  New Posts New Posts RSS Feed - Alignment
Topic ClosedAlignment
 Post Reply Post Reply Page   123 6>
Barracuda View Drop Down
Direct Link To This Post Topic: Alignment
    Posted: April-02-2008 at 10:42am
The Following information was taken from a separate thread by Eric Lavine regarding common transmission failures:
These trannys have 4 basic problems
1. water inside causing complete failure, which is not the case here
2. cracked forward drum, wont cause the problem you have
3. ring gear for reverse plantary comes loose and you completely loose reverse
4. reverse return snap ring land breaks and you get drag in nuetral (most likely if cable is in adjustment)
oil changes will not effect breakage, you really have to watch the forward to reverse shifting on these transmissions, make it a habit to shift into nuetral letting the prop stop and then shift into the other range within the means of being safe, remember the prop is spinning one direction and you nuetral skip and it allows the prop to do a complete 180, i know someone is thinking this is a ski boat and you are suppose to do this....this will add many hours to the transmissions life
this is an example of a cracked forward drum out of a PCM trans, this will be found both in the 1:1 and the 1.23:1, in the 1:1 it can crack from to harsh of a shift or mis-alignment, this is probably the most frequent problem these transmissions have, it can be avoided by making sure the boat is in align and shifting at idle allowing the prop to stop turning and then shifting it into the other range, of course if you hit an object with the prop this also likely will happen to the drum. it basically is the weak link in the transmission.
This is a Borg Warner planetary that was installed into a rebuilt transmission and the customer installed the trans into his boat completely overlooking alignment, i gather the boat would have been out .050 or so and he pulled the coupling halves together with the force of the bolts and never paid attention to the alignment. The transmission case was completely grooved at 12:00 o'clock position. all 6 of the planet gears were rounded as you see in the picture
This drum failed due to water contamination, as you can see the top ring area is broken from pressing the drum out of the case, the hook style ring expands into the groove that wears into the case and then is impossible to remove without breaking, if you notice the bottem ring has clearance on the sides due to the water destroying the lubricating qualities of the oils and causing the rings to sieze in the groove in turn rotating in the case
Direct Link To This Post Posted: April-01-2008 at 4:00pm
Walters Machine company makes a clamp on style and also are real nice, they have a split down the middle and slide easily onto the shaft and then you tighten the clamp bolts, they are available thru TMI out of Florida 800-463-8848
Direct Link To This Post Posted: April-01-2008 at 2:45pm
.0005" interferance can almost be done by hand, and since everything was new you didn't need to do any of the stuff you guys suggest. Just my .02 gained from personel expierence and knowledge.
Direct Link To This Post Posted: April-01-2008 at 2:34pm
Originally posted by 79nautique 79nautique wrote:
.0005" is nothing and if you dig out the drawing's I'm betting there is also that much clearance too built into the tolerance stack-up.
Done correctly they are sold in select fit pairs and there is not enough allowed tolerance for the interferance fit to become either line to line or tight clearance. If yours slides on its too loose.
Direct Link To This Post Posted: April-01-2008 at 2:22pm
well I never did any of that when I replaced the old one with a new, a lite tap with a brass hammer worked fine, as it's really not a press fit like you think, it's a very tight slip fit actually, .0005" is nothing and if you dig out the drawing's I'm betting there is also that much clearance too built into the tolerance stack-up.
Direct Link To This Post Posted: April-01-2008 at 1:19pm
Originally posted by M3Fan M3Fan wrote:
Since the alignment was off quite a bit, you will want to make sure that the prop shaft OD and it's couplings ID hasn't fretted (worn) and is still tight. Keep in mind that this is a press fit and if worn, can't be fixed by just tightening up the set screws. Hopefully the trans will be OK.
How is the coupling pressed onto the shaft? I would imagine on a bench but then how does it get in the boat...
Bag of ice on the shaft and the coupling goes in the oven at 500 degrees. Then it's a mad dash to slide it on with an oven mitt. If you see an imprint of the coupling face burned into my carpet or upholstery, you'll know what happened when I try this in a couple weeks.
Or pull the engine if you don't want carpet burns!!!
M3Fan View Drop Down
Direct Link To This Post Posted: April-01-2008 at 12:57pm
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Direct Link To This Post Posted: April-01-2008 at 12:35pm
HW, i heat the coupling and slide it right on to the end of the shaft, you only get one chance though, its about a .0005 interferance fit,
thats why some guys prefer the double taper shaft because you can install it and tighten the nut and pull the coupling onto the taper, the only thing is the double taper shafts are pricey.
