location of impeller pcm351 |
chevyred
Newbie Joined: November-24-2006 Location: United States Status: Offline Points: 2 |
Posted: November-24-2006 at 12:14am |
I've read all of the forums pertaining to this subject and am still confused. I can do plenty of maintenance to my 88 2001, but have had the boat out 2 seasons without changing the impeller, partially because i dont know where the damn thing goes. A photo or diagram would help me out tons and once i do it once im sure ill do it too often like changing the oil every 6 months reguardless of use. thanks for any advice in advance.
Keep On Truckin
Follow the water intake hose from the bottom of the boat, through the oil cooler then to the RWP (raw water pump). That's where the impeller is. Good hunting, Pete
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
Go to the reference section on CCfan.com and download the PCM manual. It doesn't go into a ton of detail about the raw water pump, but it might help.
GN6027
1987 Ski Nautique 2001 |
Poster112
Senior Member Joined: May-28-2006 Location: United States Status: Offline Points: 206 |
Here is what my water pump looks like on my commander 351 (sort of) I do not know if yours will look the same
The impeller is in the bra$$ housing (black paddle wheel inside is the impeller) I always keep a spare in the boat. |
Poster112
Here is what the impeller looks like on mine.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21115 |
Looks the same on my '90. Should be the same for his '88.
Before you take it off, mark the orientation- its very easy to install it backwards! |
chevyred
thanks guys! i think is should be able to find it a$$ soon as i can climb back up into the boat. i just had acl reconstruction surgery and hope to have the knee and boat ready for june! thanks again!
Keep On Truckin
advsouthwind
Groupie Joined: April-27-2006 Location: United States Status: Offline Points: 82 |
USUALLY IT IS ON THE DRIVERS SIDE OF THE ENGINE, FOLLOW YOUR FAN BELTS. ONE WILL RUN YOUR ALTERNATOR THE OTHER WILL TURN YOUR WATER INTAKE PUMP. IT WILL ALSO HAVE TWO 1 OR 1 1/4 HOSES ATTACHED TO IT. TAKE CARE IN HOW YOUR PUMP IS MOUNTED SO YOU DONT INSTALL IT BACKWARDS AFTER REPLACING THE IMPELLER.
gave up sea ray life for a 77 southwind 20 project just livin the dream
