Voltage Issue |
Author | ||
00cls1camaross
Senior Member Joined: June-23-2011 Location: Tempe, AZ Status: Offline Points: 123 |
Posted: February-09-2012 at 11:11pm |
I posted about this a while back and I am looking to follow up with everyone.
I have low voltage when I put on my bow lights and my tall light in the back. I read that it was possibly due to an undersized wire. I pulled some covers off and the wire going from the battery to the breaker is 2 gauge. The wire going from the battery to the motor is 2 gauge. The wire going from the amp to power the gauges/dash is 10 gauge. I checked voltage at the battery 12.5, I checked voltage at the bus. 12.3, then I check the voltage at the gauge and I was reading 10.5. I took a closer look and noticed that the positive lead going from the bus to the gauge, where it connects on the screw looks fairly corroded. I sanded down all the connections except the one at the gauge. Anyone have any input on how to sand down the screw? Anyone know where I can find a replacement gauge? Thanks, I attached a few pics so you can see what I see. Let me know if anything looks funky. |
2002 Chevrolet Silverado Z71
33 x 12.50s, BBK, Cranked 2000 Camaro SS Cam, Slicks, Boltons, Stall 1985 Ski Nautique MT1, Board Rack, ACME 542 Future:Stereo, Wrap, Girls |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
Things look pretty clean, a small wire brush and some solvent should work, or thread a bolt on and off several times. I don't think you will need to replace the gauge.
Dielectric grease is your friend. Get some. It will save you more time down the road.
When you get all the connections cleaned up, report back on the voltage drop (with the nav lights on). Do you have a wire type battey post/terminal cleaner? |
00cls1camaross
I put that conductive grease on all of the connections I am cleaning. I will try to clean them today and let everyone know how it goes. I can't wait till everything is in tip top shape!
P71_CrownVic
Gold Member Joined: July-07-2008 Location: SD Status: Offline Points: 534 |
I'm going to re-ask this question here since it got lost in the stereo thread we saw recently: Since we're on the topic of voltage, is it bad when the sub woofer hits that the needles of the gauges jump all over the place? Is that indicative that I may need a higher amp alternator? |
Not really. It's the amp hours you need to be concerned about. Just like your service to your house,it's the average. Do you have a problem maintaining a charge in the battery? |
TX Foilhead
Matt, a second battery dedicated to the amps would probably solve your issue. It doesn't take very much stereo to get to the limits of the stock alternator, a second battery gives you a seperate resivoir to handle that. That's the easiest solution. What kind of system are you running, what amps and how many?
TX Foilhead
To the original post; Not Given, you'll probably pick up a little voltage with each thing you clean, running the motor will bring it up a couple of volts as well. I would start at the battery connection first, that should be an easy 1/4 volt. The breakers would be next and don't forget to clean or change the bulbs and their sockets.
P71_CrownVic
No, the battery never seems to be losing a charge...but I usually only have the stereo on while running.
I have a basic Alpine stereo running 4 speakers and then an Alpine amp (I'm guessing around 1K amps) and a cheap $30.00 Walmart sub. I just wanted to make sure the gauges jumping all over isn't a sign that something is being damaged, etc. |
TX Foilhead
A second battery for the amps should fix that. Basically your giving the amp a seperate resivoir to use so it won't pull down the voltage on the house battery. A Perko switch would allow you to seperate the 2 batteries when your parked to save the starting battery, an ACR (auto combing relay) would do it without you having to flip the switch. Upgrading the alternator would give you addition amps to use for the stero and the battery charging, but is probably the most expensive way to go about it.
I would try the battery first, check you battery voltage at the beginning and the end of the day. If batteries are staying charged your good, if they aren't then an onboard charging system will top them off and prolong their life. I don't think you really need most of that stuff unless you upgrade further. I ran 1000 watts off one battery for a couple of months with no issues as long as I put it on the charger at the end of the day. After adding all that and a 105 amp alternator it takes 10 minutes to top off the batteries at the end of the day and I can sit and listen for at least 8 hours then start the boat. My stereo is still growing into all that, I'll be doubling the power this winter and adding tower speakers. |
lewy2001
Matt the dash of the SN's of your ones era were known for their bad earthing and power wiring (daisy chaining). Run a couple of separate earths up to each gauge from the earth bus and see how that goes. Clean all the connections while you are there as well.
00cls1camaross
So anyways, I cleaned the connections and it did not help. What I did figure out were two things.
On the positive lead to the voltage gauge on my dash, there are 3 wires. -one coming from the bus -one going to the little horn thingy that beeps at me -a thick one that I can't figure out If I only attach the wire coming from the bus, the voltage will read 12 volts. If I attach either of the other 2 wires to that screw, it drops the volts by 1.8. Anyone have any ideas? |
Bri892001
Any pics of the bus etc.?
Also, is the stereo the only thing that messes with your gauges? Or will the horn, lights, blower or bilge pump have any impact? |
P71_CrownVic
I assume this question was for me. When using various electronic equipment (blower, bilge, nav lights, etc), when they get turned on, the gauges move ever so slightly. The same exact thing happens when I turn the nav lights (or another accessory) on in my Grandma's 2004 Bayliner. The needles move maybe 1/2 a needles width. I'm sure it's nothing major... |
Bri892001
Matt, Yup, I meant the question for you. I was wondering, because if they moved a lot, it might be just a ground issue. I had to run a second ground (in tandem with the original) from my motor to my dash. You could also use the battery ground.
Where does your amp get it's power? Is there a dedicated positive wire from the battery to it, or are you picking up power off Edit: off the DASH wiring? |
I will back up Mark (lewy2001). It's been well documented about the undersized wiring. Doing a search will bring up plenty of info.
P71_CrownVic
Amp get's it's power straight from the battery. Like I said though, I don't really care about the jumping needles as ling as I'm not harming anything...which it sounds like I'm not. |
