  New Posts New Posts RSS Feed - rpm’s
rpm’s
hspencer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hspencer Quote  Post ReplyReply Direct Link To This Post Topic: rpm’s
    Posted: May-14-2005 at 12:51am
Does anyone know what the proper rpm range is for a older model(1976)pcm 302? Thanks
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 1:05am
They claim intermittent service MAXIMUM of 4400 rpms. continuous of 3600 rpm. I run my mustang 17 at about 4700 or so wide open throttle, but rarely keep it there. It allows for props of less pitch for a better pulling power.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 1:32am
Jeff, Is that right? I've been running my '68 289 up to 5300 or 5400 and cruising at 4800. Maybe I need a bigger prop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 1:44am
Jim in houston, it certainly sounds it to me! Unless your engine was modified heavily, your not gaining any extra. A few pithces higher would make the engine last longer if your cruisin around the lake. The prop you have is good for pulling a dozen people out of the hole. You will get a heck of alot better gas mileage with the right prop. My mustang 17 has a prop(12x15RH) where the hole shot isnt great, but i can cruise all day on a tank and the top end is about the same. I also have a 12x13RH for serious pulling.
Bhedbloom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bhedbloom Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 3:06pm
I'm with Jeff on this one. I,m still running the original prop 12x15 RH on my 1970 Mustang 235 HP. Max RPM is 4500 RPM @ 42-45 mph. I'm a 200+ pounder and it pulls me up on a traditional slalom just fine. Any RPM's greater than about 4000 for extended periods of time aren't good on large V8 engines anyway. Unless of course you like to rebuild every few years.
Barry, South Carolina
74 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 3:22pm
Continuous service on my 302 in 4100 and intermittent is 4400. You can dowload the manuals from this site, and they have all of the useful info on all the older models.
Shake and Bake
1974 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2005 at 12:22am
The newer engines have a bit higher rating like 5000 rpm max.
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2005 at 9:38am
My '63 was the same as what Jim stated. Easliy run to 5000 plus rpm's.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
Post Options Post Options   Thanks (0) Thanks(0)   Quote hspencer Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2005 at 12:07am
Thanks for all the help.