i will fit the coupling first and put the shaft and coupling in the lathe and take a face cut, this puts it dead on, the remove the coupling and re-install
Direct Link To This Post Posted: April-01-2008 at 12:04pm
Direct Link To This Post Posted: April-01-2008 at 10:27am
saffer, if your saying it was out that far, and has probably been for a while it just may be worth pulling the coupling as discussed and also doing a runout check on the shaft, the shaft was under alot of force, how many hours? they say the maintanance life of shaft is 500 hours but lets face it no one changes thier shafts at 500 hours. did you currently feel vibrations when you ran the boat? that may have been shaft whip and over time will degrade the shaft. also spin the output of the trans and feel for any roughness, when the alignment is this far out it loads the rear bearing and cocks the planetary, hopefully you wont find damage cause your far far away, you may have caught it in time, the worse case of mis-alignment i seen and i sent the guy a replacement trans before i got his back was the 6 planet gears were missing every single tooth and the case was wore about an 1/8', all the bushings were spun and it was a mess and it still sits on my shelf today the way i got it back, the trans is useless but acts as a good show piece to show damage, i will snap a shot of it one of these days
Direct Link To This Post Posted: April-01-2008 at 9:18am
Originally posted by saffer saffer wrote:
At last i have seperated the coupling.
She is way off!! about 1cm to port!!
You refere a lot to "propping up the shaft", what is your point of referance?
Also, is there a bearing in the stuffing box, if not i assume that goes where the shaft goes eh?
Thanks
The reference to propping up the shaft is to take the weight of the foreward end off it to keep it from dropping down. You can use a wood "V" block clamped in a way that you can adjust it. I recommend taking any side loading of the stuffing box off by removing the small section of rubber hose and moving it slightly forward. What you want to try to do, is see how concentric the shaft is to the bore in the rubber cutlass bearing/strut. This will be by feeling how easy the shaft rotates. The easier it turns, the better. When you get the shaft to that point, you will then align the engine to it. Side to side and up and down is a visual to make sure the shaft doesn't move when you put the coupling halves together.
A lazer sure would be nice but I don't know of a set up that would work. They are used on shafts but not in such a confined space.
There isn't a bearing in the shaft log/stuffing box. Once you slide the stuffing box forward you will see.
saffer View Drop Down
Direct Link To This Post Posted: April-01-2008 at 8:23am
How can i be sure that the "new" alignment is right? how can i centre the shaft without lazer or trying to look up the shaft via the prop view?? You refere a lot to "propping up the shaft", what is your point of referance?
Feels great to see i have made some progress.Also, is there a bearing in the stuffing box, if not i assume that goes where the shaft goes eh?
Thanks
Direct Link To This Post Posted: March-31-2008 at 11:48pm
well if your not skilled enough to ring the taper then torque it down some more off centered so that you interduce a side load, but then maybe you don't understand simply physics and force diagrams. And I all so guess they are not smart enough to know how to position the wrench so that the prop doesn't spin either, so if your too damn dumb to know either of those then by all means screw it up with the impact.
Direct Link To This Post Posted: March-31-2008 at 10:41pm
were not talking about airplane props here,
the impact's hammering action will remove the prop, with one inch shafts you will see guy's putting blocks of wood between the hull and the prop trying with all they have to get the prop off, a pipe wrench on thre shaft is anpther good one and these are the things that they shouldnt be doing. Most boats including the ones with 1 inch shafts will come off easily....its the ones that have been on there for a few years that have never been off that you hit with an impact, im not one to stand around and ponder, i got a job to do and the impact falls within those guidelines when i cant get a prop off
Direct Link To This Post Posted: March-31-2008 at 2:20pm
sounds like you hired the wrong guy for the job to start out with, but regardless last time I checked all of these boats use 1" shafts and you don't have to use a raft. Guess your just trying to confuss them by bring up BS that isn't related to the job at hand.
Direct Link To This Post Posted: March-31-2008 at 2:10pm
when your paying some 20.00 and hour to do a 10 minute job and he's wondering around you tell him to hit it with an impact, that is a last ditch effort when all else fails, you would understand and no i dont use screwdrivers as chisels, if my old boss ever seen me hit one of his pullers with an impact he would of fired me on the spot and that was embedded in my brain for years. when your hanging under a swinging boat on a 4x4 raft you hit it with an impact or you are going swimming when it lets loose. do i condone it no, is it necessary sometimes yes
Direct Link To This Post Posted: March-31-2008 at 12:52pm
it's simple physics, and if you are not appling the force along the axis, then you are not going to do anything. And really why are you comparing something completely different, let's just say what ever, so they tear it up and make unusable tring to remove it. The puller is all ready flexed, it's not inline, and if your dumb enough to throw an impact on it too, then I guess you deserve it. Dad had a saying junk like that,, hammer and chissle mechanic that doesn't know his rear from a hole in the ground.
Direct Link To This Post Posted: March-31-2008 at 10:30am
79 sometimes you gotta do what you gotta do, my statement was made because at times on a 2 1/2 shaft you need an impact, plus i make my own pullers and if i break them no one can yell at me
Direct Link To This Post Posted: March-31-2008 at 9:28am
Originally posted by eric lavine eric lavine wrote:
Pete, thats the first time ive ever seen you use the f-word, did you skip breakfast?
