Drilling hole for bilge pump outlet |
Author | ||
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Posted: January-11-2008 at 3:38pm |
I am planning on installing a bilge pump in my Mustang. The fitting for the outlet for a 3/4" hose requires about a 1" hole to be drilled in the hull. That is a big scary hole to me. I'm thinking I want to put it on the rear starboard side. Has anyone installed one of these? What kind of drill did you use? How do you do it without the gel coat cracking on splintering?
Bruce, Get a hole saw and mandrel. Run it backwards to get through the gel coat a little. It will cut a nice clean hole for you.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21132 |
Dont worry Bruce, it could be worse! A regular drill bit will work. Its not a bad idea to tape over the area youre drilling and to run the drill backwards to avoid chipping the gel. Chamfer the edge with sandpaper once youve got the hole in.
Id almost be more inclined to put the outlet up front, as the curve of the hull might make it less noticeable. The back isnt a bad option either. May I suggest a SS thru-hull fitting if you arent already planning to use one? |
Bruce don't drill yet,I'll get you a picture of mine which was factory installed.
JoeinNY
Grand Poobah Joined: October-19-2005 Location: United States Status: Offline Points: 5695 |
Tim that Tique looks pretty good, what was the reason you weren't keeping that one again?
I am pretty sure my bilge pump is in the factory location as well if Gary can't come up with a picture of his I will uncover mine and get one for you this weekend. -Joe. |
Joe, that Tique is a keeper- but it belongs to Pete. Mine isnt quite picture-worthy yet |
Riley
Gary/Joe, a pic of the original location would be great. I thought they were in the rear by the gas tank, otherwise I would put it in the front like Tim's Tique as it is easier to access and closer to the pump.
Tim, you had guts and great focus to cut that 2nd exhaust hole. If I ever convert the Mustang to a V8, I'll hire you to drill mine. Sounds like taping it and using a hole saw is the way to go. I'll be making phone calls when I actually start doing this stuff come May, although if this damn warm weather keeps up, it will be a lot sooner than that. I was browsing around at West Marine this morning and was surprised to find out how much stuff they have in stock and that it appeared of decent quality. The SS fitting is nice for a newer boat, but my goal with this one is to keep it as original as possible. Seeing that it's got a Ford Falcon straight 6, originality is the best thing it's got going. |
Riley
I was going to say, you've really been moving along on that one. |
JoeinNY
West marine isn't a bad place to have around town (invaluable to those of us who also sail)and some things are even reasonably priced but compare online if you have the time some things are 3-4 times the price you can find online.
Bruce here you go,one of outlet placement and one of hard to see pump location (replacement pump)The '63 American Skier I had,used a front outlet,but the pump was mounted up front as well.
Bruce, Just forward of the engine is usually the low spot in the bilge when the boat is sitting and the reason the bilge drain is in that area. I fell that would be the best location. Are you planning for the worst? After you are done with working on the boat, I'm confident that you won't have any leaks!
Tim, Yes that is a great looking Tique and you have made great progress on it! |
Yeah, she's ok. |
66Skylark
Senior Member Joined: September-01-2004 Location: United States Status: Offline Points: 195 |
Bruce,
I'm @ work and I'm sorry to say I don't have a picture of the back of the Skylark handy. If it helps to know, the outlet for the bilge pump on the Skylark is on the stern - port side. If memory serves, the vent for the gas tank is on the starboard side of the stern. Good luck! Kyle |
Barracuda
Moderator Group Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
Bruce- drills and boats just don't go well together, do they? I had a hard enough time drilling holes to mount my bim top last summer.
I've never drilled a hole that size in a boat, but would be inclined to use a corded drill with a hole saw. Definitely would not recommend a paddle bit and those 1" contractor bits will cut a hole in your wallet. |
Riley
Gary, that's where I thought they went. That pic will be a great help, thanks.
Pete, There's a lower spot in the bilge between the front seats. You can't see this area on mine without removing the floor. I'm thinking I'm going to put it there, but I will have to make that section of floor removable. I want a bilge pump so I can moor the boat. Kyle, funny how they put it on the port side like the steering wheel. I hate the thought of drilling holes. I thought of ordering a Bimini with my Sportster, but couldn't stand the thought of someone drlling holes in the deck, so I decided to put the money towards sun tan lotion instead. |
