can i turn a 13x 10.5 |
bwooton
Groupie Joined: June-13-2005 Location: United States Status: Offline Points: 91 |
Posted: June-03-2007 at 9:55pm |
i found what looks to be a good deal on a Acme 13x10.5 on ebay and i was wondering if that was to much prop. i have a 78 tique that i have repowered with a mercruiser 350 not sure what the hp is.
Thanks Bobby
there's no replacement for displacement |
79nautique
sure you can,
might spin a couple of RPM's thou |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5774 |
What's on the boat now?
bwooton
it has the stock 12 x 14. i put a standard rotation engine in because the po let the 305 freeze with lake water in it, now i need a standard rotation prop that i wont have to pay and arm and a leg for.
Thanks Bobby
Bobby, My understanding of dia. to pitch is that 1 inch larger in dia. equates to about 2 inches of increased pitch. This puts the 13x10.5 in the range equal to a 12x12.5 so you may be under proped. You will need to watch your top end rpm's. The other problem is that although the 13 inch may fit, the closness of it to the hull may reduce it's efficiency. Close to hull props have also been know to cause hull rash. It's when the gel coat is actually eroded from the water. This is a picture from another post showing the hull rash.
Are you sure that your 78 was a 12x14? My 77 Tique has a 13x13 on it. |
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
My old 78 tique had a 302 and 12x14 from the factory.
bwooton
i am sure that it is a 12 x 13. I would run a 12 in prop if i could find one at a reasonable price. the acme 540 is a 13 in prop?
Thanks Bobby
bwooton
i am sure that it is a 12 x 14. I would run a 12 in prop if i could find one at a reasonable price. the acme 540 is a 13 in prop?
Thanks Bobby
81nautique
The 540 is 13x12 but ofcourse backwards for your new engine. I turn a 540 at 4900,I think you'll spill the guts out of the motor with the 13x10.5
