winter mods |
Guests
Guest |
Posted: October-09-2007 at 1:00am |
..its that time for some of us guys on here to winterize our toys again. im sure they will be plent of time that will be spent on cleaning/wrenching/upgrading/our ships.what is on your "winter to do list"??
behindpropeller
New shaft
Replace Cutlass Bearing Replace Impeller Replace belts New plugs and wires. Rebuild or replace transmission. Next year it gets a new floor and motor rebuild. |
Thought this was a good thread till I started my list, now its making my wallet hurt thinking about it. Looks like the 67 wont get much attention this winter.
Wash/Wax/Winterize Replace Bent Front Fin New Cutlass Bearing Replace Raw Water pump New Shaft and Rudder Packing Add New Dimension Tower with Racks/Speakers/Amp Remove/sendback under warranty/reinstall stereo head unit. Remove x-pole and cut pylon, replace with stock ring and finger pylon Replace/Recut covers to Match tower Paint Exhaust Manifolds Cut to length and Install New Spark Plug Wires Repair/ Replace Wood in Drivers Seat Back Convert to 1:23 transmission, replace mounts, propeller, shaft, etc as needed. Upgrade Fuel Pump to Holley High Flow electric with Regulator Recurve, and upgrade or replace DUI, needs more initial timing, needs ability to retard timing 4 degrees on demand. Source and install New Spark Arrestor Fill Hole in Gunnel from previous stereo installation Reinstall fuel filter/separator Source/install replacement sea strainer Do Something about the big plywood box over my engine. -Joe. |
Im way ahead of you guys, started removing the decals for a paint job and removing bottem paint, waiting to pull interior for the dutchies, probably pull the drive for some tlc'n
SeattleFordFan
Senior Member Joined: April-18-2005 Location: United States Status: Offline Points: 190 |
Seek out a Mid 90's SN so I can take my time on the 80!!
Travs
Where there is a will, there is a way, and where there is a way, it usually costs more money. 1980 Ski Nautique |
87BFN owner
Not sure yet, have to look at the fundage available for projects then figure out which ones need to be done right now and which can wait. I will get back to this.
Guests
Guest |
damn joe- looks like your gonna be one busy man this winter..better have some deep pockets for all those upgrades..hopefully santa treats you real real good this year!
behindpropeller
Ryan-
The only thing you should be doing is buying a boat lift. |
jbear
Winter mods? We ski in the winter....no time for "mods"
john |
69 Mustang
Senior Member Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
Joe,
Want to sell that cut pylon with the extension? Mike |
For every complex problem, there is a solution that is simple, neat, and wrong.
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
jbear
Thread jack; sorry.
Mike; Had a senior moment...should've known you'd want the thickness.....of the swim platform guys...will get it to you in a few days. No time to run out to the boat and we are leaving for a long weekend up at Norris tomorrow. john |
69 Mustang
Hi John,
No problem - I have the template almost finished. Glad to see you back onboard. Mike |
jbear
Man am I glad to be back on here!
All I had for a week was tv! john |
What Santa could bring me is some nice heated workspace, and a little less work travel, and an injury free year and all would be well. As for buying parts the trick is to never ever add up the money you have into a boat.
Yep, Would have listed it here after it is actually removed but I am still skiing on it as of now. If its for a 69 mustang you might be more interested in my extra flite pipe which clamps onto the stock pylon instead of sliding over the top. Let me know what you are trying to do, I have so many old parts I am never going to use at this point I have no room to work. |
85nautiquematt
Groupie Joined: August-07-2007 Location: United States Status: Offline Points: 58 |
Taking the old carpet out of my 85 SN and installing new after I do some research first.
Painting the trailer before the snow flys here in WI - I'm not really down too bad with heat in the man cave, I can still do some detailing. 85 See ya on Green Lake in 08. |
Nothin like the sound of a mid 80's Nautique at mid throttle.
