PCM Ford electronic distributor installation instr |
Post Reply | Page <12 |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
sounds good to me WLM wording right and picture wrong
Cheiz
Groupie Joined: September-26-2016 Location: Palmyra VA Status: Offline Points: 47 |
Right hand rotation it is:
I need this starter than http://www.nautiqueparts.com/starterkitrhreverserotation-permanentmagnetforoldercorrectcraftboatspriorto1989.aspx |
93 CC Nautique Excel CB 351 GT40
YES |
Cheiz
Check your private message inbox, I sent you something KenO |
desertskier
Per the following you need a CCW starter: ARCO tech tips
Starter PN 70201 is a CCW starter: ARCO Starters The starter on the NP website is an ARCO 70201 and is the correct starter. |
Cheiz
Anyone have pictures of the coil/resistor location mounts from the electronic ignition kit as well as the bracket that goes towards the back where the 50 amp breaker is?
Thanks |
Lots of pictures here already, try a google search "coil mount site:correctcraftfan.com/forum" |
That's way too much typing for us old simple minded guys that don't particularly like typing to begin with Hollywood correctcraftfan coil mount in a Google search gets the same results without quotes or slashes or any of that stuff. |
Cheiz
Thanks all for the help and guidance. I got the boat turned over and winterized it (boo!).
Attached are the actual instructions for the kit from PCM for future reference. However, I did run into a wire that I need to connect up. It is near the Vdrive area and the light blue wire goes towards the interior dash and I am trying to find out where this red wire goes to, any thoughts? Where does the red wire go from this picture? |
desertskier
That is the neutral safety switch. One wire goes to the key switch and one goes to the starter relay.
Chris,
I don't feel that's your NSS. The NSS would be on the trans and not the Walters V drive. Someone will be along who knows more about the Walters but I'd say it's the pressure sender for the Walters. The light blue up to the dash would be to the warning light and the red would be the "hot" + to the switch. |
I get dizzy looking at the picture, but like Pete said, low oil pressure warning light on the dash gets fed from that switch if I'm looking at the picture right
Here's a link to the v drive manual Walters v drive manual Unfortunately the page with the wiring diagram doesn't seem to be there |
Cheiz
Thanks Walters V Drive Page 16
Assume that the light blue to the dash and red to ground? |
Good job, where'd you find page 16?
Red to ground doesn't seem to pass the "sanity check" though. |
Chris, Check to see if the indicator light is wired to ground or +. Just because you found a wiring diagram in the Walter manual, doesn't mean the light was wired that way by CC. |
GMacLaren
Senior Member Joined: August-22-2013 Location: St. Louis, MO Status: Offline Points: 495 |
Seems this thread has strayed a bit from its subject.
If still looking for dizzy info, it's possible this might contain some useful info: http://www.grantmaclaren.com/72skier/engine4/index.html -=Grant=- |
Grant, Please review the complete thread. Thanks. |
Cheiz
Thanks all.
I'll do a check this holiday to determine the mystery wires lol. Page 16 comes directly from Warner, I contacted them and they shot it over to me. |
