Tach Conversion Possible? |
Nautique Mike
Senior Member Joined: June-20-2006 Location: United States Status: Offline Points: 147 |
Posted: November-07-2006 at 9:18pm |
Hey Gang-
Here's a good one for you... Has anyone ever tried or is it possible to convert a outboard tachometer to a inboard tach? This is for a 351 commmander. Both guages are 78' vintage teleflex with 6000 rpms. Thanks- NM |
Nautique Mike
I Think its the number of cylinders and 2 or 4 stroke thats important for the tach to read. So wouldn't a tach read the same hooked up to a 4 cyl 2 stroke as a 8 cyl 4 stroke? Pete
boat dr
Mike, 4/ strokes read pulses or counts at the coil,8 pulses = one RPM on a v-8 and signal wire hooks to the coil. a 2/stroke reads pulses or counts the poles on the flywheel,6 magnets=12 poles,4 magnets=8 poles,and the signal wire hooks to the rect/regulator. the newer tachs will go both ways,2 or 4 stroke. hook it up and see ,you wont let the smoke out ,it just wont read correctly....... boat dr
79nautique
No they wil not read the same. If it was a lter model outboard that was of a four stroke design and was capable of switching to 8 cyl then it would but since there weren't any four strokes in the 70"s your SOL.
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
If the tach has switches on back,you can set it to 4.4 pulses per rev on a v8 4 stroke.I don't see a problem if it has switches for different applications
Good luck Munday |
79nautique
if it is designed for a 2 stroke motor it will not work for a 4 stroke motor and vise versa 4-2 regardless if it has a switch or not.
79nautique
if you did that then it will read twice as fast as your going since there needs to be one pulse per cyclinder. |