Eric, I must say that you are very observant! You are correct that I don't use the F word very offen even in normal discussions. I wanted to emphasize that sometimes it takes some force to split the coupling halves apart. No, I did have breakfast!!
Direct Link To This Post Posted: March-31-2008 at 1:19am
over torqued is over torqued, doesn't matter if you use a 1/2 impact or a 3/8 impact if it not inline and torqued at an angle you are not doing any thing but bending stuff, like the shaft, using an impact wrench on a puller of any kind? why? dumb?, guess if you want to tear stuff up go a head, but it a feel thing, not a brute force think, but I'm a poor mechanic and don't make my living that way, but... each there own.
baumanmt View Drop Down
Direct Link To This Post Posted: March-30-2008 at 10:21pm
With a bit more heat, and a very lite tap of the hard rubber hammer it popped right off.   Thanks guys
gb842001
Direct Link To This Post Posted: March-30-2008 at 10:08pm
I'd be some po'd if I damaged my prop with one of those c puller after paying $70 for it. Good to know for future reference.
Direct Link To This Post Posted: March-30-2008 at 12:57pm
Thanks guys, we got 15 inches of snow so i'm going skiing, i will try again when I get back!
gb842001
Direct Link To This Post Posted: March-30-2008 at 12:40pm
Saffer, i think you are trying to gently, try a very rigid putty knife, you have to get this apart to check the alignment,
i know exactly what you are trying to do cause I'll watch my guy's for humor trying what you are trying and then I'll hop on the boat and give it a good whack and pop it, dont be afraid to hit it...dont use a sledge either...
Direct Link To This Post Posted: March-30-2008 at 12:36pm
Pete, thats the first time ive ever seen you use the f-word, did you skip breakfast? with the c-style i will even nail it with a half inch impact, heat the prop with a mapp gas torch and sometimes whack it with a b-----fin hammer.
the c-type is good for the diy guy but is not for everyday use, one of these days im going to make a batch of these pullers or have a machine shop make them....i will in the near future post a picture and if 10 or so guy's wanted one i could take it over and see what he could make them for.
or if someone on the site wants to make a joint venture project you can include me, i could do alot of the machining
Direct Link To This Post Posted: March-30-2008 at 11:51am
Originally posted by Riley Riley wrote:
Pete, I have a puller just like the one in the photo. It is made by Acme. The instructions say it is not designed to release the prop by cranking down on the nut. It says to get it tight and then give it a hit with a hammer. The shock is supposed to release it, not the pressure from the clamp.
Absolutely correct and the point I'm trying to make. With a "C" type pulling on one side, it will start to stretch open and then not pull equally around the hub. Now you need to finish it off with the hammer!! Eric, like myself uses a puller that will pull on all sides and I know he appreciates it. He uses one a lot more than I do!!! They do take longer to put on especially the one I made because you need to thread 3 or 4 bolts into the C holed plate behind the prop. I really don't know why the prop guys continue to sell the C types and what I consider to be a poor design. Maybe they are counting on more prop repairs from the damage they cause!
I'd like to mention again the prop taper compared to the taper in the quill of a drill press that holds ether a drill chuck or drill bit. It's not uncommon for me to find someone trying to remove ether with a block of wood and just wailing on it with a BFH just because they couldn't find the drift. I'll find the drift and with a slight tap the taper pops because the force is a equal pull or in this case, a push.
Direct Link To This Post Posted: March-30-2008 at 11:24am
Pete, I have a puller just like the one in the photo. It is made by Acme. The instructions say it is not designed to release the prop by cranking down on the nut. It says to get it tight and then give it a hit withm a hammer. The shock is supposed to release it, not the pressure from the clamp.
BuffaloBFN View Drop Down
Direct Link To This Post Posted: March-30-2008 at 11:21am
Yessir!
1988 BFN-sold
Direct Link To This Post Posted: March-30-2008 at 11:19am
Originally posted by BuffaloBFN BuffaloBFN wrote:
I see the space you mean, but how about the other side of the same nut?
I see space on both sides Greg. You only need to pull it maybe .010 to .020 to free it up off the taper.
Direct Link To This Post Posted: March-30-2008 at 11:14am
Greg Buffalo, Keeping the prop nut loosely (look close-there is space between it and the prop)on the shaft is actually the preferred method. When the taper lets loose, it keeps the prop from flying off and hitting the floor.
I remember reading about that...and I remember 1 time I wish I'd known about it! I see the space you mean, but how about the other side of the same nut?
I have the same puller, but it fits on my set-up dead in line with the shaft. His may be bent just a hair? The first couple of times I used it, the prop came off like a gun shot. Since then my prop has been to Delta and I lapped it on as I learned here. Now it comes off with an solid pop but with much less effort and my neighbors don't come running out to see what I've done to myself?!!?
1988 BFN-sold
