RWP |
Duane in Indy
Posted: January-04-2017 at 7:43pm |
This thread may bit a bit long but hey, it's winter here and not much else to read.
While doing a normal RR on a rwp I noticed the housing was cracked. It broke completely when I was taking it apart. Having the proper equipment and raw stock on hand I decided to make a new housing. Following are pics of the re manufacture process. This is the broken housing Stock in lathe Hole being drilled and outside shape being cut On the mill now and putting in hole pattern and reliefs Finished part ready to assemble |
1978 Mustang (modified) |
Duane in Indy
Shaft assembly installed into the new housing
More of assembled housing Back side Really was not too big of a chore. Turned out good and assembled with all new internals. Hope you enjoyed. Duane |
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 234 |
Nice! And those Sherwood pumps are not inexpensive.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10667 |
Hi Duane
I've been sitting here for half an hour trying to think of something witty to say about this, but "I got nuthin" You're just a magician with metal KenO |
JPASS
Impressive work there Duane |
'92 Correctcraft Ski Nautique
Steve, Things like this happen when you're a retired tool and die maker with the time and the equipment. Cost doesn't factor into the project t! |
Ken, I too am at a loss for anything to say! Duane, Great job! |
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Tool and die work is fading art form. One that I appreciate.
Nicely done sir!!!! |
1999 Ski Nautique 196
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1722 |
Nice work! I very much appreciate people that can and will do projects like this. Keep posting these long posts !
Morfoot
Errrrrrrrrrrrrrrrr.....Ummmmmmmmmmmm......
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2206 |
Very nice
'88 BFN |
JD ski
Senior Member Joined: September-25-2016 Location: North of Tahoe Status: Offline Points: 199 |
Great work and a true improvement over the stock part. It never hurts to have beautiful billet parts in a motor compartment.
JD ski, slicing, dicing, and shredding since 1981
1999 Air Nautique, GT40 Pro Boss, Trail Rite trailer 1975 Century Resorter |
Duane - Thanks for posting pictures of the process. I'm envious over your knowledge & equipment.
What material did you make the part from? 304? |
Duane in Indy
Chris, Did not use 304 which is a S/S grade. This part was machined from a piece aluminum that I had on hand. Undecided whether I will anodize it or not. I have NO plans to ever use the boat in salt water and plan to drain the engine after each outing. I have pet cocks on every drain plug hole. Thanks to you and all others who have complimented me. |
Duane in Indy
Chris, You are so correct about the trade being a fading art. More people should pursue Apprenticeships in the Trades than chasing after "non sale-able" degrees. Affordable college tuition should include affordable trade school tuition. Most trades are very high paying positions. |
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
I can't even get the pulley out of my water pump.
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
Duane in Indy
I know what you mean. I had to chuck mine up in the lathe and cut the hub out of the pulley and then make a new hub with a set screw and weld it back into the pulley. I first put the pulley in my hydraulic press and exerted 12 tons of pressure with heat and had no luck. P**s poor design. |
RVR-BTR
Newbie Joined: December-16-2016 Location: St. Louis Status: Offline Points: 16 |
Duane, I wouldn't worry about anodizing. And Ditto all the glowing praise on the lathe work. Honest work, and a lost art form. |
C.J. In St. Louis
1974 Correct Craft Martinique 18 1967 Chris Craft Commander 27 |
quinner
Keep doing stuff like this Duane and we are going to be forced to kick you out of the back yard hack hobbyist club
Duane in Indy
HaHa, that's been high on my priority list!! Finished up the pump today. As previously stated, I had to bore out the hub on the pulley and install a new one Pulley with new hub installed, now with a set screw. (old system was pressed on) Opposite side of pulley. Finished item ready to be installed on engine. |
flyweed
that looks awesome. I had to put a new pump in when I bought my boat..I know the old Sherwoods aren't cheap.
dochockey
Nice Work !
Can you make the front flag holder (staff) that goes in the light for the early mustangs? |
1989 Teal Ski Nautique
Duane in Indy
Got a sketch or picture.?? Got a lot on my plate now but sounds interesting, especially if they went on Mustangs as late as mine. 1978 |
baitkiller
Very cool. Old guys rock.. "yeah my bearing housing is busted.. no big deal.. I think I have a chunk of 4" billet kicking around.. Ill just chuck that bitch up in the lathe and burn a new one.. See? easy!" It is gonna suck when we die. nobody can fix a flipp'n toaster anymore.
Why fix when you can buy new?
Kidding of course. Nice job! |
LeftFieldEngineering
Senior Member Joined: December-20-2010 Location: Monson, MA Status: Offline Points: 384 |
Vary nice.
phatsat67
That's killer Duane. Making Sherwood engineers look like losers.
Duane in Indy
Thanks so much for everybody's comments. Just took off my Jabsco plastic bodied pump and going to redesign it and reproduce it as it has 2 cracks in it.. Will use it for a backup or let someone else use it. Pictures to follow. Thanks again, Duane |
swilliams
Duane, ScottZ is looking for a plastic bodied Palmer (Thermo-Electron) pump. A pic of it is in the parts wanted section.
