Points or Electronic ignition |
Author | ||
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
Posted: June-23-2012 at 8:13pm |
Ok. So I should just replace em all together, instead of keep cleaning them every 25 hours.
74SkiNautique
wingwrench
Senior Member Joined: December-11-2010 Location: Lakeland, FL Status: Offline Points: 155 |
Once you remove the platinum coating from the contacts either by filing or from use they are done, all the cleaning and new condensers in the world will not prevent them from burning again. Years ago the contacts were solid platinum and they could be dressed with no problem. |
I have heard that do to the fact that no one uses points in the volume that there used to be, that the replacements are not up to the quality standards of old. If I needed some I'd check with Napa
74SkiNautique
We just installed a new resistor because that failed a weeks ago. If you clean the points correctly, and set the gap correctly, how long should they last before you have symptoms of dirty points? |
74SkiNautique
slmskrs
Gold Member Joined: January-03-2012 Location: SF bay area, CA Status: Offline Points: 522 |
I had a 1985 Ski Centurion with a PCM 351 and points. I converted to electronic (sorry, can't remember the brand) about four years into my 10 years with that boat before my Nautique, and I was very happy that I did. Not one problem; worked like a charm, and no more dealing with points and condenser. :) I'd do it all over again if I had a points engine.
Gordon '97 Ski Nautique, GT40
74SkiNautique
ok. We installed a new cap, rotor, points, and condensor a few years back. We used Mallory, i tihnk it was $38 for the kit. also, we have already upgraded to a 4-blade OJ propeller. haha
74SkiNautique
wingwrench
Throw the old points away and install new ones along with a new condensor. Once the coating burns off the points they are done, cleaning/filing will get you home but that's it. Be sure the new contacts are clean and oil free before and after install. Oily feeler gauges are points worst enemy.
Waterdog
All condensers are not created equal,the condenser needs to match the points or the points will arc and burn.
A warm coil is normal HOT is not. I've used Mallory E spark & DUI electronic ignitions both are good. Get the points right and use the money to buy a prop. |
Chris, Check the voltage to the coil to make sure the ballast resistor is doing it's job. You should not need to clean the point set every 25 hours. You may have a bad condenser. I went over 20 years (over 420 hours) on my 312 without even opening up the distributor!! |
74SkiNautique
This coil says use external resister on the side of it. We havnt changed it since we bought the boat in 2004. It feels VERY hot, and it seems like it is oil filled because I can hear liquid in it. Anyway, the boat runs great when the points are cleaned and gapped properly. it seems about every 25 hours we have to re-clean and gap them because it gets a little hard to start when hot. If I switch to electronic, is it an upgrade or a downgrade. How long do you guys run before you have to clean your points?
74SkiNautique
Chris,
Was the coil changed out? Is the voltage going to it proper for the type? (internal or external resisted) It also should be epoxy and not oil filled sing they lay on their sides. Point sets have been used since they got rid of the old "hit and miss" engines. That's lots of years!!! They work plain and simple. Conversions on the other hand always don't. There are several brands out there that reliability is a problem. If a conversion goes out on you in the middle of the lake, you had better have an extra on board. If a pont set gets bad, all you need is to clean up the contacts to get back home. What is the problem with the engine or are you just wanting to go for some bling? |
74Wind
I've read some negative comments & I can't speak for the technical aspects, but i switched over to electronic ignition in my 75 Century and it's run well & reliably ever since. |
1974 Southwind 18
1975 Century Mark II |
74SkiNautique
What are the pros and cons of switching from points to electronic on my 1974 Ski Nautique. Also, How hot is your ignition coil supposed to get? I can barily keep my fingers on mine for more than a few seconds. Is this normal?
74SkiNautique
