How do I get these off? |
Page 12> |
Frankenotter ![]() Platinum Member ![]() ![]() Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
![]() ![]() ![]() ![]() ![]() Posted: March-24-2013 at 1:28pm |
Well, its manifold time and I have a HUGE concern. My port side manifold is sooooo corroded that there is nothing left of the bolt heads.
I'm planning on grinding the heads off, pulling the manifold off, and then seeing if there is enough left of the bolt to get a vice grip on to slowly back it out. If the shaft of the bolt breaks I think I'm screwed. I've been hitting them with penetrating oil for about a week now and someone suggested heating the area around the bolt with a torch, but that doesn't seem like it would be good for the head. I'm all ears to suggestions on all or part of this job. ![]() Chris ![]() ![]() |
1999 Ski Nautique 196
What do I do if the worst case scenario happens and the bolt dreaks off in the head?
gR@HaM ![]() Platinum Member ![]() ![]() Joined: May-01-2012 Location: UK Status: Offline Points: 1265 |
How's about chopping the head off with a small cutting blade on a dremmel then using vice grips to get it out?
Failing that, welding a hex bit to the bolt? Or using a small Irwin easy-out? |
'82 Ski Tique
Waterdog ![]() Grand Poobah ![]() ![]() Joined: April-27-2006 Location: United States Status: Offline Points: 2020 |
A cut off wheel will work.
Cut the head off or cut an "X" in the head down to the shank. and use a chisel. Soak them in penatrating oil the best is 1/2 Trans fluid and 1/2 acetone, easy to make yourself. And keep soaking them. |
Resist all urges to use an easy out. If you have a mig welder weld a nut on to what you have first and see if you can get them out.The heat from welding will help break the rust.If that don't work grind the head off remove the manifold and then weld a nut on. Replace with stainless and use anti seize. Some may come out with a vice grip but be careful not to mess them up so much that you cannot weld a nut on.
I agree, but I wouldn't be afraid of cutting them off with the cut off in a Dremel. You will them get a better shot at getting the penetrating where it should go. The problem with a "easy out", is the soc. hd. cap screws are grade 9 and very hard. They are tough to drill even with carbide bits and an easy out won't grab. |
TX Foilhead ![]() Grand Poobah ![]() ![]() Joined: February-01-2009 Location: Kingsland TX Status: Offline Points: 2076 |
I just cut off 4 of those, cut off wheel on a die grinder and some paitence is all it takes. If you don't want the manifolds it a little easier, it's hard not to saw into them a little. I also broke the spark plugs off on purpose to keep the motor sealed while I worked, pipe plugs would work for that too. I didn't remove the bolts from the heads, but I got a ground off head bolt out of the block and anothe out of the exhaust manifold. I used acetone and ATF on both and let them sit for at least a day. They hardly put up a fight when I got around to taking them out. If you have a welder you can tack a nut on them to make it even easier.
Hit the bolts fairly hard with a ball peen hammer. The scale rust will jump off and help loosen the bolts. |
Good info gents. I'm going by the boat one more time today on my way to work and ill hit it with the ATF mix.
I've been warned my several people already not to attempt an easy out due to bolt hardness. Ill see if I can get my welding dude to tack a nut on. Next weekend will be d-day for this project. Chris |
peter1234 ![]() Grand Poobah ![]() ![]() Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
take the heads of the bolts off pry the manifolds off, weld nuts on where you can hit the studs with a hammer, i have to say i have been using a new product i always used pb blaster but now i heat the studs , and when cool i have been using crc freeze off , whatever it is it acts like freon and penetrating oil all at once
Well the bolts have been soaking in oil all week so I came back to them today for a test.
It didn't go well. All I've done so far is the riser bolts (haven't even touched the manifold bolts which are in 10X worse shape). Broke 3/4 after using ATF/Acetone mix and sitting for 4 days. These don't matter because the lowers are garbage anyway but it makes me nervous for the big show. ![]() ![]() |
Those manifolds don't look too bad, your probably going to have to tak a nut on them since they're so short. On the heads you should have much more to work with, but since you're going to tak some of them you might as well do all of them. Another round of ATF/Acetone won't make it any harder.
The risers are in great shape but the lowers are cracked due to winterization from the PO.
