NEWS FLASH, PINKS AT LAKE GEORGE |
Post Reply | Page <1 23456 8> |
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7949 |
Man, with all this hype, it's going to look pretty bad if that 409 doesn't dominate everything, and especially if Godfather begs off on lining up with someone.
so your going to flash the Prom in the computer for extra pony's nice? or just replacing the ECU all together with a re-mapped unit? You do get all the goodies don't you?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21124 |
Id be curious to know exactly what he would change. I bet removing the rev limiter is one of the things he'll do, though. I know my uncle will bump up against it in his '04 196 (ZR6). I think its set close to 5400RPM. |
rev limiter, advance profile, fuel pressure, injector pulse width, sensor limits, lots of things to change and get power from, the rev limiter is the last thing to change if at all. Stick with the simple stuff your better off there than the fancy motors that require a computer to operate. Easy to get a 50 more pony's if you have the equipement and know how.
For all-around power, yes. For top speed, no- assuming he's not repropping. If a 375hp 196 can hit the limiter, then the 409 should be as well. Those other tweaks will equal more power, so the limiter will have to disappear if they want to push more revs. |
If you are going to run for a couple miles then you might need a few more R's for the top end but then you risk blowing it up too.
But if it only takes say 100 ft to get to your top speed and it takes every one else 300 ft to get to there top speed who wins in a quarter mile race? The one that doesn't have to change the rev limit because he's opened up a huge lead after 100 ft and extends that lead even more over the next 200 ft while your pig is still trying to get to max RPM to pass it which, it's not going to do very fast, if it's only a couple of MPH faster to start with, so really changing the rev limit is the last thing to worry about. |
If these boxes are needed to get decent performance out of a 6.0, will Correct Craft offer them as an option?
the boxes are all ready on the motor from the factory, I'm guessing that it is a tweeked version of the stock black box ECU/computer that controls all of the engine's functions, rpm, timing, idle air control, all sensors and so fourth and I doubt What Dave has will be availible for any engine but the CCF boat. |
reidp
I believe the rev limiter on the 409 might be as high as 5700 as that's what the specs show the horsepower at. I saw this on the PCM site I believe.
I just bought me a rev limiter for my new engine and after a few test runs with the new 12x17 prop, I conservatively set it at 6400. Jack Roush was with me at the time and he thought that was a little low, until I told him who/what the competition was. He then suggested I drop it even further, stating that he saw no apparent cause to run the engine any harder than need be. |
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
God..It's getting deep in here!
boat dr
Reidp,Eric says he can ship the prop Friday.Set up time of 2.5 hours and 4 hours on the CNC will produce the props you asked for. He has two blanks in stock,with that said you will be covered .
Tell Jack Roush the BS stops at the prop, lets see who has the white flag raised Sat.............Boat dr |
The Godfather
Platinum Member Joined: August-13-2008 Location: Orlando Fla Status: Offline Points: 1766 |
79nautique, I like the way you think and comments. Now if everyone esle would go back to school, they might have a chance BUT it will be to late..
The Godfather
Wow, that's great news Doc. Man I still smell smoke in here. Oh that's Reidp wallet burning!!
Maybe I'll start calling him SugarDaddy, the way he gives his money out. To one off prop's and what esle this crazy man trying to do. He must have been on a losing team back in childhood. |
Dave you have to be carefull it's hard telling what Reid has stashed in that barn of his maybe he's going to bring that skiff but then that's not right, CC's only right?
The limit on R's is directly perportional to the precision and degree of balance of the complete crank assembly. The closser to zero the higher RPM and last time I check most stock production motors are not balanced so pushing over 6K is risky especially with a fresh motor that is not completetly seated but lets crank up the Rev limit anyway. Don't think so Tim, does the future owner really deserve an abused motor over bragging rights? doesn't seem to bright to me. |
Eric was seriously balking about committing to having my 13.5 x 17 done by the reunion gotta call him today to get him more solid, if that reidp guy jumps in line I am gonna pitch a fit I mean he cant buy more than 5 to 10x as many props as me right.. |
boat dr
Joe,Getting Eric to tool up for a 2 blade 19" and a 21" was the trick. Reid ain't the one with the stroke at Johnson Propeller.I have had a dealer number there for several years.
Once again it is who you know, that makes things happen.If you wonder why I push OJ and knock Acme this is the reason.Acme seems to to think that they are doing me a favor by selling me props of answering questions. Eric and Sue have always jumped thru hoops for my customers,fast turn around on repairs and special orders they do with ease, the impossible takes a little longer....................Boat dr |
The Godfather
Now something smells fishy here. Why would Reidp need this GOLDEN CHILD PROP.
If I do my math right, the BLACK BOX would still win!! |
I don't get why a supposed HOT PCM 409 needs a special aftermarket black box. Why don't they just dial it in right to begin with?
Its just speculation, but one nice feature of the 409 is that it only requires 87 octane. Perhaps one of the possible "tunes" that Dave can alter would advance the timing a bit to take advantage of some higher octane fuel? |
It is dialed in, engines tuned to absolute max performace probably wouldn't last very long. |
Well then it ought to be pretty interesting if The Godfather has to dial it up to #10 and run it WFO. |
quinner
Not unlike a car/truck, dialed in for everyday use would be based on maximum efficiency and dependability, performance not necessarily being the top of the list. Would liken it to re-programming the chip in your daily driver. |
all manufactures are very conservative when setting limits on engines and this is so they last longer and the owners have years of enjoyment with out any warrenty issues related to the motor. If you look in some of the old stuff in the ref section there where engine options availible that had no warrenty on the motor because of the limit being pushed.
Hell you never know he might have a larger mettering plate and bigger injectors to throw in too, then throw in the ECU changes watch out don't get hit by the spray when it blast off. |
87BFN owner
Wow I have been away from the site way to long.. You guys make me want to take the AWOL and be there for this wold event.
I kind of remember Reid saying in GL,that his goes to 11 |
MaddMarxx
I wonder if that boat will preform as good as one of those Corvette boats that had the 383-callaway motor in it, and ran in the upper 60s, keep in mined Reids Classic is about his 3rd or 4th fastest boat he has in his stable, you better hope he dont pull his baby blue mustang up there or Marshlls boat!
boat dr
MM , there are rumors as to what weapon Reid
will be armed with. Dave has opened a can of worms here. How many HP doe's it take to swing a 19" prop 6400 rpm's Hope he can back up the "TELL" with some "SHOW". But then again he has not said what boat "THE GODFATHER" will be towing. Could there be a secret that only PCM/CorrectCraft know about? This could be a Bait & Switch on Daves part.Who knows what CC has stashed in the R&D department , wanna give us a hint Dave..... <<< I am gonna put my money on The Reid Man>>> |
The Godfather
Ok Doc, everyone know's you don't go to a party with out a present!!
That's all I can say for now, so dry off and jump back in your hole you dirty little rabbit. |
jbear
Wow James I gotta agree...this is shaping up to be a "don't miss" event.
I would be there, even if I hadta walk, execpt for the fact that we will be in Ohio for the 50th of the West Shore Water Ski Club. Now that willbe some party with my brother and all my ski club buds. But I will be there with you guys in spirit. Better be taking lots of pics and video. john |
The Godfather
9 day's left to sweet talk your way to Lake George .
I'm shock here, that no one has asked if the 409 comes with DUALS !! Oh that's right you saw the video from Ken test driving it before the install. Now is this statement true or not. But it sure does make you think about it.. Man you is this guy. |
