The old girl got a face lift |
gcam4
Groupie Joined: March-21-2017 Location: Charlotte, NC Status: Offline Points: 51 |
Posted: April-15-2021 at 6:09am |
Super old thread, but has anyone had any more luck locating tubing for colored inserts? I'm looking for teal. I wanted to just flip it around but the screw heads have damaged the insert on the inside and I don't want to use it except as a last resort.
KRoundy
Steve,
That does not look right. Assuming that your 1993 Sport and my 1993 Ski have similar rub rails, I don't think you got the right part. First, here is a close-up of my rub rail, before it was removed from the boat (other parts of the rub rail were trashed): I also have spent some time at the Taco Metals Marine Products web site. If you go to this site and wander down to the FAQ's you can get a list of the rub rails that go on Correct Craft boats. Based upon this information, and the advice of others here on CCF, I believe that the right rub rail for my boat is a V11-3447. This rail is the closest to the OEM rail for our era Correct Craft boats. Note that the rails now only come with a black or a white insert tube now (you can't get say, a blue one, that would match the color of your boat or look like the brochures. I hope this helps. I'm not sure why you were sent what appears to me to be the wrong part. Paul - did you get a Taco rub rail? If so, which part number? |
AussieNorts
Groupie Joined: March-10-2007 Location: Australia Status: Offline Points: 82 |
Paul,
I just need some clarification here I am not sure the rob rail you used is the same to what I have purchased from Nautique Parts. Is this the same rub rail? Mine is very rigid and has the white backing in it, did yours look like this? I only ask this as the rail seems too rigid to fit to the boat without some heat, but if it the same as yours I will try as you got it no worries. Paul also did you measure to find the middle and work from the bow down one side and then the next side? Sorry for all the questions,am totally new to this job never seen it done or done myself, I am in the dark!!! I just spoke with my local dealer this morning and he made it sound like it is very hard to do. Thanks again Steve |
Correct craft.....is there any other boat?
quinner
Paul, nice work, looking good! Now that the boats are done time to get that siding up on your boat barn!!
87nautique
Newbie Joined: February-09-2006 Status: Offline Points: 9 |
Hi,
I have an 87 nautique, grey hull and black lettering. Where did you get the rope to replace the rail? How much did you get? What diameter is rope? Any information is appreciated. Thanks, Paul |
C-Bass
Paul, it looks great. Info on your decals and pinstripe source (TimD?) is appreciated, they look like an exact match. Did you have trouble lining up the shadow graphic after the main was placed?
Steve
Also when your putting in your screws just snug them up secure. If you run them in two tight you'll get bulges in the side of the rail. Theres plenty of screws to hold it solid so they dont have to be to tight just snug. Good luck with yours. |
AussieNorts
Paul,
Thanks for the explanation on the rub rail install, I just could not find on here anyone that had documented it. I truly appreciate it and your method sounds alot easier than heating the thing up. I have filled all my holes so I will probably attempt it this weekend. Steve |
Bengals went to gray on gray????? I thought they were prissy pumpkin orange and black |
turningpoint84
Platinum Member Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
Love your Cincinnati Bengals boat, great color scheme!
1970 Mustang |
Jllogan
ya better bring the 95 that way you dont make my 86 look so shabby. |
Joe
send'em on down we'll get them shined up after a run two...enty in the river |
Steve,
I did it by myself. The first thing I did is fill all the old holes with thickened epoxy resin using a big syringe tube. I took a small drill bit and enlarged the hole slightly. I sprayed WD-40 on the plunger to help it slide and keep the resin from sticking to it. I had to refill it three times to do all the holes. Once all the holes were filled I took a putty knife and smoothed out the resin that oozed out of the holes. It worked great. I then took masking tape and laid out(every 3")where I was going to drill so I wouldn't hit the old holes or cap rivets. I then put the roll of rub rail on a chair with wheels and as I rolled the rub rail out I used stripes of duct tape to hold it in place. There is no need to warm it up just go 1 screw at a time in sequence and the slack will push forward. You will have to adjust where you taped it as the slack pushes forward. I used two drills one to drill the holes and the other to run the screws in with. To install the rope I used the 1/2" copper pipe trick with a slight bend to guide the rope into the groove. 187 screws and 4-5 beers later it was done. Here's the big syringe I used Here you can see the lay out marks above the rub rail. |
That boat is looking pretty darn good Paul! The only problem I see is that both of your boats are getting close to perfect... you won't have anything to work on. Don't worry... I can drop off one or two of my boat backlog to keep you busy.
Paul, I agree. It looks fantastic! |
Kristof
That looks shiny...
Great job! |
AussieNorts
Sorry and by the way the boat looks great!!
AussieNorts
Paul,
Would you care to elaborate on the process you went through to install the rub rail, I have to do this on a 1997 Sport and have heard you need to heat it up in a bath or hot water, did you use this method? I just can not see how warm water will enable this to stretch at all. How many people did you need to install that new rub rail? I wish it was just easier but then it would not be a boat right. Thanks again everyone on here for there help with all matters correct craft. Steve |
davidg
Great job!! The boat looks great! A classic color combination.
Gottcha
On fall start up I usually pull the plugs shoot a shot of starter fluid in each hole.(if you can shoot it through the carb it's even better to get it down in the crankcase) Then a few wide open throttle pulls to get the carbs fuel bowls filling. Then one more shot of starter fluid replace plugs and they usually fire right up. I think using the starter fluid for the first couple pulls helps thin the oil and helps the sled light off the oil. |
Paul - Great job, you will get many compliments at the ramp!
Pete - does she pull a tube with it? |
Paul, No No No!!!! The plugs were replaced EVERY year!! That's why I mentioned the damn thing would not start on fogged plugs from the previous fall! |
WOW you got 5 years out of a set of plugs on a 2 stroke!!! Send some of that luck my way
I always figure a new set a year in our 2 stroke sleds. |
Paul.
It's a 2 stroke. The Platinum Spark Plugs for at least 5 years have held up damn good. The ignition system on the 500 is so weak that the fall fogging will not allow a spring start. The cure is a new set of plugs. The platinum plugs are the proper replacements for the originals per the charts. |
Pete
2 stroke or 4. Are the plugs getting wet(fuel) Those carbs can clog up right quick. I'm not sure about the '90s but when I had my '01 600 it had to run the recommended plugs. |
Paul, You have "his" and "hers" boats? Wow!!! In the Brainard household, All I can call "hers" is the damn PWC she bought! It's a 1990 500 Seadoo and it's actually not going in the water this year. Last summer, when I was winterizing all the boats, the damn thing would not start. I understand the ignition system is on the weak side on the 500's. The high end spark plugs have gotten me through many years but now it's time to take it in. I refuse to work on the thing standing on my head with said head in a black hole!!! Any help/input on the 500's? |
Not sure yet the wifey likes the '95 better with the kids.(her boat) |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
Nice work. Nice shop!
83Ski
Big Pappa
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 322 |
Looks Awesome!!!
