Fuel Tank Breather |
Author | ||
tstafford
Groupie Joined: March-15-2004 Location: United States Status: Offline Points: 81 |
Posted: July-20-2008 at 4:12pm |
On my 68 Mustang the breather is located on the transom of the boat. On the inside of the boat is a 2' hose connected to the top of the fuel tank in front of the filler hose.
How are other Mustang owners systems plumbed? No matter how much fuel is in the tank, fuel sloshes out the breather. I didn't notice this as much until my new white paint job. On other boats the tank sits much lower in the boat allowing a vertical run of the vent hose and a one way ball valve. My vent nipple is not much lower than the vent. Thanks, Trevor |
Trevor 1968 Mustang
Trever, Double the length of hose between the tank and the through hull fitting. Coil it under the deck and fasten this coil up as far as you can. Usually you will have some bolts for deck hardware that you can lengthen and use with hose clamps.
Sorry to hear that you painted and not gel coated. This isn't the only problem you are going to have with paint. |
Brktracer
Senior Member Joined: December-20-2007 Location: South Carolina Status: Offline Points: 387 |
What are the other problems? |
Matt, you bought your boat painted didn't you? I'm not a big fan of painting a fiberglass boat just because the durability isn't there compared to gel coat. I've been a wood boater for so long that I'm very familiar with the care needed to dock and moor a painted boat let alone leave it for any time. The fiberglass boat industry took off because of the low maintenance the boating people wanted. Yes, the newer LP's (linear polyurethanes) like Sterling or Allgrip are tough but they are still paint! They are still not as hard as gel. If scratched, you won't be out there wet sanding and buffing out paint like you can with a thick gel coat. If painted, don't plan on keeping the boat in the water for more than 3 days. The paint is not recommended for below the true waterline. Most of the manufacturers will state it directly in their application guides. The paint will develop blisters and you will end up with a real ugly mess!! Gel coating is however very labor intensive and the reason it does cost more. Now, if you have a scratched up painted boat that you want to gel coat, Extreme care must be taken to get every single spot of the old paint off before you gel! |
