  New Posts New Posts RSS Feed - Hours Question
Hours Question
vbatla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Topic: Hours Question
    Posted: September-25-2014 at 9:35pm
Hi, I'm new to the forum and have been looking at 1989 Nautiques. I found one in good shape but has over 2500 hours on it. No major work ever performed on the engine or transmission.
Question: How many hours can the engine/transmission be run before rebuilding is necessary? thanks
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2014 at 9:41pm
Really depends on how well the engine and tranny were cared for. If the owner did regular oil changes and general maintenance you may be fine. It would be worth the money to have a shop look over the boat prior to buying with that many hours on it.
Can you do a basic compression check on the motor? Is the motor clean?
What's the asking price?
It's a buyers market now and there are plenty of older boats out there for not much money.
What's your budget and what model are you looking into, 2001?
'92 Correctcraft Ski Nautique
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2014 at 10:59pm
Thats alot of hours
This is the life
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2014 at 11:28pm
2500 is a lot of hours but engines are like people, some last longer than others. My dad's the original owner of his '75 Ski Nautique w 351 Waukesha, the predecessor if you will to PCM. He's running an honest 2800-3000 hours on both engine and BW velvet drive tranny. The boats always been run hard but never "put away wet." The engines strong and smooth and doesn't leak nor burn oil, compression is good, tranny I can tell is getting tired, no doubt there's a nano second lag when going into gear.
Compression check will show if the engines tired or not. Depending on results, you can tell if it's tired in the heads or the pistons. If the boat looks and feels clean and price is right, I wouldn't turn it away. If it's the original owner chances are in your favor. My recommendation is drive and feel othe Ski Nautiques to compare it to. The engines IMO seem to outlast the transmissions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 3:31am
Thanks for the responses.
I'm looking for a 1989 Nautique 2001.
The boat mentioned above is still owned by the original owner who claims all oil changes and maintenance were performed as recommended. Was used for slalom skiing only. No party outings.
Seems honest, the boat looks well maintained and clean. It's priced in the 9500 area. That's at the top of my range. I'll look into getting the compression checked. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 7:32am
But at $9500 I'd walk on down to the next Nautique.
RobertV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobertV Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 7:47am
I agree $9500 is very high. Not sure where you are, but here in the States for that kind of money you can get a 94 or later with under half that many hours. 93 and earlier had wooden stringers that were prone to rot. Give us some more details on where you are and what you want to do with the boat. The members here are fantastic and are extremely helpful. If you are in the US check out the most recent posts on the thread "Interesting Craigslists Finds"
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 7:48am
Originally posted by RobertV RobertV wrote:
I agree $9500 is very high. Not sure where you are, but here in the States for that kind of money you can get a 94 or later with under half that many hours. 93 and earlier had wooden stringers that were prone to rot. Give us some more details on where you are and what you want to do with the boat. The members here are fantastic and are extremely helpful. If you are in the US check out the most recent posts on the thread "Craigslists Finds"
92 and earlier
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobertV Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 7:51am
92 and earlier
Sorry too early in the morning. Thanks for the correction!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 8:05am
At $9500 I'd keep looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 11:31am
At $9,500 it better be very nice, and you better want that year/color boat. Clearly you can get get a newer boat for less money, but that's not necessarily the point.
I doubt the owner wants you taking all his spark plugs out so just go drive the damn thing and get a feel for how it's performing. Hopefully you've driven a few other ski boats before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 2:05pm
Yeah, I was thinking 9500 is pretty steep.
I'm looking for something small, easy to move, that puts out a good wake without having to use ballast. 99% of the time my girlfriend and I will be using the boat for wakeboarding.   Not looking for a giant party boat. Looking to take out 2 - 4 people at most. Would like to stay around the 5k range. I've read the wake on post 1989 Nautiques isn't as good as the 2001's until the mid 90's sport. Is that correct?
Thanks again for your input. I'm in the US and will checkout "Interesting Craigslists Finds" .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 2:16pm
A "2001" wakeboarding wake is better than any newer Ski Nautique.
Pics of the girlfriend!
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 2:50pm
did you ever say where you were located? I've got a line on an 88 (same hull) in ohio for 6K. I don't know the total history of the boat, but I can get you in touch with the guy.
bring the ruckus
2000 Pro Air
td_in_nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2014 at 3:01pm
Really should be able to pick up a clean SN 2001 with a deluxe interior for under 7k. As suggested by others, just add yourself watch list of the "interesting craigslist finds" topic so that you will get email notifications when something new is posted. You can do that by selecting topic options in the upper right of the topic and a drop down will appear then click on "watch this topic". If you are not in a rush you will pick up a good deal. I have found that prices are not that low now, but come December and January you can get a great deal.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 12:30am
I may be interested in that 2001 boat located in Ohio if vbatla doesn't want it . Any more info ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 2:38am
9500!? for a 2500 hour boat...no friggin way. Original owner does not want to sell obviously.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 2:22pm
I may have found a good deal on a 1984. I was wanting the 89 but I don't know if I can pass this one up. Is the hull the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2014 at 2:27pm
Yeah same hull, different deck. I actually prefer the 84 over 89 plus you get dual exhaust with 84.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2014 at 4:18am
I bought an 89. :) Now the project begins...is there a section in the forum with a basic checklist for someone new to boats? Recommended maintenance? First thing I need to do is change the oil. Is there a particular brand that should be run?   I need to check the impeller along with installing a bilge pump.
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2014 at 8:23am
Congratulations on your new boat.
Any high zinc oil is good pick one and stay with it.
I use Shell Rotella 15/40 diesel
Change the oil every 50ish hrs. and at the end of the season.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2014 at 10:36am
Vince - Since it is new to you, I suggest taking the time to check alignment of the prop shaft.
Here is a how to: video
cbdenco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbdenco Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2014 at 11:14am
Congratulations and welcome! I ended up going with Mobil 1 high milage on the oil front. This article was informative on the ZDDP topic.
ZDDP and Older Automobile Engines
Also, here is Mobil 1's product guide for comparison info
Mobil 1 Product Guide
When you get a chance post pics please
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2014 at 4:59pm
Thanks for the recommendations! I will definitely check out the drive shaft alignment. I will check out Mobil 1. Is there a particular bilge pump I need to use? I like the idea of an automatic pump.
pics coming soon!
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2014 at 1:05pm
Is this an acceptable bilge pump for the Nautique?
http://store.waterpumpsupply.com/rupuau12vodc1.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2014 at 1:30pm
I'd step up to at least 800. 500 takes a while to pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2014 at 2:03pm
Would you go with a Rule pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2014 at 9:35pm
New development...When turning the ignition key to the on position, nothing happens. When attempting to start the engine there appears to be a direct short. Is there a wiring diagram anywhere online?   Looks like the previous owner had a direct line from the battery to the ignition switch. Time to dive into the wiring. Does the 89 Ski Nautique have any fuses? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2014 at 9:44pm
I don't know if Rule is the best but certainly most popular. I usually stick with same pump as I'm replacing to avoid drilling new holes.
Direct short? Can you give more details. There are numerous diagrams on here, maybe in the reference section or FAQ page, I'm not sure. Try googling correct craft fan wiring diagram.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2014 at 10:08pm
Maybe it's just that the battery has a bad connection or dead.
