Can I ask questions about a Supra? |
Post Reply | Page 12> |
Author | ||
sjpitts
Senior Member Joined: April-16-2007 Location: United States Status: Offline Points: 111 |
Posted: April-16-2007 at 3:39pm |
Now I know that this is technically a correct craft site, but will you guys object too much if I ask questions about a Supra?
I have a 89 Supra Mariah with a PCM 351 Ford and a PCM power plus tranny. I have had the boat for little more than a year, and I am still trying to figure this inboard stuff out. The boat has a very dubious history, and I like to do things myself. Needless to say, Dubious boat, no knowledge, and DIY is a dangerous combination. The reason I want to post here is that it seems like this forum is full of people who like old inboards and like DIY. I have found many helpful discussions searching this site, and I couldn't find a comparable old supra site. I don't know why that is, maybe old supras just were not that popular. Or maybe they are here, just pretending to have Correct Crafts. Jared |
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Welcome to CCF.com, Jared. I don't think anyone objects talking about another type of boat here. One other member of CCF.com, Larry (75Tique) currently owns a 1989 Supra. We've discussed his boat in the past.
We share lots of information on PCM engines. You'll find a lot of troubleshooting threads from the past four years. Very helpful information. We also have a transmission specialist on this site. Post a picture on this thread, we'd love to see your boat. We also like discussing water sports too. Feel free to post any water skiing pics. Ken |
bkhallpass
Ask away. You may get a little ribbing (this is CC fan afterall). However, we have active members with American Skiers, Malibus, Centurions, and Supremes. I'm sure a little Supra talk won't hurt anyone. BKH
Livin' the Dream
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
no problem, welcome aboard. Not a CC but nearly any inboard is better than anything else.
Nate |
Hollywood
So what's the question??? As long as you're not trying to sell Viagra, Cialis or Herpecine you won't be turned away.
sjpitts
Well I am glad to see that there is some willingness to help out a non-cc owner.
Here are some pictures of the boat when I first bought it. It really doesn't look any better now. Notice the bend the in the trailer. The trailer is actually weak all the way around. It is very difficult to load on the trailer as the nose of the boat always wants to go under the black rubber thing it is supposed to be sitting on. This must be a long standing problem, as the nose of the boat has lots of little spider cracks in it. Jared |
bkhallpass
If there is a question in there, I'd say you are putting you trailer too deep in the water. If you don't put it in so far, the boat should engage the bunks and lift the nose up above the black roller. BKH
Livin' the Dream
sjpitts
So the guy I bought it from gave me a story about how he bought it from a friend and new that it was cared for, just old, and all that jazz. But I think he was giving me story, as I have since discovered that he seems to buy and sell boats all the time.
I had owned an I/O for a long time, but knew nothing about inboards. So I took it to a local shop and had it looked at. Notice that this was *after* I bought the boat. They gave me several items of bad news. First, there was low compression in one cylinder. The good news on this was that it went mostly away after running the boat, so in their words it might have been rust on the cylinder wall. The second item of bad news was that rudder was shot. The boat shop said it looked like the boat had been grounded. I had to remove and replace the rudder. This involved removing the gas tank (no minor task) and some fiberglass work. It turned out ok, but it cost me more money than I was expecting to spend on that. This also made we wonder about the strut and shaft,but the boat shop said it looked ok. This is the new rudder, but old shaft |
sjpitts
Last summer I also replaced the starter, the t-stat and the fuel filter.
Then I found ski-dim, and bought a distributor kit (cap, rotor, points) and learned how to use a dwell meter. Once I did that, the boat actually ran good for the rest of last summer, although I am not sure if I am getting the top end I should-- the RPM's max out pretty low. But it goes fast enough for me. I think I could really use a carb rebuild. And I am now worried a bit about my cooling system. That will be the next post. Jared |
sjpitts
Yes, you are right there. I learned that searching the archives of CCFan. So I have been putting the trailer in less deep. This makes it easier to get the nose of the boat over the black roller, but it sure makes it hard to crank the boat on the trailer using the hand crank. (I have never got nerve up to power onto the trailer-- plus my wife usually drives the boat to the trailer, and she prefers to turn off the boat before she gets close to the trailer) Jared |
sjpitts
So that brings us up to last week.
