Dilemma. |
Tate
Senior Member Joined: October-08-2004 Location: United States Status: Offline Points: 134 |
Posted: August-28-2006 at 11:22pm |
Y'all help me out. I think I want a tower on my 80 Martinique. I'm trying to progress on my wakeboard. I've been riding for a few years behind an extesion pole but I hear the quality of the ride is a lot better behind a tower. (Boat doesn't lyst on hard cuts) Is that going to ruin the vintage feel and look of the boat? I know it's a moving anachronism on an '80 but I really think I want one. Anybody have any feedback on this?
Tate
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
Tate, I don't see how a tower will prevent you from listing during a side cut. The rope will still be pulled from approx. the same location attached to the same base platform (the boat). We try to not pull out so far and increase our cut just before the wake, helps reduce the list.
I would second that a tower isn't going to change the load on the hull and will still list to the side in either case.
Tate
I thought that too, and you guys are probobly right. I heard a guy on the Pull TV show say that and since I've never ridden behind a tower I really had no basis for comparison. Maybe the ext. pole is sufficient.
Tate
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
I board with a skylon and I'd like a tower, but like the others I don't think it would make much difference in the boat listing and I don't think it would improve my boarding (essentially the same pull point as the skylon). I would want a tower for:
1) looks 2) currently rope gets caught on my boards in the board rack on the skylon 3) can mount speakers and lights on a tower 4) could fashion cover around a tower...right now I remove the skylon when putting the boat up 5) tower mounted anchor light would be cool However...if I was going to drop a grand on my boat, I'd probably put perfect pa$$ on it before a tower :) |
"I don't know what the world may need, but a V8 engine's a good start for me"
bkhallpass
I've had this debate before as to weather a tower lists less than a pole. At it's simplest level, I agree that if the attach point is at the same, the forces should be the same. Still, in the back of my mind, I can't help but believe when you move from a single point of attachment at the floor, to a 4 or six point contact at the gunnel, and distribute the loads over a wider area, there must be some difference. However, it's been 25 years since I studied physics, and I'm not smart enough to figure it out any more.
Antidotally, I've driven and ridden the same model boats with tower and pole. It sure seems to me like the the pole rocks the boat more. BKH |
Livin' the Dream
Poster112
Senior Member Joined: May-28-2006 Location: United States Status: Offline Points: 206 |
Pivot point with an extended pylon is lower (below the floor), therefore you get more leverage when pulling on the lever, which is the pylon. The tower's pivot point is at the level of the gunnel, so not as much leverage, which equals less rock. How much less is still a question, because an arguement can be made that the sides of the hull act as an extension of the tower, leading down to the same pivot point as the pylon (the keel). I still think that the shorter lever provides less leverage. Anyway, I would never put a tower on my 78 nautique, so I just do not pull out so far when using my skylon.
Just my 2 cents. |
I agree with the Perfect Pa$$ before a tower option especially if you already have an extended pylon. Towers are nice for the extra storage room and provide a bit more solid pull helping load the rope betterbut its not going to get you closer to landing your inverts. Couldn't live without my perfect pa$$ though, once you have perfect you can't go back...
Dank, The previous owner had the cover on my 2001 modified to fit around the extended pylon, and it works out really well. I could take a picture of it if your interested. -Joe. |
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
I will have to disagree with that poster. There is no pivot point. If the pylon & the tower are both attached to the boat in a rigid manner & both have the same height to the pulling point, the roll of the boat should be the same. There will be an increased stress on the attachment point of the pylon compared to the tower because of the single attachment point compared to the 4 points of the tower.
dchris17
Gold Member Joined: May-28-2005 Location: Weatherford, TX Status: Offline Points: 573 |
From a mechanical engineering perspective, I have to agree with the sentiment that the listing SHOULD be the same regardless of whether you use a tower or a pole. That's the way the physics work, at least at the level of understanding you get from college level static/dynamic force cla$$es. There is a difference in the amount of torque exerted at the attachement points, but I don't know why that would affect the tendency of the boat to roll.
That said, my experience is the same as BK's. Boats with towers rock less. I can't explain why. I didn't believe it until I bought a tower and put it on my boat (not my M17). Everything I studied in college tells me it shouldn't matter, but it does. Aesthetically, I wouldn't have any problem putting a tower on your 80 Martinique. I have seen a Martinique with a tower on it and I think it looks great. Since it's open bow, it kind of looks like all the other open bow ski/wake boats. |
Dank
Joe, that would be cool. Shoot me some pics when you get a chance: kruzie @ gmail . com I'll need to do some cover repair before too long...maybe I'll incorporate that in.
Mojoman
Senior Member Joined: October-31-2005 Location: United States Status: Offline Points: 553 |
QUESTION, Not to threadjack, but do most states have a problem with towers/skylons and running at night with conventional aft, deck anchor lights?? Don't anchor lights have to be at the tallest point on the boat? If so, all these "add-on" aftermarket towers don't come with a retrofit or anchor light option, or at least what I've seen available?????
Just wondering.. Moj' |
Tate
Thanks guys. I'm as confused as ever. I don't want the boat to roll but at the same time I don't want to ruin the look of the boat after an 18 mo. restoration(still not finished).