I will be trying the welding technique for sure. I've also been reading a ton of info on ford sites about the miracles of PB Blaster. Anyone want to chime in on the ATF/Acetone vs. PB Blaster oils???? |
I'm sure someone will post the test, PB Blaster is about dead even with WD40. ATF/Acetone blows everything away by a good margin. It's quite flammable and I would guess that my safety people would frown on it with no MSDS, but I know quite a few machinists that keep a bottle around for the difficult stuff.
Evidently the Ford guys on those sites fall for "Madison avenue marketing" BS and they shop at HD!! ![]() If you fail at getting them out, a machine shop with an EDM can burn them out. It may be cheaper than a new set of manifolds and risers. |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21139 |
I think we have established that the manifolds are beyond saving for other reasons. He is concerned about the heads. Personally, id do my best on them but would know in the back of my mind that new gt40p heads would bolt on 45hp for $450... So if things go south that's not all bad news.
the way i weld nuts on is . grind the top of the old bolt head put the new nut on and weld the hole , if you have the option on say a 3/8 manifold bolt i try to use a 7/16 or even a 1/2 " nut over it you have more hole to weld. if you have difficulty getting the nut to stick try and die grind a slot into the top of the bolt so the weld will get into that .
Waternut ![]() Senior Member ![]() Joined: July-11-2012 Location: Macon, GA Status: Offline Points: 292 |
Well if it comes down to it, I've got a set of heads that I pulled off my boat during the GT40p head swap. They're in good shape and just sitting on my shelf taking up room so I'd let them go pretty cheap. Shipping isn't cheap though...
i have a pristine set of 428 cj heads from my old jet drive, i bet you could find a bb ford short block to fit in there
Now that is project scope creep!
Dank ![]() Senior Member ![]() ![]() Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
So maybe someone has already asked, but if the manifolds are cracked due to the PO no winterizing the boat...how do you know they drained the block? Maybe I can learn something :)
"I don't know what the world may need, but a V8 engine's a good start for me"
I went & viewed the boat. I verified (by taking block drain plugs out) that block was drained. The PO was not mechanically inclined & did not know that there were other things to drain too.
The engine also turned-over via breaker bar. |
got ya...just caught my attention and I hadn't seen anyone else ask :)
The engine has an abnormal amount of external corrosion.
It must have been put away wet repeatedly. |
Well the day has arrived. I hacked into the manifolds today with mixed results.
The good news ----- 15 out of 16 bolts came out!!!! The bad news ----- 15 out of 16 bolts came out..... All of the bolts forward of the Aft-most cylinders came off really nice after being soaked in ATF/Acetone for a week. The two most aft cylinder bolts (both port and starboard sides), however, were too far gone to get an allen head in. I started by taking a cutting head on the dremmel and little by little removing the head of the bolts until I could make out the gap between them and the manifold. ![]() ![]() The manifold popped right off exposing my two stems. ![]() ![]() I took a chance and put a shot of oil and a vice grip on the first one and it literally spun right out. ![]() The same was not true of the other. As I put a vice grip on it, the threads fell apart and I was too afraid to try again. You can see it in the picture above just above my finger. I guess my last attempt at getting this one off is going to be the welding method. I hit it with ATF/Acetone about 10 more times before I left today in hopes that it will be ready next weekend when I come back to it. On the starboard side I was not as gentle because the bolts were in much better shape. Here I used a pneumatic cutting wheel and went to town. ![]() When I got the manifold off, I put a vice grip on the stem and they came right out nice and easy. So.....literally one bolt lays between me and boating season (in theory). Until it comes out my nerves will be shot for the next week or so. |
Oh.....and before anyone yells at me.......
Those are sacrificial spark plugs in the hole to block little bits from entering the cylinder. Chris |
You"re doing good you've only got one left and you haven't resorted to the real serious stuff yet. Weld a nut on and I bet the last one will pop out easy.
If you can't get a welder, a micro-torch that would heat that shank easy. I would use some flashing to shield the other surfaces from the flame.
storm34 ![]() Grand Poobah ![]() ![]() Joined: November-03-2008 Location: Dexter Iowa Status: Offline Points: 4492 |
Chris and Chris, was this boat on Delhi? I remember one similar on a lift up there.
Is it just me or is almost everyone on this site named Chris?
Yes Chris, this was a lake Delhi boat. Bought it from an older couple that were moving and kids were all gone from the area. I know they did have it on a lift as well until the dam broke. Like Chris said, really nice folks, they just did nothing for upkeep on the boat. It's been and interesting road getting this little hot rod back in shape. Chris. |
Page 12> |
