control cables |
![]() ![]() ![]() ![]() ![]() Posted: June-04-2007 at 7:27pm |
anyone know the correct length for the shift and throttle cables for a 79SN. how about apart number for the red jacketed tele-flex cables isn't that what I want or are the u-flex ones at Skidim ok?
MaddMarxx ![]() Platinum Member ![]() ![]() Joined: June-29-2006 Location: United States Status: Offline Points: 1741 |
they are 17ft, I need a set too, can you get me a price!!
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3337 |
A place across the street makes up Cablecraft premium SS cables while you wait, right in front of you, then stress tests them. Thats the way I'm going next time. O-ring sealed too.
There is only one rep per state, but maybe one is near you? |
Another option is White Lake. They have the 17' cables for $40 each before our discount is applied.
Control cables |
behindpropeller ![]() Platinum Member ![]() Joined: July-31-2006 Status: Offline Points: 1810 |
After breaking a couple of junk U flex chinese ones I went back to the red jacket supreme.
Tim |
do you have a part numbers for both cables and/or a source as well? |
rex marine...has the red jackets for about $35 dollars, I will try to post the link later!
Here are the red jackets, check them out.
Only $30.99 |
I saw those Mark they are actually a little cheaper on the site I list also they are the 1/4-20 threaded ends and not he 10-32 we need. The cables that I listed are the new Extreme cables from teleflex they are suppose to be better than the red jacket cables for 20 bucks more. These are sold single and I need to order two cables right?
yeah..you should do them both at the same time!
So you say we need the 10/32 ?? |
I believe so I won't be able to check mine untill next week so If you could take a look at yours to confirm I would appriciate it.
Oh and I'm bring a secrete weapon to GL for the races, going to bring about a 100 bucks worth of C14 for the boat. |
whats c14????? are you talking fast gas?
yes
Yeah...I was planning on having something like that in my tank to, its good for about 20 more hp!
79... can you post a pic of your manifolds and the elbows, you were talking about, and any other parts you think I may need for mine..thanks.
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5776 |
Better plan on bringing more than a $100 worth, Green Lake is so big we burned a tank of gas each day we were on the water last year. Your gonna need a tanker and a valid credit card. ![]() |
a tank a day, are you kidding me!!
well you can't run straight c14 to start with and at about $15/gal you don't want to.
Nope, I left the boat in all weekend though so with the 4 of us boarding, skiing and cruising we were would come back on fumes each day. Its also hard to stay out of the throttle with all the hardware in the water and onlookers but what fun would that be anyway. We also paid for dock fuel cause it's a pain to move the motorhome twice a day to load/unload and run to the gas station. What the hell it's only money right. |
your's are a little different than mine from what I remember send me a picture to verify please. I don't have a picture of mine assmbled yet. Your's have one inlet on the front then a jumper hose for the snails at the rear. The main thing your going to need is to replace the snails/risers with elbow to get them under the motorbox. I would do a dry fit first to see if they clear the motor box. Also I believe your's all readyt has the fittings on the front for the hoses. Send me a picture and I'll give you a ring to talk about it because I have alot more stuff to hook up than you have too and one piece I got lucky and found over at Horner's in Tampa otherwise I wasn't going to be able to hook up the 1" coolant lines to feed them. |
