  New Posts New Posts RSS Feed - ---
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:21pm
Hmmm, so did you figure out if there was a blockage at the hull fitting? Or is it just that the Fake a Lake wasn't doing it's job?
The pulley alignment thing has come up before... It should be in line, but others have said that it's sometimes not in line to start with.
waker319 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:14pm
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:21pm
Any chance your temp gauge or sending unit is bad? Do you have a infrared thermometer to double check?
just a thought...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:20pm
Originally posted by waker319 waker319 wrote:
I tried doing a search for "the bucket test" but couldn't find a thread. I feel getting it off the hose and and doing the test may tell alot.
ok, im doing this next... so to do this, do i use the hose right at the hull ( before strainer and transmission cooler) or can i use the hose right before the pump? (between the pump and transmission cooler)
Use the hose at the through hull fitting. Then, the strainer and cooler will be included in the test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:08pm
Originally posted by watrski watrski wrote:
Unless you let your RWP suck water out of a bucket you are just going to continue chasing your tail.
Agreed.
If you have the 1.23 transmission, then you have a LH rotation motor. If you have a 1:1 transmission, then you have a RH rotation motor (and in which case, your RWP would be installed upside down).
Look at the tag on the transmission, it will tell you the ratio. Or give us an overall picture of the engine- the mounting angle is different between the 2 set ups. Or, give us the serial number off the tag on your intake manifold- it has all that information built in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:07pm
watrski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:02pm
It looks like the screw on the body of the pump is facing in, which is correct IF he has the (more common) 1.23 trans in his '94.
Any chance you have the old impeller around to try? I think I see the key in the shaft of the pump, so the impeller is probably spinning. Ive heard of impellers becoming separated from the hub though. Is this an OEM sherwood impeller?
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:57pm
i strongly believe it must be something with the impeller cuz i never had a problem before... this just happened after i replaced it... can someone confirm if i had replaced it correctly?
Just for laughs, see if you can confirm that your impeller pulley is definitely turning the shaft. I thought I read something on her about a key coming out of the keyway, and then the shaft wouldn't turn the impeller.
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:54pm
I was talking about the bottom of the transmission cooler. They get clogged sometimes
83Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:54pm
It looks like you have the 1.23 transmission, is that correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:52pm
And you're really sure you didn't somehow rotate the whole pump body around by accident. AKA, which way is your impeller set screw facing?
Check out these directions, they make it pretty easy:
http://aquaskier.com/articles/impeller_replacement.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:48pm
[QUOTE=waker319]
(( the first picture is something i saw after the strainer (in order as in coming in from hull intake) it looks like a filter but theres hoses coming out to engine block and tranny... i checked for blockage but it was clear... ))
That is your transmission cooler. You did check the bottom for blockage?
83Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:41pm
1989SN2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1989SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:41pm
If you're getting plenty of water out the exhaust, perhaps you have a blockage or you have a circulation pump issue. Is the circulation pump turning freely? Excessive shaft play? If the circulation pump is not working, the RWP would likely supply enough pressure to push some water through the engine, but not much, perhaps this explains the 160 with no tstat and 200 with a tstat.
Has the engine been rebuilt recently or had the heads off? Head gaskets can be and are often installed backwards on the SBF engine and will result in running very hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 4:36pm
Still, it shouldnt take a ton of water to keep the engine cool at idle, in neutral.
Not much at all. A gal. of gas contains 114,000 BTU's. At idle, it takes quite a long time to burn 1 gal. Removing 1 BTU, one pound of water will only increase in temp 1 degree and we all know the cooling water gets hotter than a delta T of one degree.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 3:15pm
Im not assuming anything... but if he's supplying very low water pressure to the RWP, then Id still say thats a water flow problem, not an air leak problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 3:08pm
1. You have an air leak.
If these symptoms were on the lake, then I would agree. But I run on the trailer with a gross air leak (I do not shut off the intake grate path on my tee'd water input) and never run above 160.
The fact that he runs 160 with no stat is indicative of a water flow problem. I think the the RWP test is a good place to start.
TB-
You might be correct, but you are assuming that he has the water turned up full pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 3:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 2:53pm
2. You might have put the pump on backwards and the hose is pushing enough water to keep it around 195.
Put a hose from the RWP into a bucket full of water (with the hose filling it) and see what happens. If it puts out bubbles you have the pump backwards. If it cools it you have a leak between the RWP and the inlet.
