1960 Atom Skier Fin Boat Recondition |
Post Reply | Page <1 23456 14> |
Do yourself a favor and buy enough 3/16" to do the job as well... Better to have it on hand just in case. I can never remember which boat takes which size shaft vs rudder... and I'm not sure CC was all that consistent about it either.
Jack,
I'm 99% sure it will be 1/4". |
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
I need to repack the shaft log and probably rudder as well. There a couple different size ropes. Wondering if anybody might know which I would have so I can get it ahead of time. Thanks
juniorwoody
I believe you are the one that gave it the name Nomad, John. Seems we have been bitten by the Fin bug. Would be a shame to lose the old girl after chasing around for it and with it for a few years now. This fire was a real eye opener and there were some lessons learned. |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
I'm happy to hear the Fin Boat is ok. It would be tragic to lose it, it's very high on my list of all time favorite boats.
juniorwoody
You got me on the manuals not being original bubba but I still like them better ATM. The four barrel wasn't either that it had when I got it. One thing at a time think I'll manual choke it for the summer and take it from there. Boat is pretty much original at the moment I think.
Come on Jack, get the automatics working They aren't any more difficult than any other Ford. Both mine work and I've never touched them. By the time you goof around with setting up manuals, you could have then working. Besides, manuals aren't original!
juniorwoody
Pete, the automatic chokes are pita so we never used them. Should have put the manual choke on a while ago. I have been pulliny the arrestor on the front carb and holding the choke closed to get cold start over with. Will not do that anymore.
Jack!!!
I don't understand why you need to pull the flame arrestor to choke the engine! Well, anyway, I'm glad it wasn't real serious, no one was hurt and the boat is OK. |
juniorwoody
Well we have a new story in the storied past of the Skier. Got back to Ct last week and a few days in town said to Burton let's take it for a ride. Was evening coming on when we slid her in the water. I had the dog house open and as Burton pulled the trailer to park I slipped the front flame arrester off to hold the choke and cold start . This only necessary for cold start and have done it many times LOL. Well true to form and fitting to its name the fireball backfired and we had a pretty good fire going. Mad scramble for fire extinguishers and trouble with the one on board. Fellow at the dock made a quick dash and in the water with his. He got to the boat Burton following with our other extinguisher from the truck. All is well that ends well but we loaded up and went home. As it turns out most of the mess in the end was from extinguisher and had a couple melted wires not to bad. It has since been cleaned and I will finish installing the manual choke tonight. Have developed a healthy new respect for having good working safety equipment onboard and taking gas delivery systems very seriously when boat related. I have had carb fires on cars in the past. No big deal. This is serious business. The boat fired up last night and will be on the water again very soon. see you all there.
juniorwoody
It is a mystery then as to the original. Perhaps the Morse. No signs on the kick board of a pedal but signs of a cable routed under the floor on the starboard side. The rigging was amateurish but could have been messed up by the PO. I have saved all the Morse parts.
The pylon is not for sale Bruce. Though I haven't started the Straflite yet it is in my plans as soon as I finish the Junior Utility. Will most likely be my last big project. |
Notch is cut into the side of kickboard.
Jack, that pedal is the same one used throughout the 60's. Your hand throttle looks to be of correct vintage to early 60's. Unless they replaced the kickboard, there should be clear signs of a pedal having been there.
Do you want to sell that pylon? |
juniorwoody
Notice the setup on the 1958 Starflite.
juniorwoody
I have seen that style of pedal Bruce. Didn't see anything like it when I was looking online. Looks to be a much simpler setup for sure. The court is still out on whether my rig will work well or not. I am pretty sure the Morse was not original but not positive. Thinking most early 1960's boats may have had the foot pedal. In any case the conversion may have been done when they put the four barrel on and the installation was not very good. It was also very busy to handle the column shifter and throttle all right handed. Perhaps I am wrong but it didn't look original to your question Pete.
This is the only picture I have of one. The back is a bracket that bolts to the kick board. The pedal pivots on a hinge in the middle. There's a notch in the top of the kick board for the cable. There's a holder connected to the frame and an old style cable with a brass ball connector attaches to the pedal. We had to cut the ball off the old cable, drill and tap it in order to adapt it to a modern cable. |
Duane in Indy
Looks like it would be simple task to hook up the foot pedal to a Morse cable. Foot pedal could also be altered to look more "original" if you wanted.
1978 Mustang (modified) |
Jack,
I just noticed the holes close to the sole on the foot rest. Does it look like they were for a cable at one time? |
I can take a picture in the coming week of one for you. They're simply a pedal that pivots in the middle and the throttle cable connects to the back of the pedal near the top. It sticks and you use your toe and heal to operate it.
I too wonder how it was set up originally? That single lever Morse doesn't look bad at all. You don't feel it came from the factory? Did you ever consider keeping it?
juniorwoody
Thanks Bruce. Wish I knew what was original as I figure there's an easier way to get there but all I can come up with. I styled it after the contraption on the Starflite.
That's a lot of nice work jack. It is far more complicated than the original design.
juniorwoody
juniorwoody
Pete, the boat came with a Morse lever mounted on the gunnel. I do believe it was originally a foot pedal but no trace left of the mechanism. Has a column shifter.
Jack,
Yes, it looks like you are designing a "Rube"! Not that it's bad, sometimes needed and I admire your engineering. What was in the boat when you got it "converted"? I went back in the thread looking and couldn't find anything plus, some of your pictures have been deleted. |
juniorwoody
Finally got back to working on the foot pedal accelerator. As the boat came converted I was on my own to make a suitable linkage. This is my Rube mockup. I hope it saves me some time lying on my back in the helm. |
juniorwoody
Hey there JohnB, the fin boat or Nomad as you named her is resting in Fl where the season is gentle on old boats with long histories. Had some great fun with it at the mini reunion in Lake Badin this summer end and brought it south along with myself to winter it out. I also made a trip up and back to CT Thanksgiving time and brought back the 1957 Starflite to look at and think about beginning the long process or compplete restoration. Am very pleased to hear that Alan is going to be running a restoration of the same hull at the same time. Should be very helpful possibly. The 1950 Utility is upside down in Ct and needs another summer season to finish the hull as well. I hope to get to that this summer coming however may need a little work done on my lumbar and that could cause some delay.
john b
I hope the fin boat is bundled up in swaddling clothes for a winters rest.
kapla
looking good!
juniorwoody
Thanks for the comments gents. I expect to have many smiles per gallon with it.. Burton is itchin for a pull bad and that could happen this weekend.
Pete, we adjusted the lifters after that shakedown ride again and they are good. I now need to tweek the carbs perhaps on the idle mix cause occaisional stalling at the dock or loading. That can be frustrating and cause damage. |