Tate
bkhallpass
It's still going to roll, tower or no tower. I say, if you restored it, go with the pole. If you fixed it up, go with the tower. My $.02. BKH
Livin' the Dream
quinner
Mojo, That is an interesting question, my 99' came from the factory with a tower and a conventional stern light and my 05' came with the light on the tower. |
92'NIQUE
Senior Member Joined: September-27-2004 Location: United States Status: Offline Points: 189 |
Now that we've taken care of the physics questions, go for the tower! They really do add another dimension to the boat. I'm partial to Monster Towers for older boats (lets say... pre '95). Nothing beats FCT for newer boats('96+). I've never heard of anyone regetting installing an after market tower.
Tate
92 I looked at monster. They are good looking. If I do it I'll probobly go that route. BKH, hint taken. I realize that my def. of restore vs. some of the talented guys on this site are probobly very different. The boat looks great now. All I can say is you should have seen the "boat" I pulled home.
Tate
bkhallpass
No hint Tate. I don't recall what your boat looked like. All I was saying is that if you took the time and effort to restore it to orignal, then my vote would be go for the pole so it stays that way. I'm sure your boat looks great. BKH
Livin' the Dream
05 210
Platinum Member Joined: February-17-2006 Location: Southern Maine Status: Offline Points: 1481 |
I'm curious about this.Do you think the boat would list more because with a pole you are putting a side load on directly above the point of attachment,whereas with a tower,maybe some of that side load is lost thru the bends in the tower and transformed into some form of downforce?Does that even make sense?
Mike |
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
skicat and Dchris. Not trying to be a smarta$$, and I would really like to know the answer to this question...and...since both of you must be engineers...having the torque generated below the boats Vertical Center of Gravity (VCG) with a Pole or above the VCG with a Tower could possibly be the difference.
I take no credit for my Towers design since I basically scaled down a CC design (see recent post) and started welding. But I did notice that compared to other designs, the geometry of the legs will try to place load on all 4 supports. If you take a look at the Tower I built you could do pull-ups from the Tow Point on the shop floor (not bolted down)without the thing turning over. The point being was the geometric nature of the design tries to load all four supports when in use. When transfering some of the "pull out" load to both sides of the boat..even a small amount on the high side..the list is reduced. I basically scaled down the CC design to fit my small boat...I think the Engineer who designed their Tower really knew what he was doing. The CC design is not just an elevated Tow Point...some smart guy sat down and did some head scratchin'. A factor much greater than Pole vs Tower is the width of your boat. Mine is a narrow 16' Tow boat. IMHO a wider model (like a Martinique) will do well with either a Tower or Pole since it's a lot wider than my ride. You can build your own...a lot of us have...but believe me, it's a lot more work than you think. Building is simple as well as installation, but there is so much more to it than just that. The Companies that do this for Profit IMHO don't charge enough. I buitl my own Tower because it's the kind of thing I like to do. Labor or Love! Hope this made sense! |
2_Nautiques
05 210 - to address your question, as the boarder pulls to the side there is a down force from the tower that is transfered to the side of the boat, however don't forget that on the oppisite side of the boat there is also an upward force trying to pull that side of the boat out of the water. With everything attached to the boat, it doesn't matter how it is attached it only matters how far from the center of gravity the pull is generated (how high the tow point). Just my .02$
77stang
Senior Member Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
the kid and i were discussing a topic for his science project. i think we found it.
great78
Senior Member Joined: October-04-2005 Location: United States Status: Offline Points: 103 |
2 Nautiques has it right(as do others)however the lever arm is longer on a pole as it attaches to the floor and the tower attaches to the gunnels. torque is force x lever arm so would be greater with a pole.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
I disagree. 2_Nautiques has it right. The point of the force is equidistant from the point of rotation (the hull) in both cases. It shouldnt matter how the pylon or tower is attached, as both are attached securely to the hull. |
I agree with Matt and TIm,....great78 is correct about the formula but that is based upon the pivot point which in this case is the hull, so if the pole was slightly higher then yes it could list a ittle more but not that much to make a difference and screwing up the boat looks with a tower that doesn't match that well. I've only seen one that was custom made that looks good on that hull all other are disporportional and doesn't flow with the lines of the boat looks bad IMHO
05 210
This is what I was wondering after my first posted question.The point of rotation is the same no matter what,so I guess it would make sense that the list would be the same if the tow point was the same distance from the pivot point.It's settled then...Towers list less because we want them to after spending all that money on one!! Thanks for the insight guys. Mike |
[/QUOTE]...Towers list less because we want them to after spending all that money on one!! Thanks for the insight guys.
Mike[/QUOTE] nice logic the higher the ticket price the more weight it carries. |
The Dude
That's just like, I ski better on my new ski than my old one because it's new and more expensive.
Mullet Free since 93
95 Sport |
05 210
Exactly. I may be completely wrong,but it makes the most sense to me.But I like new and expensive as much as the next guy,so I can't say anything. Mike |
Mostly for Dank...
Here are some pictures of how my cover was modified to attach to and go around the extended pylon. The overlap has velcro on it... -Joe. |
