool too much with then engine cover open so that it runs normally. One word of caution when it is flooding the engine. I was helping jump a friend's carburetted SN. She has poor/corroded jumper cables (we were doing this at the launch ramp (no dock) from my car). Because the cables were poor, we could get it to barely turn over, but it wouldn't start. Of course she was pumping the throttle, etc. We finally pulled the battery out of her truck, disconnected the dead one, connected the new one. With her in the boat and me on the ramp holding the boat (luckily with the engine cover closed), she then started it. A very loud bang, the engine cover jumped up. We opened the engine cover, and all of the fuel vapor while trying to start had collected in the exhaust pipe/muffler, and blew out the side of the fiberglass muffler! We were lucky the cover was closed! So please be careful if it is acting flooded!!! Let us know how your tests go. Between all of us, we should be able to figure this out! |
slmskrs
You are correct; on the GT40 (at least my '96), there are two temperature sensors. There is one on the forward side of the starboard intake manifold just aft of the thermostat housing. This has two wires that go to it. One goes to the dash gauge and I don't know where the other one goes other than in a harness to the rear of the engine. There is another sender in the circulation pump housing that also goes to the rear. I have not pulled the one in the circulation pump to see if it is a temperature sender or some sort of pressure sender ). At least you can tell if the one on the intake manifold is working since it is connected to the gauge, but I have no idea what the other wire is for. I assume the one on the pump is for the EMC, but I will have to dig around for a wiring diagram to see where that other lead goes on the manifold sender. |
slmskrs
Tom, I don't have the deceleration problem either. I will have to check to see if my pressure gauge hose is long enough that I could put it on and have it laying on the floor with the engine compartment closed. That way I don't risk it cooling enough to have the problem not happen (like what happened to you yesterday). Hopefully you'll be able to get it to lope when flushing it today. If your test is successful and it shows constant pressure, then I'm going to do what Mark suggested and have a socket wrench all ready to very quickly remove (or at least break the seal) on the ISC-BPA since that's a great test as well. It may not be until next weekend until I have conditions that will cause it since it's cooling down this week. Mission Bay!! I hooked up with a couple of members probably 8-10 years ago while on a business trip, took my ski and got a ride on the course there (I'd have to dig around to get their names). If you are ever in the SF bay area, we're www.sccwsc.org and I'd be happy to give you a pull. Same to you Mark although you are a bit farther away than Tom.... :-( |
lewy2001
It is on the bracket that supports the computer it is a black plug marked with EEC Test. My tester is a OBD1, MCU for Ford Engines. Eric there are 3 water temp sensors on the GT40 engine. 1. The ECT sensor near the front on inlet manifold it is a two wire device as it has a signal return to the EEC. This is the main one for controlling fuel and ignition via computer. 2. Engine temperature gauge sender 3. Engine temp switch that puts the EEC computer into limp(SLOW) mode The ECT (engine coolant temperature) is used to control the fuel delivery the others are not. The ACT air charge temperature is near the ECT mounted into the side of the inlet manifold it is also used to control fuel delivery. I have not ruled them out but they should have returned a fault code. I recently changed my FCC filter and checked fuel pressure. I have also not ruled out the fuel pressure regulator as it may be over pressuring as it has a too rich problem. |
boo
Gordon,
Yesterday, I connected a fuel pressure gauge to the valve on the fuel rail. Started the engine on the wash rack. This was after a morning of skiing and the engine had cooled down during the twenty minute ride from the water to the wash ramp. The engine idled perfectly. This has never happened in the last six months. It always has the loping idle and then it would eventually stall. This morning, I launched the boat with the fuel pressure gauge connected to the fuel rail valve. Started the boat and it idled perfectly. This has never happened in the last six months, either. The fuel pressure at idle was 34.5 psi. The manual specification is 31 psi plus or minus 3 at idle. Unfortunately, I was not able to check the fuel pressure with the idle loping symptom present. After skiing for 3 hours today, I trailered the boat to the wash ramp. Started the boat to flush the engine and the loping idle was present. (The gauge was not connected.) Conclusion, connecting the gauge removed the symptom and the engine idled perfectly both times the gauge was installed. Why? I don’t know yet. Was there air in the system that the gauge’s hose bled out? If so why does it only happen when the engine is cold? Why does it go away by turning the engine off and then on again?Not sure but I will go back to the manual’s Pinpoint Test section and proceed with more tests. Keep in mind that the engine runs perfectly except for the first start upon launching the boat and after it has sat for about 30 minutes. Stay tuned. I will fix this problem. The course on Mission Bay now has boat guides and turn balls that self adjust up and down with the tide. One of our members invented the stainless steel pulley system. It's absolutely unbelieveably superb. In 2006 we built a new dock, too. Tom T. |
Tom T.
