Reducing drag! |
stang72
Posted: April-03-2007 at 10:26pm |
The cheepest performance trick....reduce that drag!
I was just wondering how much time does anyone spend under the boat???? A good buffing and wax job as well as smoothing out and polishing the rudder and fins can reduce enough drag to gain a couple mph top end!!! Try it and see! |
When I did that it cost me an engine rebuild! When I got my boat it was in bad shape,but I got it running and used it for one summer.On that summers Labor day I decided to clean the bottom.I had waterpump trouble,if you drove off it was fine once it warmed up,but if you idled off it would over heat.Well after I cleaned it,I idled off not thinking,went about 1 mile,looked back and saw steam coming from the exhausts.Shut it off and luckily it was so hot it would not turn over,if I had gotten it started I'd have cracked something for sure.So now it's on a lift to keep it clean,I don't want to jinx myself by going under it again.
stang72
Your safe as long as ya don't get a rag stuffed in the water intake!
Randy_in_Ohio
I buffed out the bottom of mine. took it out today for the first time this year. I think you may be right, I did see an improvement.
Gary, What do you use to polish the fins and rudder? |
stang72
Randy,
My fins and rudder were pretty rough (machine marks,nicks etc)...you can wet sand them a bit and buff them with a high speed buffer using compound or metal polish. Also...On many older boats...the bottom can have chips and scratches...worth the time to fill and smooth! It all adds up...all those surfaces! |
A low drag bottom will make a difference. Think about sail boats and the work the pros put into their bottoms to gain speed. Of coarse on a sail boat, a small % makes a big difference.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5772 |
Gary,
Thats in my future before it gets in the water this season. Not really for speed but I can't have anyone crawling under my boat and seeing how filthy it is under there now can I. Gonna get it off the trailer once I get the motor work finished and compound and wax the bottom. I have one gash to repair from the PO, he said he used to float the boat on the trailer, after looking at the gash I think he tried power loading once and said never again. |
boat dr
81,If you are speaking of the America's Cup,yea they spend mega bucks looking for that .25 knot increase in speed. Only downwind can these boats outrun their own wake,the catamarans ,Hobie & Nacra, are a different animal. Planing hulls means less boat is in the water.Waxing a Hobie is a sure way to slow it down,shaping the rudders,and boards and cleaning up nicks and scratches,Do..........boat dr .
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
I've heard a waxed hull creates more surface tension and actually slows the boat down. That said, I wax mine because I moor it, and the mung cleans off much easier when it's been waxed at the beginning of the season.
Doc, You have a very good point regarding the planing hulls. I read someplace that someone was experimenting with a golf ball like surface on a boat. My understanding it worked because it trapped air under it reducing the surface tension to the water. Now all we need is to train the barnicles to grow on the bottom in a pattern like a golf ball!!
81nautique
Like I said, I'm cleaning it because it needs to be cleaned and the wax does help with cleanup during the season. I boat in some pretty brown river water and it has to be wiped down as soon as it comes out of the water or else it's hell to get off. I think the buff and wax helps seal up a porous gelcoat and aids in cleaning. Guess I'll have to give up that .25 knot increase I was not looking for.
JoeinNY
Grand Poobah Joined: October-19-2005 Location: United States Status: Offline Points: 5695 |
In sailboat racing the hot surface is usually a non waxed but wetsanded about 600 grit boat. There are a couple wax type substances from sailing that claim to be as good or better than a freshly wetsanded boat. A lot easier to wax than to keep it perfectly smooth if your not racing boats where a 1/4 knot makes a difference. I don't race sailboats as much as I used to, but if any of y'all ever want to feel what its like doing 25 knots through 3 foot waves on a 17 foot catamaran just look me up on a windy day.
boat dr
Joe,from your post about a 17 I assume your a Nacra guy,Have raced a H-18 for 20 yrs.Have yet to master it so no need to move up.
We had our first regatta last week end, weather proved who was in control,and it was not the race committee.Plenty of rain and 20 to 25 knts.I am not as mad at the wind as i used to be,maybe age ,or is it wisdom...... JOE SAID: I don't race sailboats as much as I used to, but if any of y'all ever want to feel what its like doing 25 knots through 3 foot waves on a 17 foot catamaran just look me up on a windy day..... Words do not tell that story: gotta be there to feel that RUSH.boat dr |
eric lavine
I new you had a sensitive side doc, being a blow boater and all. lol eric
JoeinNY
yep doc, nacra 5.2, two of them they got real cheap when they stopped being a current production class. They were fast enough to beat all the hobies on the lake until my arch sailing nemesis got himself a brand new hobie fx one summer before last, he used to be me 1 out of three times without handicap, 2 out of 3 with handicap with his old hobie 18. Now he is back on shore and one corona ahead of me by the time I finish.
Randy- since I have an old boat it does not have fins.The rudder I had out because I had to get a replacement so I used a DA sander then buffed it.But now I have the original rudder on,the PO had found it and I didn't bother to do anything with it.
SkiBum
I always thought the perfect ski boat would be the width of the boat guide bouys with a flat bottom and golf ball dimple surface with large dimples to trap air. I can picture soft foam in the place of evil wakes exiting the back of the boat. I guess if I just don't sand the orange peel off my boat I could test that theory. |
boat dr
Ski Bum, the product is called;Miracle Micro Balloons,and has been banned in most one design sail boat classes.
It works by trapping water in those "dimples" water sliding over water,same as a golf ball.The surface looks simular to "orange peel" but much more uniform.....boat dr |
Bill, I think you should try it!! You can always sand off the orange peel later.
87BFN owner
Dont forget waxed hulls slide off trailer very easily if they are not hooked to the trailer. especially on a steep ramp.
stang72
Very true about the bunks...especially if you have BUNK carpet(I nearly lost one at the ramp once)
I stand by the clean waxed bottom...I have done it and each time I pick up about 2 mph top end! Maybe if I just buffed and left the wax off , it would even be better!!! I suppose the more important part is to hone the hardware, fix scratchs , chips and remove oxidization....= less drap! |
