Another Speedometer Question |
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
Posted: October-20-2008 at 7:45pm |
I have an 87 SN and this weekend I did the speedometer glass cover. They look great, post pictures later. Now, I cleaned the pitot and blew air from the front to the back. To test I tried to blow them with the mouth and nothing seem to move. I started blowing compress air slowly and it was until I give it a full blow that the move but only to 25mph. I took the boat to the lake and I confirmed that they are not working. Any ideas or help? Sounds like I may have to replace them. If I open the can they be fixed?
Thanks |
Brady
Senior Member Joined: June-28-2008 Location: Lake Elmo, Mn. Status: Offline Points: 226 |
Anthony,
See the above post by Tellarico, he had his rebuilt. |
Charlie
Three Lakes, Wisconsin 69 Barracuda |
Anthony,
Do the compressed air test again but directly to the gauge. Slowly bring up the PSI just like you did and listen for air leaking - you shouldn't have air leaking internally in the spedo. This will tell you if it is a gauge issue or if the pitot tube/dampener is leaking or blocked. |
anthonylizardi
If I have an internal leak in the speedo, does anybody know if that can be fixed.
Anthony,
I see you did find Tellarico'd post on his speedo restoration. We'll see if he comes back with the name of who did them. There are a couple other threads on firms that rebuilt them as well. The internal leaks are silver soldered. If you don't want to try it yourself, I would remove the internals and take it it a jeweler. It may cost a couple bucks but they are one of the trades that are very good at silver soldering. |
anthonylizardi
Pete thank for the information. BTW, I finally finished my school and started working on the boat. I will post my progress but owe a lot to you and other for helping me with the shaft and other things. The boat felt great and WOT was 44mph. I have some issues like over heating and backfires when I nail from idle but somebody has an idea to check the pump linkage and set the timing to 10 BTDC. Amazing what this website can do.
Tellarico
Senior Member Joined: June-17-2008 Location: United States Status: Offline Points: 118 |
I finally answered the other post.www.classicboatworks.com can fix your speedo. One of mine would fill up with water which I think indicates that the diaphram was broken.
anthonylizardi
Tellarico,
I saw your answer, thanks! I will check with them. If I decide not to do it myself. |
