  New Posts New Posts RSS Feed - props
props
Gary View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Topic: props
    Posted: June-10-2005 at 6:12am
hi, i have a '85 2001 and i just can't get it to go. i'm a barefooter and would like more top end.
i've been working with the prop but can't get the right combo. i'm running a 1313 oj legend. but trying to get it back to 4400 at 44mph. i'm at 42.6 on my gps now at 4200. johnson propeller is working with me but its a long process to get the right cup and pitch. Does anyone have any sugestions? i've also worked with my mich. prop 1313 cupped. but haven't had much luck either to get it up to 44-45mph? correct craft told me this boat is supposed to go 46mph. yeah right? i've done all the engine work i can for a stock motor, timming, ign, plugs, manifolds, ect. and it runs fine. but it just won't go top end. i like my boat and don't want to sell it, i bought it brand new.
help?
       Gary
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2005 at 12:52pm
You need to talk to ACME props. Call Jim or Todd at 888-661-ACME. You will probably need to get away from the original 13x13 to get your rpms and top speed up a bit. I am no prop expert, but the guys at ACME certainly are and are very familiar with your boat.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2005 at 3:03pm
Gary,
It sounds like the only mod's you have made to the engine is basicly replaced the intake with an aluminum one. Have you replace the dist, with am electronic one or conversion kit? With out making more mods to the engine you are not going to be able to get the speed you want. If you increase pitch to get more top end you will loose hole shot. Where are you located? If you aren't to far from nothern Indiana I would let you barefoot on mine if you can deep water start, and you'll just have to tell me how fast you want to go so I know which prop to use.
To get the power out of the 351w you have to replace the heads, or rework yours with bigger valves, replace the cam, and balance the engine. There are several people on this site that has done this and can go over 50 mph and there are others to go over 60 mph. the stock cam just will not produse the torque needed for high speeds. You don't have to do all of the mods but I doubt that the cam alone would be enough, the heads would restrict the performance a little. Replacing the heads only might get the job done but it can get expensive depending on how you choose to do it, buying new vs. reworking or getting used heads. A lot of people use the GT40P heads, I have D70E on mine but they have been messaged a little to flow better.
Ron View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2005 at 7:09pm
Gary,
I can't believe you didn't even send me a thank you for steering you to this wonderful site. Anyways give a call if your coming by this weekend, as I will be in and out.
//Ron
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2005 at 1:31am
Gary,
You've apparently had the boat nearly 20 years now, so congrats on a nice long relationship. I guess we're understanding that it ran 44mph and 4400 new or some time ago, and that's where you want to get it back to. While my boats run great with the OJ props, which are my currrent prop of choice for top speed, these props are not apples to apples (size wise), at least from my experience, with the original Federal/Michigan wheels, i.e., a 13x13 OJ may not be a direct or adequate replacement for the 13x13 Mich, rpm wise. When switching from the Fed to the OJ, I had to drop an inch of pitch to keep the same rpm and speed increased slightly. The reason behind this has to due with the rake of the OJ prop which is another whole thread discussion. Does the orig Mich prop only turn 4200 as well when you've recently tested with it? There's a whole new world of speed out there as bc, myself, and others can attest, but I feel you've got something else holding you back right now unless she's just plain tired.
ReidP
1973 Mustang
S.T. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote S.T. Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2005 at 2:21am
http://www.correctcraftfan.com/articles/ACME_540_Prop.asp
SS 201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2005 at 8:26am
Before changing props be sure in your heart the engine has all the power it had from the gitgo. Engines with excessive hours especially 351, 460 Fords came with a 8 degrees retarded chain and sprocket from the factory. With more hours it gets more retarded.This takes away the top torque, hp power. All over the counter replacement chain sets are not retarded.If you have the 123 tranny, its worse. OJ haas 75 years of experience plus Eric has raced Formula 1 for years.
When you play one prop againt another without the power you are not on level playing field. I have run OJ props againt $850.00 - $1000 custom props and his props are within 100 200 rpm difference, the best bang for the buck.
Every boat is different, glass boats that sit on a trailer will change the bottom, so there are manty things to consider.
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2005 at 7:02pm
In my opinion, the bolt-ons to a 20 year old engine can be OK at best, especially since you're really gonna put em' to the test. Pulling a barefooter at 46-50 mph is tough duty. You may want to compression test your engine since that's were it all begins. If you've been using that boat for 20 years pulling that hard I'd bet $'s to donut's she's a little tired at best.I increased compression on my engine to 165 psi and she'll still burn pump gas and pulls great at low end and high end. Then we worked the heads over and saw a little more gain. Going over 4500 rpm will take more exhaust and intake work but it would be worth it especially since if you've owned her for 20 you'll probably enjoy the mod's for 20 more.
That's very impressive to hear from a 20 year owner! And then a 20 year owner who can barefoot.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
Dawg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2005 at 11:51pm
I have to agree with those that look to the heart of the power... the engine. I would start there. A compression test will tell the tale and is very easy to do. When I got ready to re-prop my 86SN,I did the test and found I was @130-135psi on all my pistons, pretty good for an 86'.Then I went to the Acme folks, they hooked me up with a prop that got me spec RPMS and 4mph more on the top end @47mph. Tandem Barefoot, no problem. Good luck.
DAWG 99NSS
Dawg
