Southwind 18 bilge pump |
Tom Southwind
Newbie Joined: September-20-2005 Location: United States Status: Offline Points: 12 |
Posted: July-24-2006 at 1:10pm |
I bought a southwind 18 can some one tell me how the bilge system works. The pump is running but I can not find where is is pumping to it looks like it goes in to the floor but I cannot see where it goes.
Thanks |
79nautique
there is a thru hull fitting that the hose connects too. Mine is forward of the driver's seat. Look around on the outside of the hull and you should find a thru hull fitting with about a 3/4" dia hole in the middle, usually plastic but maybe metal. there should be another one that is chrome and smaller and that is the vent for the gas tank and mounted on the transom mostly.
fredo68
Senior Member Joined: April-03-2006 Location: United States Status: Offline Points: 138 |
what year southwind? and maybe if you hear the pump running you should pull the boat
and drain it from the bolt in the hull. |
fredo68
Tom Southwind
Ti is a 77 Southwind I have been drain with the plug I have never had much water in the boat I have only been out for short trips The pump is located about 6 or 8 inches in front of the drain plug will the drain I think I know the hole on the transom there is no water coming from that hole when pump is runing
duffnit
Senior Member Joined: October-12-2005 Location: United States Status: Offline Points: 235 |
Perhaps there is not enough water in the bilge to prime the pump and remove the water.
It seems like you need 2-3 inches of water to actually prime and pump. That being said it won't remove all of the bilge water, or at least none of mine do. d |
Danny
"no offense- but the rate at which you spread bad information is very impressive" |
JoeinNY
It takes less than an inch to get water to come out of either of my Correct Crafts, you won't get much but you will get some. I would pull the hose from the pump, and either blow through or pour water through the through-hull fitting and make sure that the hose is attached to the fitting and there are no blockages.
-joe. |
fredo68
the hole in the transom is the gas tank vent.
you bilge through hull fitting will be on the side. joes right check the hose for obstructions, however a new pump and hose is a lot cheaper than a wet starter, or worse. good luck |
fredo68
oldskiboat
Groupie Joined: June-16-2006 Location: United States Status: Offline Points: 92 |
My 75 Southwind has the drain on the far port side of the stern. Further over then the gas tank vent.
