Bruce , possible YH replacement SU’s |
uk1979 ![]() Platinum Member ![]() Joined: June-13-2007 Location: United Kingdom Status: Online Points: 1414 |
![]() ![]() ![]() ![]() ![]() Posted: September-26-2015 at 12:09pm |
There you go Bruce... main body will fit but to centre it I have had to undo the float chamber mount will need to make up a bracket for it, will need to mod the valley tray to give more room under the carb’s.
When in will add 2’ 3/4 inch to the height of engine. YH’s carbs have a 1’ 9/16 ventures the SU are 2’ inch, Not much to report still on honey doo’s duty. Cheers Roger. |
Lets have a go
juniorwoody ![]() Gold Member ![]() Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
Is your goal to increase performance or reliability Roger?
That looks like a rather large honey do list there bud. Any pictures of the Starflite or is it on the back burner? |
Jack I’m hoping to build a max CI Y block, so yes just a performance upgrade and still keeping the engine as low as possible, there has been talk of stroker cranks by Scat but nothing as yet.
The YH’s are good on a standard engines but will hold back a bigger CI engine with big valve heads. Starflite is well hope to move it forward over the winter. Cheers Roger. |
Lets have a go
Roger,
Very interesting but will they fit under the dog house? ![]() |
lewy2001 ![]() Grand Poobah ![]() ![]() Joined: March-19-2008 Location: NSW Australia Status: Offline Points: 2234 |
Roger I wonder if a sidedraught CD Stromberg would have a lower profile? They were basically SU equivalents. Same as the SU's should be available in 1.5" 1.75" and 2"
Used to have a few different triple sidedraught carby setups on hot rod straight six motors in my boy racer days ![]() |
Had SU's on a '67 MGB. Had to add oil to the carbs every time I drove it.
No stranger to sidedrafts here I bought a new MG Midget in 1970 after returning from VietNam. What a can of worms that was but as I remember the carbs performed ok. Still not having had enough of cans of worms I bought a 1962 Mrecedes 220b around 1980. It had sidedrafts as well. Were they Solex? Can't remember, but I remember getting a vacume gauge to synchronize them.
The triple Zenith's on the Chris/Hercules are always lots of fun too! |
Another more recent option would be the Mikuni or Keihin carbs on motorbikes. Bikes took quite a few more years to switch to fuel injection. Throttle control and feel is big part of riding a bike fast.
I had a 2001 model V twin 1000c Honda that used two 1.9" (48mm) carbies was able to purchase after market jetting from Dynojet as well. |
Thanks Mark ... I hadn't thought about them or big V twin bike carbs shall look into them and report back. Cheers Roger. |
Lets have a go
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Roger, that's really interesting. I would think those would make a difference.
What are you building, a terrace? |
Bruce, I'm putting in a base for a summer house/shed and a new green house.
Will update more on possible carbs, once I have fully checked out Marks Idea's. Cheers Roger. |
Lets have a go
Keep us dated. Have you started on the boat?
Dreaming ![]() Platinum Member ![]() ![]() Joined: May-21-2010 Location: Tacoma, WA Status: Offline Points: 1870 |
I had SU's on my Datsun Roadster as well, you should be able to find something cheaper than the Jag/rover types Roger mentioned. I'm always amazed at how creative and knowledgeable some of you guys are!