2002 SN GT40 |
boo
To All,
Regarding the ISC-BPA, on page 3D-11, Step 3-Output Cycling Test, states operation of EEC controlled engine actuators can be performed at the conclusion of the KOEO self-test when using the Star Tester. I didn't do this test because I felt my Idle Speed Control-Bypass Assembly was okay. Tom T. |
Tom T.
2002 SN GT40 |
slmskrs
Tom, I only get the cold start loping when it is really cold (like air in the low 40s. Otherwise I don't get it (so don't get it very often--a few times this winter). Okay, your results are just plain weird! :-) On the surface, I'd just call it a coincidence, as it really doesn't make sense.....or does it? What if there is some sort of pressure surge. But when the pressure gauge is hooked up, there is not only the length of a hose that can expand and contract slightly with pressure, but there is definitely air in that hose, and you will compress that air so that when whatever is causing the pressure to drop, the air expands, keeping the pressure from dropping as much as it would without the hose, and maybe it is just enough to keep it from loping? I'd love to see you duplicate and see if the test results are repeatable. Since it appears that you get cold start loping every time (whereas I only get it when it is really cold), you could try starting it without the gauge connected. If it starts to lope, immediately shut it off, put the gauge on, and restart (I have tried shutting off and restarting a cold loping engine and it doesn't make it better). So, just thinking out loud if I had the same results, I think I'd do the following (depending on how frequently you are using it, you could do a few tests over a couple of days): Day one: Start cold, if loping, shut off, quickly put gauge on and restart. If loping stops, either shut off immediately, take gauge off and restart, or wait and do day two test. Day two: Start cold, if loping, shut off, wait the same amount of time it took to put the gauge on (but don't put it on this time), and restart. If loping stops, the waiting period is what stopped it. If it keeps loping, then attaching the gauge stopped it. Do you ever have the problem while out at the course when it is warm? If I'm pulling back to back skiers with only a 5-10 minute stop, I never have a problem. But if we are boat rotation (max three boats allowed at a time) so I wait for two skiers or 20-30 minutes when the air is warm, it lopes. If you have the same scenario, you could do a number of similar tests the same day between boat rotations. But if not, then it looks like your only hot engine test is when you are at the flushing station. I will make sure to have my gauge when I go out next time and if it is warm enough, I'll do these tests as well. It's not cold enough for me to get the cold start loping so I can only work on hot engine loping. For that to happen, the air needs to be at least in the 70s (at least when it happened Saturday, it was around 70 outside). We're on a percolation pond here in San Jose, But with rain and the water district playing around with the dam, we can fluctuate upwards of 18 inches. We have sub-floats with 3 or 4" diameter capped PVC tubes with a cylinder lead weight with a stainless cable; the cable coming out of a hole in the top. The weight appropriately counterbalances the buoy and has about a 12" travel (depending on how deep or shallow it is at the anchor). It works reasonably well, but we don't have the daily level change you guys have. I was course caretaker a number of years ago and even though the deepest is only about 12', I dove with tanks many times to do repair (visibility on a good day is about 2", usually around a foot). What is the average spread between high and low tides there? When I skied there, you still had the old dock. I told your club president at the time (I skied with him and someone else and I'm pretty sure it was a Nautique) that he and anyone in the club had an open invitation for a pull up here and no-one has taken me up on it yet...... |
slmskrs
Just had to run out to give my youngest daughter's boyfriend a jump. Probably corrosion rather than a bad battery, but his battery is behind the rear seat, so I wasn't going to get out a hydrometer, etc. to check (just jumped to a positive terminal in the engine compartment).
