Mechanical fuel pump |
Tomj72mus
Newbie Joined: July-14-2016 Location: Edmond Oklahoma Status: Offline Points: 11 |
Posted: July-15-2016 at 4:36am |
I believe mine is going out or has lost some psi. I'm concernd with weather or not I should replace it with a filter style or a non filter style. The fuel tank is original and prolly isn't the cleanest thing inside so I'm debating. Have any of you with an older cc switched to a filter less model and if you have how did it work out?
DayTony
I would not go completely filter-less if that is what you are asking.
There is no gain in having a filter on the pump vs an inline filter. either style will work as its designed. you can also rebuild them. personally i think an inline filter gives you better options. A. something like this RAYCOR is about the best you can get for fuel filter/water separator quality. B.Easier to get at depending where you mount. C.has built in drain to drain off any water in the system. Even if your running the filtered pump the raycor is a good idea for any boat's fuel system. Make sure its not the clear plastic bowl style, those are built for above deck installation. below deck, uscg requires the metal bowl. |
1988 Barefoot nautique-454
Tomj72mus
It looks like that would work perfect. Thanks!
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
I would advise to keep the in-line filter if you have one. Also, depending on how much time you wanna spend, take the tank out, and slosh it around with some gas in there and tip it up on an angle and then siphon it out. Also, it's good to inspect the vent hose and filler hose if you have never seen it.
74SkiNautique
Tomj72mus
I did this just today, I pulled the tank and tilted it to one end to suck out all the junk. It really wasn't as dirty as I thought it was going to be. Also I found a new mechanical fuel pump with the filter on it for $44 that I just installed this evening. It works great and my motor seems to idle a lot better now as well. Thanks for the info fellas!
rolleronariver
Senior Member Joined: May-24-2016 Location: Rogers, AR Status: Offline Points: 195 |
If you don't mind me asking, where did you find the pump at for that price. I need to replace the one on my 92 sport nautique.
92 Sport nautique
Tomj72mus
Advanced auto parts! Napa Auto has them as well.
Tom, Is the pump marine rated? Do you have the part number? |
Tomj72mus
Pete,
First off how's it going? I haven't been on here for awhile hopefully you remember me. To answer your question no it is not, reason being is because the carter pump I pulled off of it wasn't either! The new pump is a Airtex 4990 and is almost an exact replica from the carter it's just alittle taller. |
Joby1969
Senior Member Joined: July-06-2015 Location: Conway Status: Offline Points: 160 |
arent the only difference on the pumps the little bypass nipple in case of diaphragm failure.i replaced mine with one from a box store like advanced and removes the nipple out of the old stock one.I then put it in the new pump.it had the option via a little knock out area to install the nipple tube in it.then attach the hose and its now a marine pump
my 1980 SN is mad at my 2009 HD
Tomj72mus
Thanks for the info Joby! And yes I think you are correct!
Joby1969
Well basically. A marine pump for sure has a seal on the diaphragm push rod in case the diaphragm ruptures. If not there the,overflow fuel will just fill up the crankcase and may also come out the the arm pivot rather than go up the sight tube. When I rebuilt my old '69 pump I added the overflow too, but it did have a seal too. Some pumps in the past had a dual diaphragm and a sight tube or a glass bowl between them to see the overflow if the main diaphragm went bad. |
Joby1969
gary,you are correct.i forgot to mention the seal in the backside.I do remember the old school style with the sight glass as well.......good info added.thanks Gary
He's not totally correct. Besides the nipple to connect the hose back up to the carb incase of a diaphragm leak. the true marine fuel pump is a double diaphragm. BTW, just because the bad pump wasn't marine doesn't mean you have to put another non marine back on the engine. For a few more $$ than the $44, it sure would be safer! |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10687 |
The true marine fuel pump may or may not have 2 diaphragms. AC and Carter would be the 2 most popular mechanical marine fuel pumps. The AC built pump which Pete is thinking of is a dual diaphragm with either a glass bowl to show leakage into the area between the diaphragms or instead of the bowl, later versions run the sight tube up to the spark arrestor. The Carter built pump which Gary is quite familiar with is a single diaphragm pump with the nipple for the sight tube up to the spark arrestor. It is sealed around the operating rod for the diaphragm.up above this nipple. So.........functionally the 2 pumps do the same thing, just differently. I've had both styles apart to see this with my own eyes. |
Not any more Pete, I believe in a Windsor powered boat the only true dual diaphragm pump had the fuel bowl on them. I think it has a diaphragm a spacer then another diaphragm. The glass bowl mounts into that spacer. If the bottom diaphragm leaks it fills the bowl,the second diaphragm keeps it from flowing into the engine or bilge. Since they went with the hose I have never seen 2 diaphragm pump. When I rebuilt my pump it had a seal on the diaphragm rod and one diaphragm,I added a fitting for the overflow when I found that it had the 2nd seal. I bought a new Carter marine pump from Skidim as a spare,it has the same upper housing as my original and one diaphragm. New Carter- Old Carter on HM- If you look you can see just the one diaphragm on both pumps,it's the one under the series of screws,the other protruding one is a gasket |
ken and Gary,
Thanks for filling me in. |
Here's a picture of an AC on the left and a Carter on the right.
The black fitting is where the bowl would screw into on the AC or alternately the tubing to the flame arrestor could go there. I notice on your new Ski Dim spare Gary, that the nipple is on the back. Hooking the tubing to that is a PIA because the oil pressure sensor and the tubing from the nipple want to occupy pretty much the same spot at the same time. Your rebuilt old one is prettier You can still find either style for sale pretty easily. KenO. |
Your right Ken. I was able to remove that fitting and by drilling a new hole relocate it to the front. That was the only pump that had a filter on it similar to my original. The other minor problem is that the inlet and outlets are switched,thought I could change them around but no. All in all not bad for 41 years difference between them.
I see the difference in how their made Ken, same end results just a different way of doing it, the Carter way being cheaper I would guess |
Joby1969
im running the carter if i remember right, it didnt come with the nipple so i took the old nipple and used it in the new carb.I think the spot for nipple was already on the upper side of diaphragm. I have 4 daughters ranging from 5 -30, sometimes i forget and need a little reminder and thats why the woman is here. she keeps reminding me of what i have invested in toys.
Keith78sn
Newbie Joined: July-21-2016 Location: Sc Status: Offline Points: 4 |
Where are you guys finding rebuild parts?
Here's the link Keith. They need the numbers that are on the mounting flange. I don't think you can look it up yourself there seems to be alot of pages,might be easier to email or call them. At the time new screws for the pump halfs were not included in the kit but were available,they help make it look like new. Hope this helps.
Keith78sn
Great thanks a bunch always thought you could not rebuild
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3597 |
Guys the bad news on Mechanical Fuel pumps is that all the major manufacturers quit making them due to very low volume sales. Carter and AC both quit manufacturing and farmed out the mechanicals I believe to Blackstone who makes them for Carter.
I think Airtex may still make some mechanicals and may even supply Carter with some of them. When Fuel Injection and electric pumps took over the market in the mid 1980's the volume of Mechanical pumps fell so low so fast that most manufacturers just exited the manufacturing and one or two now supply everybody. There are some China manufactured pumps coming in also. If I had a good old pump I would consider rebuilding the old one. Maybe some company still offers new diaphragms for them. In the classic car world fuel pump issues are a problem, the original Carter pumps lasted years and years the replacements sometimes don't last long at all unfortunately. |
