wire harness |
85Nautique
Groupie Joined: April-30-2007 Location: United States Status: Offline Points: 69 |
Posted: October-04-2007 at 6:49pm |
Hey 79,
I just burned up my wire harness I saw that you have replaced yours did you just rewire with plain wire from home depot and remove the plugs on the harness. The wires are burn from the alternator. Need your help trying to fix this weekend so that I can winterize soon .. |
85Nautique
sorry it is a 351 commander
Brian, I would try to find out what caused the melt down first. Have you been doing some rewiring with Home Depot wire? Sound system? pumps? Fill us in! They do make "marine" grade wire! More important are the connections. Fusing??
85Nautique
the melt down happened after i replaced the alternator belt, I have not done any replacing of wire, Should i get the wire from boaters world or something like that, I have all the color and Gage of wire i need for each wire just not sure what Pin referres to. Is this something i can do in a weekend. any help would be great
Brian, Replacing the belt just meant that the alternator may have put out it's full rated amps. (the belt wasn't slipping) You haven't mentioned any add-ons that may have been done. Have you installed a larger than stock alternator? If you had a short, the main breaker should have popped. I'm trying to get a idea of why the burnt wiring.
Skidim does have wiring harnesses. |
79nautique
get a new harness from skidim and you will be done in about hour or so.
85Nautique
The old belt may have been slipping but the new belt was not slipping, Regards to add-on it is stock other then a electronic ignition and I installed a depth sounder to replace the clock. Nothing other then that. I am thinking the alternator wires may have been cracked or touching and that may have caused the melt down. Not all the wires in the harness are burnt so I am going to look it over this weekend and replace the ones that need to be replaced and leave the rest no need to break something that has been working.
Let me know if I am on the right track. I talked to woody at southeast correct craft and Vince at SkiDim: Vince said he has a harness but it would need to mod. To word. Woody said just replace the wires that are fried and leave the rest. And splice into the harness before the plug. |
