Green Lake 2014 |
Post Reply | Page 123 4> |
67nautique312
Gold Member Joined: June-23-2004 Location: United States Status: Offline Points: 883 |
Posted: November-05-2014 at 3:02pm |
one downfall with points on a boat is moisture...causing no start! easy fix but dont really have that problem with EI.
67 Riviera 68 barracuda 1971 Ski Nautique Promo 86 Silver Nautique 1995 Ski Nautique |
800wildcat
Senior Member Joined: July-05-2010 Location: Ripon, WI Status: Offline Points: 121 |
Good one Moj. So far, I have gotten a call half way through the season each year about them having trouble getting the boat started or staying idling when putting it in gear. I reset the dwell on the points and it solves the problem. It does seem to me that the points that were on it go out of adjustment more rapidly than points usually do. Unfortunately, it seems to affect their perception of the reliability of the boat. It may be contributing to their consideration of selling it. An open bow would be more ideal for them. But we'll see how long the stern drive unit they just had donated at the end of this season lasts. If and when it dies, maybe at that point I can persuade them to look for a Sport Nautique (9 passenger vs SkiTique's 5).
And tubing puts more load on the drivetrain than skiing. Don't know if they even have anyone that can teach kids to ski right now. I'm still trying to get them to remember to at least pull the plug when it's going to rain....[rolls eyes] |
Mojo
Dan, is all this necessary to drag kids around on a tube in the bay??
05' SV211 TE
800wildcat
The unit I installed cuts the field current collapse time in half compared to points, thus the increase in spark energy. Dwell time at high RPM can also increase compared to points allowing for a stronger and more consistent spark and spark timing. So to whatever extent your switching mechanism affects dwell time and field current collapse time it will also affect the spark strength. Point operation degrades over time and with increased RPM. That isn't acceptable to me. If I was a rich man, I would have just installed a MSD unit and used the points as the trigger. Of course, I'm hoping the reliability of the unit I installed will be acceptable. Hall effect units have done quite well in cars. We'll see. |
Geez the only thing more tired than Pete's old points is this old argument....
You won't get a hotter spark out of an ei conversion kit- spark strength is determined by the coil. All you did was change the triggering mechanism. The only way it could account for the performance improvement is if the points were improperly adjusted beforehand.
I have found the cost, reliability and failure mode of points to be far more acceptable than the ei conversion kits... But to each their own! |
800wildcat
Be serious Pete, any motor that gets run a couple of hours a day, 5 days a week for most of the summer isn't going to have the points stay in adjustment for 20 years. Even with grease on the rubbing block, it's going to wear, especially after the grease dries out. And after it ran for 20 years without being touched did you put a timing light on it and verify the timing hadn't changed? To me, there's a difference between still running and still running with timing unchanged. And an automatically adjusted dwell is something no point set can accomplish. Or do you like that bounce at high RPM? Or do you just set your points with a matchbox cover and call that good enough? Points are known to fail worse than magnetic pickups. It just might be why auto manufacturers converted.... |
Point set going out of adjustment? I've had them run for 20 years without even touching them.
The conversions are know to fail. Better performance? Did you get your point set from Auto Zone? |
800wildcat
The sealer I used was K&W, it's the type that you need to drain and flush the antifreeze completely out of the system before you use it and then drain and flush the sealer when you're done with it. Didn't need to worry about antifreeze in the boat, of course, but it appears to be pretty good stuff. I checked compression on the bad cylinder after sealing and it was back up to 130 psi, which is the same or above what the rest of the clyinders tested. And, as I mentioned it was reading at least 53 on the speedo, and I haven't seen it past 51 for the last two summers or since I had the prop repitched. So maybe the leak was dropping performance slightly (although it always seemed to start, idle and run fine until they had trouble with it half way through the summer) or perhaps the Hall effect unit is giving it enough stronger spark to improve the performance by that amount. Since I made both changes at the same time, I guess I can't verify how much which item contributed to the improvement. I'm thinking both played a part. Either way, if the camp keeps the boat and I can bring it over next summer, I'll be looking for a few heavyweights to sit in the back and see just what it might be able to do now. Perhaps it'll be fast enough to be able to keep a certain barefoot Nautique in sight - with binoculars.... |
Dan, Thanks for the response. I hope the sealer holds out. Why did you get rid of the point set? |
800wildcat
Camp Grow had another boat donated to them (a stern drive) and may possibly put this one up for sale. I've suggested they keep the SkiTique for a backup, but they're a bit tight financially right now and may choose to sell it. I wish I was a bit better off financially right now - I'd be real tempted to buy it. |
Dan, Not being at the reunion this year, I don't know if you make it or not? I don't see where you answered as to what the problem was. |
scottb
Senior Member Joined: July-05-2006 Location: Bolingbrook, IL Status: Offline Points: 376 |
Here are a few more pics from the weekend.
