UKs 78 SN |
Post Reply | Page 123 8> |
uk1979
Posted: May-14-2009 at 8:36pm |
Odds bits I made
Lets have a go
pretty sweet work there roger.. top drawer..
BuffaloBFN
That looks well thought out. Would you tell us some of the details?
I gotta hang out in your shop someday!!! |
Roger,
I sure like the idea of using the resin/glass. No problems with it bonding off at bulkheads like you may have with PVC or other tubing. Just more work!! You sure are the pro with the vacuum bagging!! |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5771 |
Did you built the tubes? what did you use for a core?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21126 |
That is so cool. Wish you werent in the UK... Id ask you to make me some!
uk1979
Hi Guys thanks for your kind words but none of you warned me about getting hooked on playing with Epoxy & Glass, here are some shots on how I made it.
Have looked around over here as Pete said for Epoxy supplies the West System is good but when you have a Epoxy habit the cost is to high found this one which has many types for different applications even one to make fuel tanks and a Epoxy foam for structural work, the cost is now 50% less now I buy it in a 43Kg drum kit. Sicomin Epoxy For tubes used Foam edge protectors we use on tops with wood inside if you need a bend just put bits in and then just staple plastic pallet banding along the sides loop round one end and staple down the other side leaving long tail at on end,so when dry you can rap around a stick and pull out. When you fit the foam together over the wood you can make the bend and hold by the odd strip of masking tape then wrap the hole thing in Cling Film /Pallet wrap. As for matting I used 4 axel cloth just in 2 strips each side well wet it will give and shape if you work it around the bend and wrap again with Pallet wrap tight,when all wrapped up you can smooth out a crease with you hands. Make it longer than you need and cut to size,then set up in the boat on blocks and glass a web across to hold together when dry take out and build off it for main ducked,I went for 6inch flex as we have that here. When I had the basic shape right then cut the hole out on the main clean up and add more layers to ouside around joint and 6inch pipe. Thinking about the foam I think you could use the type used on pipes will be trying that out. Thanks again guys Roger. Please be careful with this info you may get hooked think I have it bad |
Lets have a go
uk1979
Used some pipe foam and it did work out.
Used an off cut of armored cable inside which helps hold in shape and if you twist the foam it makes a bend then tape. As for pulling out fixed a washer to the end of cable and held in vice to pull out. |
Lets have a go
uk1979
Hi Guys well had a go at making ballast tanks for each side here is how I did it.
Lets have a go
uk1979
Can not load more pictures will try later, should be filling up this week who can guess the weight of them 2200mm long.
Lets have a go
Kristof
Roger, that's just plain marvelous!!!
I think I'll have to make a quick trip to the UK soon to see that art work in person... Don't just cover her up yet... You can teach me a thing or two. I can even take two days off at work and come by after you finished work and drive back the next morning... (Can you tell I really really wanna see this craftmanship up close?? LOL). Shoot me a mail: kristof.erens@skynet.be |
kapla
that thing looks wicked!!! to bad we are crossing by..I´d really would have love to see your work personally!!!
uk1979
Thanks Kris but my stuff is small beer to you,as all who serve for us to be free gets my vote.
Seb I'm sure we will meet soon and keep your post coming great stuff. Here are some more pictures. |
Lets have a go
Kristof
Just talked to my Chief... No problem in getting two days off to come see this little marvel (showed him the pics ).
Wouldn't be a problem to come look at it. Got anything to do thursday evening...? Give me a call: +32476/259.477 |
BuffaloBFN
Didn't I ask first? |
Kristof
Yes you did Greg, but it's just a little more than 6 hours from my home...
BuffaloBFN
If I could get Pete to tell me how to change my raw water pump to a sea water pump, I could get there in 5.5...
Too bad my concord is in the shop. |
uk1979
Kris will be great to meet up just give me a few months to finish off some other parts I have on the go, and it will give me a push to finish off the house rebuild, have already thought of my CCF friends around the world and now have a built in coffee machine to fit so all you need to bring is the beans you like and show me how to work it.
I'm working on a bank job at the moment so time is tight (yes I know you like driving but I'm ok for a driver as its not that type of job) but sure we meet soon a share a few beer's or ales. I take it the number you post just need the country code added first. Greg just lean up the mixture and the chevy power should do the 4k on a tank. |
Lets have a go
Kristof
I don't know if your phone works with the "+", but if it does, that's the complete number to reach me from anywhere. (Country code for Belgium is either 0032 or +32) |
uk1979
Have them full of water and on test
Also go the weights done Tank 1 Tank 2 Now on Tank 3 under the back seat. |
Lets have a go
BuffaloBFN
Which side are you going to put the heavy one on?
Just kidding; that's amazing that your weights are so close! |
kapla
little piece of engineering!!!
uk1979
Greg and Seb I could spin a load of BS that it was all worked out but the truth is I just went for it to see if I could do it had no idea of what weight it would come out to shame the extra 2 lb is on the drivers side, still if I use speedo's instead of board shorts may balance it up.
Lets have a go
Kristof
nautiless
Senior Member Joined: June-30-2008 Location: South Africa Status: Offline Points: 186 |
Roger:
Fancy work. Most impressed...... |
uk1979
Nautiless thanks, you will have no problem with your stringer job had the tanks full all over the weekend until Monday and not a drip to be seen, did think I would have the odd one but all clear just shows how good the epoxy is.
Oh and thanks for letting us win one game |
Lets have a go
kapla
thraed jack..
nauti..so u like soccer? how about me going there to the world cup? got place? LOL |
nautiless
No prob Roger. The Lion's forwards had us worked out last weekend.
nautiless
Kap:
I enjoy both football and rugby. We're really jacking up for World Cup. Our city is a host city so pop in if you like. I got space.....you're welcome. |
kapla
not sure as I will be left with the pockets empty after my euro trip and boat TLC!!!