Anyway, while I was driving back from giving him the jump, I though of another possible test to run when it is loping (at least a hot loping test since it seems that the causes of hot and cold loping would be completely different). When the key is turned to ignition, both pumps go on for a half second or a second unless the engine is starting/running. However, there is a terminal on the test port that you can jump to turn the pumps on (I did that when testing the flow rate of my low pressure pump last year). I've always thought the hot loping was caused by some vaporizing somewhere and you needed some time and RPMs to get cooler fuel into the rails (in other words, the FCC isn't perfect). So another test for loping would be to jump the pumps and let them run for a minute or two before starting (simulating the flow of fuel during the first minute or so of loping). I would think that would flush enough cooler fuel through the system that if there was a vapor issue, it would be resolved (since running it at higher throttle runs more fuel). Again, it seems that loping is caused by erratic idle speed control valve behavior, but if it is a fuel/pressure issue, I'd probably try this as an additional loping test. Of course, I don't want to have to jump the pumps every time, but that would help to narrow down the search for the source of the problem. Dang! I need my weekend extended so I can work on this! |
boo
Gordon,
Please check your Private Message Inbox. Tom T. |
Tom T.
2002 SN GT40 |
boo
The boat sat yesterday afternoon and all day today. After work today, I drove to the boat and connected the garden hose to the engine’s flush connection. Instead of connecting the fuel pressure gauge to the relief valve on the fuel rail, I did something different. I unscrewed the relief valve’s cover and used a small flat tip screwdriver to depress the valve’s stem - just like you would release air from a tire if you overinflated it.
I placed my ear very close to the valve as I depressed it very, very gently with the screwdriver hoping I might hear some air flow out of it. I did not hear any air. I removed the screwdriver from the valve tip so it would spring back closed and then threaded the cover over the relief valve. Next, I started the engine. It idled up perfectly for about 5 – 6 seconds and came down to its proper idle speed. In other words, the engine idle loping did not occur. I’m definitely onto something. The engine never should have idled properly after putting it away yesterday when it loped on the wash ramp. Every time I’ve depressed that valve stem, the next time I start the engine it idles perfectly. For now, this will be my last post until I figure out why pressing the relief valve on the fuel rail causes the engine to idle correctly on a cold start. The cause is probably a vacuum leak. I will find it if that’s the culprit. I’m not a mechanic so what I’m about to say please consider the source. I do not know how long it takes for the fuel rail pressure to subside, so pressing the relief valve, I would assume, could produce catastrophic consequences if its still under pressure. Something like an explosion or fire. With 900 views to this thread, I hope I’ve helped some of you with my postings. So far, I’m very happy with the results. My next post may take weeks or months but I will post the final outcome. If any of you have been able to temporarily resolve your idle issue using this method, please post it here. I would like to know. Tom T. |
Tom T.
2002 SN GT40 |
slmskrs
Just a quick thought. If the idle speed solenoid is failing to open upon hot start and therefore little air is getting mixed with the fuel, if you cracked the throttle slightly to let air in, then it should start rather than just dumping fuel into the cylinders with no start (it would just immediately start racing). Just wanted to check to see that it is not starting when you crack the throttle (at the start, not when it is already "flooded"). If it start when the throttle is cracked open, then it is the solenoid (or something in the line (low voltage, etc.)). If it doesn't start if you crack the throttle at the beginning, then I don't think it is the idle valve solenoid. Just a thought.... |
slmskrs
That is just plain weird! :-) I can't test it since it just isn't cold enough form my boat to have cold start loping (funny since it is always warmer in San Diego than here near San Francisco). So I can only test hot loping (assuming it is warm enough this weekend), but I will definitely try bleeding the rail (with a rag or something so I don't blow up) and see if that stops the loping. |