The Godfather
Platinum Member Joined: August-13-2008 Location: Orlando Fla Status: Offline Points: 1766 |
gotta love that green machine |
Jbear, said to me wow if it was'nt for this site we would never had met for this to happen....
81nautique
You'll have to step it up Gary, 15.9 up 15.1 home. That headwind on the way home pretty substantial. LOL |
81nautique
Back home no problems all weekend, great trip with great friends. Low key weekend with more time around fires than the Goose, it sure was great to catch up with everyone.
And yes we ran the snot out of the 200 which we just love doing. We ran for 3-4 hours solid each morning until it really started blowing. Sunday night was some good water as several of us shut down Norwegian bay. It's really great to pull people around that don't get the opportunity like we do. As Dave said it was nice to go to GL without an agenda to follow but I'm also looking forward to 2015. Lots of townies I bumped into were asking where all the Correct Crafts were so they miss us! |
The photographer didn't even take a pic of her own boat! The Mustang
pictured still has it's 2bbl 260 and the Avalanche well it got a blistering 13.1 on the way up and 11.1 on the way home,try and beat that Alan |
Mojo
bwahahaha, I was just reading some old contracts from 2013 haha. That's what you get for doing two things at a time.. Duh' |
05' SV211 TE
only pic's from '14,you'll have to wait till next year for review.
That's nice but how was GL14'?
Mojo
Recap,
Yes GL14' was a small, more "mini" like reunion. For us planners, it was actually quite nice, as we were able to take in the group activities a little more without any heavy lifting. It was the first time in 8 years were me and my family actually hit the water on Friday afternoon. Anyway, GL14' was also great as we had the pleasure of meeting a new CCFan'er (you can see the rasberry color'd mustang in the picture above. John and is wife and friends came out from Racine for the day, which was great. Along with a suprise vitis from Quinner, and to see Scotts new 200 Sport was awesome.. You really can't see the cool blue metal flake gel, which looked really cool in the sunlight.. GL14' wouldn't dissapoint with usually brutal water conditions, with constant winds from the SE, but we were able to get some water sports in. And Alan and Dana doing most all the heavy lifting, kept all the kids wanting more... My girls had the best surf session they've ever had. They really have the 200 dialed in perfectly. So a special thanks to them for their timeless effort and generosity to always want to pull someone. Gabs will always remember Sunday afternoon !!! Speed runs in Pauls beautiful 71' Promo was awesome.. Next time, I'll really hammer on it hahaha. And always good to see Steve's Classic, as it came out of hibernation to make the party !!! Some brats, chops and rubber hotdogs over a campfire rounded the evenings. And with a lot of laughs in the end, I'd say it was a great success !! Next year it will be official, so mark you calendars !!!!! Thank you all for coming. Moj' |
05' SV211 TE
OverMyHead
Thanks for the pics, keep them coming. I hope everyone got home safely.
1987 Ski Nautique |
The Godfather
Nice Photo of the 200 Sport !! |
What a great picture. Sorry I couldn't make it this year, had a band concert going on.
in one word-- yes
OverMyHead
So what happens at green lake stays at green lake?????
1987 Ski Nautique |
OverMyHead
No News, can't somebody throw a dog a bone?
1987 Ski Nautique |
OverMyHead
And now the wait for pics. If only I could have magically woke up in a tent at Hattie Sherwood this morning.
1987 Ski Nautique |
