  New Posts New Posts RSS Feed - 83  New Stringers & Floor
 Post Reply Post Reply Page    <1 6789>
jterr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 9:14pm
Not sure what is going on but now I can't send a pic from mail, so I'll post it here
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 9:49pm
Are there supposed to be a thousand words or so to go with the picture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 9:52pm
[QUOTE=KENO] Are there supposed to be a thousand words or so to go with the picture?
[QUOTE=jterr] Not sure what is going on but now I can't send a pic from mail, so I'll post it here
/QUOTE]
Nope another fellow on here wanted me to send a picture of this gauge but when I try it says I don't have permission-DUHHHH
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 9:55pm
Another question.
Why are my Throttle and shift cable different lengths? Want to order new ones and it looks as a 16' would work for both??
Suggestions; Thoughts didn't work above
Probably because they take different routes to get where they're going.
Usually (not always) the transmission cable runs from the front of the engine back to the shift lever and the throttle cable goes under the engine to the back and curves forward to get to the carburetor.
A little long is better than a little too short
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 2:20pm
Can someone fix Messenger for me It won't let me send a picture, keeps saying don't have permission..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 2:26pm
Wilson_1968-
See if this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 2:33pm
John,
Don't feel bad. I just tried and found the same. My guess is Keith needs to reset a setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 2:38pm
John,
Thanks Thought I had lost it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 4:16pm
Is this a factory bracket for transmission or am I gonna have to make a new one???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 4:31pm
John,
Looks factory to me. I've seen some pretty crude ones! Were you expecting something a little more sophisticated?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 6:45pm
John,
Not really it looks like PO bent the place where the cable connects , so I'm sure when I
remove it will break.
Update:
Found one at Nautique Parts in NC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 7:18pm
Not really it looks like PO bent the place where the cable connects , so I'm sure when I remove it will break.
Don't blame the PO. The bend may have been done at the factory for alignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 7:25pm
Yup looks correct. Nothing odd or cloogy about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 7:59pm
Pete I think what he means is not the bending of the bracket to align but that some of these mounts had 2 slots in them much like a fork. The cable would be placed in one slot and then that dividing tang bent down to hold the cable in place. My HM ones were all bent to heck,they sorta look like this but without that lever- just 2 approximately 1/4" slots with a tang left between them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 8:05pm
Now that I see it on my PC it's not what he meant
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 9:41pm
[QUOTE=jterr]
Everyone is more or less correct. The PO I guess broke the lever off so he crimped the place where cable sits together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2020 at 10:13pm
John,
Thanks. I see what was done to the bracket now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2020 at 3:51am
Small Update:
Got tank , new blower & hose ,new speedo lines and new fuel sender/lines in. Tank was a hard job had to redo 2 times before all fit
Now to motor bracket
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2020 at 3:59am
Question-What is this for??
swilliams View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2020 at 8:10am
That is for storing a flagstaff. There are usually two to hold it in position along the staffs’ length.
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
Post Options Post Options   Thanks (1) Thanks(1)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2020 at 12:21pm
For an 83 those are prob for the anchor light pole
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2020 at 12:25pm
Thanks , thought it might be some kind of brace for that wood cover that goes back there somehow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2020 at 12:34pm
"flagstaff" is a more appropriate marine term than "pole". Still, the same item.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2020 at 12:57pm
Question:
Getting ready to mount motor bracket and it is not quite level , is that a big concern or can it be fixed with the mounts
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2020 at 1:08pm
Question:
John,
The cradle? And not level with what? Yes, there's a fare amount of adjustment in the mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2020 at 1:13pm
[QUOTE=jterr] Question:
John,
The cradle? YES
And not level with what? Floor
All I needed Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2020 at 9:25pm
I hope you’re just doing a fit test for the tank and things because the carpet should go down before the tank is installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2020 at 10:43pm
That would be a Big OOPS, I'll deal with it
Thanks-LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2020 at 10:49pm
Another ??
Any idea how wide this piece of wood should be, or a measurement from the rear of pole to edge towards engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2020 at 10:51pm
Think I could ever get the color back
