Fuel pump relay failed. |
Author | ||
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1809 |
Posted: July-05-2020 at 3:51pm |
Well, cheers to having that spare fuel pump relay, as it saved the day on the water. Launched the boat this morning, cranked it, and it soon died, wouldn’t restart. Turn key on, no pump sound. Swapped out the one relay (the one on the dongle) and was GTG 🙂 I’ll change out the other and put a couple more spares on board.
Bringing the following back up:
Or just buy plenty of spare relays. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10700 |
You could read the rest of the thread that Pete pulled that quote from if you click on the link below
link Then you could probably say "yep, I (and the previous owner) got my money's worth from that relay and carry a couple spares like you plan on. To quote someone here on CCF..................."keep it original" |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2863 |
Note to self: “buy spare fuel pump relay for boat glove box...”
JQ Write that note twice or make your note say "buy 2 relays" Since the ECM relay and the fuel pump relay are the same relay and a bad ECM relay will not allow power to the fuel pump relay, it's a lot easier to "shotgun it" and replace both at the same time instead of swapping relays around to figure out which one is bad when you're 20 miles from the launch ramp Then later on you can figure out what's good and what's bad |
ultrarunner
Yep, always replace in pairs. My second one here tomorrow. Plus two spares. Odd my NAPA didn’t have them.
Didn't have the specific brand you wanted? They are generic. |
I just figured I'd post this from an older thread and all those Caddy words will probably send Pete on a trip down memory lane The part number is Echlin AR-174
ultrarunner
Yeah, wanted the USA Hella. |
Kevin's '79
Senior Member Joined: March-05-2004 Location: Florence, AL Status: Offline Points: 178 |
I just bought 2 Hella Relays from Nautique Parts. What P/N do you buy from your local auto parts store?
Thanks(1)
I wouldn't mess around with just a couple spares. Go for this to keep on board
The Hella relay in the link or any of the Hellas in the cross reference at the bottom of the same link will work link |
slmskrs
Gold Member Joined: January-03-2012 Location: SF bay area, CA Status: Offline Points: 522 |
I think a few spares is the easy way to go, but rather than a diode, why not a capacitor? At least in the olden days, that's how I got rid of arching on a relay.
Gordon '97 Ski Nautique, GT40