69 Mustang
Hi Joe,
I'll be using it for the 78 SkiTique. I have a FlitePipe and I like it, but the lower clamp block and the doghouse do not always get along well. I'd love to get yours since yours is already cut, and I don't have the heart to cut mine. Swapping them out would give me a cleaner install. Hope we can work something out. Thanks, Mike |
Mike,
Send me an email at jhf6659 at yahoo do t com and we can talk and see if it will work for you.. -Joe. |
MaddMarxx
I plan on adding some more horse power, around 50 to 70, so (bye bye) Reid and boat dr.
new- heads new- cam 715 holly carb under drive pulleys fluid dampner install-my edelbrock manifolds new-steering wheel install-my stereo new-gauges Im sure I will think of a few more! |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5771 |
Thanks to the sharp eyes of a couple of ccfans they alerted me of a deluxe trailer I've been trying to find for the last 2 years.
Was able to put a deal together and get it home yesterday. The boats already up on blocks and The trailer will get stripped this weekend and off to the sandblasters. The fiberglass will get paint in the meantime. Should be a nice addition to the 81 when done. Thanks Dave & Steve for the heads up. |
jbear
Way cool trailer Alan...had one of those under my first boat...a yellow '79. Always got lots of comments.
john |
Alan, I love the trailer and know how hard they are to find. I don't think there were many made with the fiberglass pans. The trailer I have for my Dunphy was originally the delux with the pan. It however was jack knifed which pretty much destroyed the fiberglass. I wish I went through the effort to repair it but at the time guess I wasn't thinking! Looking forward to seeing the end result.
Great news Alan- that beautiful boat deserves a trailer to match. I cant think of a boat more worthy of a rare deluxe. |
quinner
Alan,
Was that the trailer under that boat in St. Charles? If so How did you manage that deal? You will like the deluxe trailer, when you throttle off it will almost lift the boat off the bunks from the prop wash. IIRC mine had carpeting along the bottom center of the pan, bought the boat from the original owner so my guess is that is how it came from the factory. Looking forward to seeing your setup once the restore is completed. Congrats and good luck!! |
81nautique
Thanks All, CQ, yes it was the one from St. Charles. I intended on buying the whole rig , swap trailers and sell the rig quickly but the boat is so bad I didn't want to get into a restore job. He was asking too much money to turn it without costing me a ton of money and time. I just made him an offer to swap trailers with me and a little cash. He actually got a good deal because my trailer had all new tires , bearings, bunk carpet, etc. This ones almost as rough as the boat so I almost hated to do it but it will look great once it's done and I have a fairly easy winter project to keep me busy now. |
79Tique
Senior Member Joined: September-04-2006 Location: United States Status: Offline Points: 380 |
I'm gonna work my ass of all winter, and dream about the snow melting off my boats next spring so I can play and relax again. I'm planning on adding Perfect Pass to the 94 in the spring.
Work to live, not live to work.
Still by far the best mod I have made to date in terms of increasing the fun I have on the boat is the perfect pass. Might not be as important to those who have a significant other that can make a steady pull and stick mostly to slalom/barefoot skiing. But for those of us still in the girlfriend of the month club or who wakeboard/skate a lot it makes life a lot smoother. |
Still skiing haven't thought about winter projects yet.
That trailer is going to look AWESOME. There are currently 2 of those on BoatTrader right now, a nice orange color I've never seen. |
M3Fan
I'm doing a cutlass bearing swap on my 2000 this fall, and maybe a PP Stargazer upgrade in the spring
Mojo
I'm looking to remodel a laundry room and bathroom this winter.... Wait a minute, were we talking boats ??? Hell, where does the list end hahahahaha....
Moj' PS: Magic, glad that whole thing worked out for ya... It's going to be worth it once it's all done !!! |
05' SV211 TE
87BFN owner
My dad had a delux trailer under his 78 SN. It did not have carpet in the bottom of the pan, just plain white fiberglass. I remember washing the boat and the trailer when I was a kid.
