Invertaflow muffler question |
Post Reply | Page 12> |
Author | |||
JPASS
Posted: February-09-2015 at 6:39pm |
I do recall seeing a small hole near the bottom of the spillway insert under the hat near the base of the muffler housing. Maybe this is what he was referring. I could see how this would allow water to exit the exhaust naturally, albeit slowly, at levels below the top of the spillway pipe.
I went back a page and noticed the video I posted has the hole I'm referring to right there. |
'92 Correctcraft Ski Nautique
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21138 |
Bert said there was a drain hole that would allow the water to drain out after shutdown. He didn't say it was an external drain... I would assume it to be internal since that would allow draining to happen naturally after every shutdown.
JPASS
I have a small screw on the starboard side of the the muffler body about an inch up from the bottom edge. It's currently glassed over. Haven't decided if I'm going to drill it out again.
I did not see any other drains on the muffler. |
dwouncmd
Gold Member Joined: July-10-2009 Location: NC Status: Offline Points: 919 |
I don't have a drain hole on the outside and did not see evidence of one on the inside pipe when it was apart (I probably just missed it; now it is surely glassed over) |
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7 |
Mine is definitely louder when it first starts even at the dock. Here is the responce I recieved this morning--- Good morning Gary, You are correct, by design, we have always included a drain hole in the outlet pipe of the muffler in order to drain water when the engine shuts down. However, a very small amount of water will remain inside of the muffler. This small amount of water will not pose a problem if it were to freeze. If the muffler was full of water, then you would need to worry about getting antifreeze into the muffler. We also include drain screws in the mufflers to drain water as well. Let me know if you have any other questions. Regards, Bert Browning Centek Industries, Inc. Manager, Product Design & Engineering Mechanical Engineer Phone: 1-229-228-7653 Mobile: 1-229-224-5653 Fax: 1-229-228-1270 Email: browning@centekindustries.com SKYPE: bertbrowning |
Orlando76
I would think if it didn't hold water, then when you crank it on the trailer for a slight second it'd be louder until it filled up as the water does a good part of the muffling??
JPASS
Our boat has been a Florida boat it's entire life. freezing had nothing to do with our leaks.
Good analogy Joe but the only way I can test right now is to put some water in an ice cube tray |
dwouncmd
I just wonder if the freeze/thaw expansion cycle has anything to do with the cracks, leaks, and particularly the inner pipe working loose. I think there is plenty of room above the waterline for expansion, but I bet the water in the muffler freezes solid. |
89 SN
JoeinNY
I cant imagine it doesnt hold a bit of water but it would have plenty of room to expand and gives a bit more than cast. When is the last time you saw water in an open plastic bucket cause a problem when it froze?
SNobsessed
If freeze expansion was a problem, wouldn't all of us northerners with this muffler have failures by now? Mine seems to be fine (knock on wood).
I just emailed Centex about the Invertaflo holding water,will let everyone know what they say.
Well that's not good,I have been using the pour method,can anyone verify that there is any water left in the muffler? You would think that there would be some sort of drain or reference to this in the owners manual. Maybe a call to the muffler manufactor is in order? |
JPASS
Thanks Pete. I guess I'll find out soon enough. just need to grind down some rough spots and paint her up.
JP,
I'd be surprised if the exhaust system sees more than 2 to 3 PSI. I thinks your repair is fine. The system is pretty open and doesn't back up much head of water. It takes 27" of water column to create 1 PSI. |
JPASS
I got the spillway pipe glued back in and I've used about 2-3 layers of 6oz mat to seal up the sides. Is this enough glass or do I need to put down more. Seems pretty solid to me, but I have no idea how much pressure is in the muffler while the motor is running.
backfoot100
I don't think it'll be louder. The water level in the tank is what's doing the muffling. I seem to remember somebody else here that completely removed all the baffles when they blew out the invertaflow and repaired it. There wasn't any noticeable difference in the sound. |
Eddie |
JPASS
Freezing was never an issue as this boat was in central Florida it's entire life.
Thanks again for all the help. Much appreciated. |
dwouncmd
That seems right to me... |
89 SN
dwouncmd
I think that is exactly how it works.
Probably. Not sure. I think the leaks occur as the thing falls apart. It is mostly full of water all the time. Maybe freezing in the winter time leads to cracks, leaks and the small pipe coming unglued? Unless you run antifreeze through until it comes out the exhaust, the water left in would freeze. |
89 SN
SNobsessed
Taking the stand pipe out would just turn the muffler into a straight Y pipe.
Lower flow restriction & louder exhaust sound would be the result. |
JPASS
My understanding of how this works is this:
That floating pipe actually acts like an elevated spillway in that the exhaust doesn't start dumping water until the height of the water in the muffler reaches the top of the loose pipe. Then the water will then flow out the exhaust. I'm assuming this also helps to create a certain amount of back pressure? Would not having this spillway effect anything in regards to the way the motor runs or performs? Wonder if it lead to any of the leaks due to an improper water level in the exhaust? Or maybe it's just too early and I'm talking outta my a$$ |
dwouncmd
I believe the small floating pipe seats down into the down pipe. I think the chamber above is an outer baffle for the exhaust (the exhaust has to flow through the water and into up into the chamber; when the smaller pipe was seated in the down pipe the water level must be as deep as the smaller pipe protrudes up into the baffle, the water and exhaust have to flow up into the chamber and out the smaller pipe into the down pipe). I don't think mine ever had that chamber, just the smaller pipe seated in the down pipe. My 89 was the first year for invertaflow; I think your muffler is a slightly newer design. I think you could just expoy the smaller pipe back into the down pipe, but looks like it might be tough in the small space you have to work in.
89 SN
Alan, I stand corrected. It's easy to criticize when I see many failures without thinking the complete situation through and I apologize for that. |
JPASS
I'm not sure I follow? Here's a video of whats going on in there. It almost looks as if I should slide the loose pipe up into that weird chamber and apply some epoxy to the end and then let it seat itself and call it a day. I don't see an easy way to fix this floating pipe. |
dwouncmd
I didn't cut mine. The larger outside exhaust pipe is stuck in through a hole in the side of the main muffler, then glassed in. I worked my way around the glassed-in joint, delaminating the joint one layer at a time until the pipe was free. The problem I see with cutting it is that you would lose the extra length that projects into the muffler and allows connection to the smaller inner pipe and the glassed in joint to the muffler.
One caveat to replacing the muffler with an unknown model invertaflow, they can be slightly different in terms of connection spacing, pipe size and angle to manifold, as well as lateral position and angle of the down pipe. They are not universal (I have one donated to me that does not fit in my boat, which I am hoping to donate in turn to someone at a reunion one day). The y pipe conversion is an option, but repairing the one you have is probably a whole lot less expensive, and as a bonus you get to figure how it is put together and how it works. |
89 SN
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Online Points: 5775 |
You have your engineering blinders on again. I'm just saying how many 1000's of these things did CC put in their boats in the 90's? Of course there are going to be some failures but when the majority are still in service after 20 years and 1000-2000 hours of use that doesn't seem to deserve the "pathetic" grade. YES anything can be scrutinized after 20 years of use and be redesigned to last longer/perform better but that doesn't make the first edition a failure. |
Alan, I was basing my comment on the construction and not the age. The thin walls and little or no reinforcement on corners or joints. The glass hulls are past 20 and they are still good. BTW, I'm past 20 and slowing down but not falling apart! |
Air206
Alan, Pete was being kind.
If really disappointed he would say "Hack Job".... pathetic ain't nothin..... |
81nautique
Geez Pete, there's always room for improvement but these things are about 20 years old. Not a terrible track record really. |
