engine rebuilt |
Post Reply | Page <1 456 |
kapla
Eric...good for this site!! i found some pics on the damper plate installation!! It was on mi-nick post, about his damper plate change!!
Now I can figure it out in my mind!! lol Thanks for the patience!! |
Luchog
Kapla just for curiosity, how much for the cylinder jackets?
Pete, I wish....they take a good half hour to get to temp with no load on them...no cooler just a loop, anymore its alot easier to throw them up in my lathe and spin them
kapla
Lucho Sleeved costed $200 each so the 8 cylinders went for $1600...but I ended up paying 2700 for all the machining work....pesos
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5776 |
You guys must be using different terminology because those cylinders are just bored and honed right? $200 a hole...eyecarumba!!!
kapla
Alan..I had to put cylinder sleeves to my block (normal to do it here, as no block of these type available) because when doing the .30 overbore one of the cylinders walls cracked, it seems the water had internally corroder the galleys making the cylinder wall very thin..
the cost is in argentine pesos for each cylinder sleeve...at $3.85 a dollar its around $50 dollars each...If I had know I was going to sleeve the block I should have ordered the std pistons... I´m a little worried though for the sleeves but it was the only thing I could do..If not I needed a new engine directly!! For you its easy as you can find 351w blocks in any yunkyard...the only v-8 I can find here are the ford Y Block 292 ci or the 318 chrislers... |
81nautique
I was just looking at the pictures of the block and I couldn't tell it was sleeved. I'm not too familiar with sleeving a cast iron block. Are they just pressed in?
kapla
yes.. they are pressed inn. From the top you can´t tell its sleeved as after they sleeved it they do the resurface so the joint its almost invisible..you can see the sleeve from the bottom of the block.. here is a pic from the bottom..you can see the difference of colour of the cast iron and the sleeve..
MI-nick
Gold Member Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 809 |
i thought those pictures looked familiar...
kapla
OOPs..while having a look on the parts..I noticed a small leak in the tranny comming from the port side lower bolt ear...before it never leaked a drop...I was hoping that when putting the tranny again the same bolt will put enough pressure on the gasket again to close the leak...
here is a pic showing the place the leak is... in the worst scenario is changing that gasket easy? or how far the tear down needs to go? BTW the leak is inside the bolt ear..the fluid line come out from there...all the exterior of the gasket has no leaks at all... |
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
I guess you can buy a nut and tight the bolt.. just a thought
uk1979
Seb It may fix it when the bolt is used to hold it to the bellhousing bolt it up to it and see if it leaks,before you put it all back in the boat.
Lets have a go
they'll leak because you dont have it bolted to the bellhousing, once bolted it should cure the leak
kapla
Ok then I hope it does!!! actually i noticed the leak this week..before it sat in the shop and i never saw a drop....
Roger thats what I will do.. |
kapla
some pics of the engine as for today..
only few things are left to finish it...looks nice... |
critter
Looking good there sebastian..
You want to just ship that to New Hill, NC for me. I will cover the shipping cost.. |
1980 Ski Nautique
1966 Barracuda |
Those engine photos look like they were meant for marketing brochures!
kapla
yeah right!! specially the stand (51 gal drum) were the engine sits on..LOL
uk1979
Seb looks great and loving the South American engine stand
Lets have a go
How many liters is that? Does the wall need to be held up? |
kapla
200 liters... you mean the drum wall? its very strong by itlself...
The engine is just there in the corner of the shop, as there some cars laying around...its not touching the wall at all... |
anthonylizardi
Wao Seb! That engine looks nice. You have come long ways rebuilding and upgrading a V8 in SA. What's the plan for break-in?
kapla
same question I was going to do in a couple of days when all ready..
I read some braek in info on the owner manual..but wanted to make sure its ok.. I don´t know if to do it in the driveway or directly on the water... cam came from Cam Research already breaked in...but ring and other stuff need to seat correctly... also I wonder about the heads needing to be retorqued after some usage? is that correct..pita as to do so you need to remove the manifolds as the valve cover center bolts are unreachable with them on... seb.. |
Looking great Seb!! Now if it runs like it looks - but I'm sure it will!!
kapla
thanks pete..I hope it does!! theres always contingency..hope not in this case....
as John and the Brunstuckians would say: its perty
kapla
Looking it again I will need to give some new colour to the alternator..to match up with the new powder coat I gave to the pulleys...also the pump need some life..LOL...
About the RWP..they came original with some special finish? or just the natural colour of the alloy of the body and the galvanised of the pulley? |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
Was going to say the same thing about the altenator. Engine looks great. |