I started the boat up for the first time this year on saturday. I immediately had several problems. First, I immediately noticed that it wasn't sucking water up (the strainer was staying empty). I quickley turned off the boat, and after some examination realized that the the drain valve for the tranner cooler wasn't shut, so the pump was sucking air. I was worried about by impeller, but the impeller was very new (replaced late last summer)and it had only been run dry for a few seconds. So I started the boat up again, and this time it sucked up water. However, as it idled the temp started to rise above its normal range. I shut it off when it reached about 195. This made me wonder if I had ruined the impeller (or if it had gone bad sitting over the winter. I then went and replaced the shaft packing with some gore tex stuff I got from ski dim. I was worried that this was going to be hard, but it was really pretty easy. The only question I had was how tight to tighten it. I did it hand tight, but as hand tight as I could get it with one hand. So then I went back to cooling problem. I decided to start the boat up one more time. This time, the boat heated up to 160 degrees and then stopped heating up. It appeared to be cooling just fine. I let it idle for a few minutes while I measured the alternator output and stuff. But then I noticed that there was smoke rising from the big hoses down stream of the exhaust manifold risers. I checked the temp again, and it was at 160 degrees. So I turned off the boat. The risers were cool to the touch, but the big hoses connected to them were very hot -- to the point of smoking. And the whole time the boat was just idling. I don't understand this. I am thinking I will just break down and replace the impeller again (I already have one) and maybe even get a new t-stat from skidim (but I am not sure if I want a 143 degree or a 160 degree t-stat). But I still don't understand how the risers can be cool, and the hoses behind them hot and smoking. Any ideas? Jared PS: Notice it only took five posts and ten pictures before I finally got around to asking a question? Are you sure you want to let a Supra guy in? |
87BFN owner
Were you getting water out of the hoses? If so how much? How long did you let the boat idle, it will take a couple minutes for the cast iron risers to get hot as water is passing through them. The exhaust hoses however will get hot much faster if you don't have enough water moving through them.
sjpitts
There was lots of water coming out the exhaust, if that is what you mean. I am pretty sure the hose was nearly all the way on, although maybe it wasn't. I guess how much water that provides depends on the level of water pressure. Your explanation on why the exhaust hose would heat up before the riser makes sense. So maybe it really is that simple-- maybe I didn't have enough water pressure on. So, when you run an inboard off a fake-a-lake, should you turn the water pressure on full blast? I know with an I/O they said you weren't supposed to. Jared |
tnplicky
Senior Member Joined: December-22-2006 Location: C'trl Illinois Status: Offline Points: 333 |
I personally don't use a fake-a-lake, however I disconnect the hose from the strainer and put the garder hose in and clamp her down. I turn the water on full blast. I've never had any problems in the 1-1/2 yrs I ve had my boat, but there are a lot of more experienced folks here that may have a differing opinion.
On you powering on the trailer comment... the ski boat trailers I am familiar with don't even come with cranks, so powering on is a necessity. The previous owner of my boat added a crank and cable to the trailer, but standard equipment was a only a turn-buckle to keep the boat from coming off once you had it on. Take it slow and easy on the throttle and gently ease the boat up to where it needs to be. |
87BFN owner
sjpitts, why is there dirt, sand and stones on the prop guard of your trailer?
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
Look at his driveway in the early pics. |
Laptom
Newbie Joined: April-19-2007 Location: Netherlands Status: Offline Points: 2 |
I think you've got an air bubble in the system the first try and a low water flow the second time. But the water hose in a bucket and an hose from the waterstrainer. Let the engine pump the water out of the bucket this way. Normally when idling the water hose cannot get sufficient water in the bucket (in my 6 boats experience). When this happens, you know the watersystem is sucking enough water.
