Hard starting when warm |
Author | |||
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2066 |
Posted: September-09-2009 at 10:52pm |
We still need to know if it is a GT-40 or a carb motor???? |
beck
Newbie Joined: July-01-2008 Location: Canada Status: Offline Points: 39 |
ya we just leave it run, and then you know if your out there for the weekend and you take it out, open up the engine cover and just leave it open until you use it next, let me know how that works for you
1994 Sport Nautique 21ft 5.8L EFI Pro Tec Injection 310HP
wakemeup
Senior Member Joined: July-11-2008 Location: Culver City, CA Status: Offline Points: 113 |
I take it you just idle the boat when you are switching skiers/boarders in the open water. I am fairly new to boating but was taught to turn the motor off anytime someone was going in or out of the boat, especially around the swim step. I'm constantly turning the boat on and off. |
Wakemeup
1988 Ski Nautique 1999 Air Nautique |
Fl Inboards
Did we have protech in 99? I thought that went away in about 94. I to agree that vapor lock is probably not the cause. I take it this is a HO carb motor? And not a GT-40. |
beck
well we do that and it works everytime lol, if we dont keep it open after using it then it doesnt start 15 minutes later
Brandon,
I'd wager to say it's not vapor locking (real hard to do on a boat) but rather your Pro Tech suffering from heat soak. |
beck
it could be vapor locking, my 94 sport nautique does that, we just leave the engine cover open after we use it and it starts up fine later
Has nothing to do with being a Ford. My GT-40 starts on the first crank every time hot or cold. Start looking deeper than the name.
wakemeup
I'll give that a shot. Thanks for your input. |
Wakemeup
My 351 starts with that 1/2 second period. If your timing is set too advanced, that will make it start hard when hot. I backed mine off 1 degree (to 9) & that helped it start easier.
wakemeup
Thats unfortunate! Everytime someone else drives the boat so I can board I have to tell them to hold the key in the start position until it fires. My friends Sanger with a Chevy Mercruser lights within 1/2 a second to holding the key in start every time. Oh well thats what I get with owning a Ford. That Chevy 350 is the best engine ever built for any application, its bullet proof. |
Wakemeup
behindpropeller
I think that is pretty normal on the 310 hp engines......
wakemeup
Mine has never stalled or ran rough after starting. The only problem is you have to hold the key in the start position way to long before it starts. Anyway let us know what the PCM guy says.
Thanks |
Wakemeup
jerry@vail.net
Newbie Joined: September-06-2007 Location: Vail, Colorado Status: Offline Points: 11 |
Check out this thread:
http://correctcraftfan.com/forum/forum_posts.asp?TID=14377&PID=176239#176239 Is this similar to your symptoms? |
Jerry
wakemeup
I've got a 99 Air Nautique with a Pro Boss 351, 310 HP motor. The boat starts fine when cold but when it is warm I have to hold the key in the start position for about 5 seconds or so before it starts. It doesn't always do this, there is no pattern. It has always started but having to "turn it over" so much before it starts is annoying. Any insight from anyone as to whats happening is appreciated.
Thanks |
Wakemeup