I think you're fine, just get enough water in the engine when running on dry land. The pump sucks at 2000rpm easily a 5 gallons bucket empty within seconds. Watch the temp gauge! |
David F
A fake-a-lake and a garden hose works just fine. Do not be afraid to turn the hose on full blast. Any excess water getting past the pump will simply flow out the exhaust. The large rubber exhaust hoses should never get so hot that you cannot keep your hand on it. Otherwise, they will collapse internally and cause restrictions.
If it were me, I would remove the hoses and check them out. Also, it appears the risers have been removed and gooped up with sealant on re-install. It si common that the new gasket is installed incorrectly (backwards). You should remove the risers and check this out as well. The blocked water passage on the gasket should be toward the outlet (rear). Your impellar is probably fine. But, go ahead and check it out since it is a simple task. |
backfoot100
Welcome. As an owner of an American Skier I can vouch for all these guys. Great group so don't be afraid to ask away.
First off, Fake-A-Lake is turned on full blast. Don't rev the engine above 2K RPM though. Also my recommendation is that you replace the impeller when you pull it out of storage for upcoming season instead of when you put it to bed for the winter. The impeller blades could take a "set" after being frozen all winter. I always did that and changed the fuel filter/water seperater in the spring. I agree with others. I think the engine is fine and the issues you're experiencing are just learning experiences being a new inboard owner. I think the impeller was partly to blame the first time (getting the "set" worked out of it) and the second was insufficient water pressure. Good luck and let us know how things work out for you. |
sjpitts
Wow, thanks for helping out with a supra. I think you guys are right, I was just being stingy with the water. I will turn it full blast from now, and be carefull not to run at too high an RPM.
I have never been sure how often an impeller really needs to be replaced. On my old I/O I replaced it every other year. Do most people replace their impellers every year? Every other year? Jared |
sjpitts
If I were to pull the exhaust hoses for a check, would I need to totally remove them? Or just pull off one end? And what exactly would I be looking for? Although I don't really think it is an issue. They were hot, but I could still put my hands on them. Although they did smoke some. Thanks again Jared |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5774 |
If the riser gaskets haven't been replaced as Dave suggests you need to get that done as they appear to be leaking and could be an explanation of the rusty cylinder walls. |
sjpitts
Thanks for the input. As you can tell, I really need the help.
I have wanted to replace the manifolds and risers, but I had hoped they would last a couple more years. Here are some pictures of the manifolds in question. Can you really tell that they need to be replaced? The stains on the side is enough to know? Is there some sort of test? Would I need to replace both the manifold and the risers, or maybe just the risers? I will note that the manifolds with the most stains are not on the side with the low compression. I can link to higher resolution pictures if these are not good enough. Thanks again. Jared |
sjpitts
Wait, just the gaskets? Not the risers themselves? That seems like it might be easy to do. Please tell me more. Thanks Jared |
81nautique
Hard to tell from the pics if the gaskets have ever been replaced but the bolts are still painted and don't look like they've ever been removed. They are certainly leaking on the outside and probably on the inside as well. Gaskets are less than $10 each or you can get a service kit from skidim for about $90. The kit comes with riser gaskts, manifold gaskets, 90 degree fittings, brass drain plugs and all new bolts. Thats just regular main. that needs to be done. |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
If they are leaking on the inside, does that mean water can get into the engine? Do people replace their gaskets if there is no obvious leaking? My 1988 PCM has rust on the manifolds where the riser meets the manifold, but there's no obvious leaking. After 20 years is replacing the gaskets something to consider?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21133 |
Yes, and yes. You dont want water getting back down into the cylinders- its a cheap and easy fix. |
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
I have the riser gaskets from DIM to put on mine. Do I put them on dry or should I use some sort of RTV or gasket sealant?
81nautique
Put em on dry Mark, the new gaskets seal up real good. Make sure you spray the bolts with penetrating oil a day or so before and work them free slowly back and forth. They will snap pretty easily so tread lightly and replace them with new. |
Mark Mel
Thanks Alan, I did plan on soaking them with the pb blaster. Breaking one of those bolts would sure stink.
