  New Posts New Posts RSS Feed - ---
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:02pm
It looks like the screw on the body of the pump is facing in, which is correct IF he has the (more common) 1.23 trans in his '94.
Any chance you have the old impeller around to try? I think I see the key in the shaft of the pump, so the impeller is probably spinning. Ive heard of impellers becoming separated from the hub though. Is this an OEM sherwood impeller?
waker319 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:04pm
watrski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:05pm
Unless you let your RWP suck water out of a bucket you are just going to continue chasing your tail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:07pm
I tried doing a search for "the bucket test" but couldn't find a thread. I feel getting it off the hose and and doing the test may tell alot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:08pm
Agreed.
If you have the 1.23 transmission, then you have a LH rotation motor. If you have a 1:1 transmission, then you have a RH rotation motor (and in which case, your RWP would be installed upside down).
Look at the tag on the transmission, it will tell you the ratio. Or give us an overall picture of the engine- the mounting angle is different between the 2 set ups. Or, give us the serial number off the tag on your intake manifold- it has all that information built in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:20pm
Originally posted by waker319 waker319 wrote:
ok, im doing this next... so to do this, do i use the hose right at the hull ( before strainer and transmission cooler) or can i use the hose right before the pump? (between the pump and transmission cooler)
Use the hose at the through hull fitting. Then, the strainer and cooler will be included in the test.
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:21pm
Any chance your temp gauge or sending unit is bad? Do you have a infrared thermometer to double check?
just a thought...
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:14pm
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:21pm
Hmmm, so did you figure out if there was a blockage at the hull fitting? Or is it just that the Fake a Lake wasn't doing it's job?
The pulley alignment thing has come up before... It should be in line, but others have said that it's sometimes not in line to start with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:25pm
Leo,
Congratulations on the fix but you never really stated what the problem was. I can't really imagine it was the Fake-a-lake? Post a picture of what you are using.
Yes, that RWP is way out of alignment. Somethings up with the bracket. Look into it otherwise you'll be chewing up plenty of belts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:37pm
Leo,
In order to save the pump, you may need to install a thread insert (helicoil) in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 7:25pm
ive never used that before... is that a tool ill be using to create a thread for the bolt or ist and actual inster i gotta put in that hole?? im assuming if i do that, itll force me to use a thiner bolt correct?
A thread insert actually has male and female threads. The female threads match your existing bolt. The stripped hole is drilled and tapped to match the male threads of the thread insert. It's screwed in and you have new threads for your old bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 7:30pm
Leo,
I really can't figure out what the problem was with your Fake-a-lake. By chance did you have it so tight to the hull that it blocked off the water supply?
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 8:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:09pm
Some like the RTV but I HATE it! what do the gasket surfaces look like? Did you do any flat filing on them? Is the housing flat and not warped?
There are some cases where the RTV must be used but this isn't one of them. I actually like the old Permatex #2 which is the non hardening. I'm just "old school" but, i have NEVER had a problem with it - yes with RTV!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:19pm
When I did my thermostat I used some Permatex Hytack to keep it in place.
Is yours just a slow drip or pouring out?
I had a slow drip when I first did mine. A couple rounds of snugging up the bolts slowed it down. Then, it kind of worked itself out. I don't know if the gasket had to plump up or a couple hot/cold cycles cured it or what.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:30pm
I like permatex av form-a-seal, but that may be the same as #2? And you did prep the mating surfaces?
Check to see if your pump case is stripped or cracked. I had a cracked one...those brass/bronze cases can't take much crankin'.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote waker319 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 1:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 1:44am
kink in garden hose.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 2:11am
my money is on air leak at thermo housing or at one or more hose connections/clamps
Also my boat shop owning friend has advised me against that type of fake a lake because it can fall away from the hull from you jumping in and out of the boat. I use the type that has a little metal hook that grabs the intake grill and then you push it up and it it "locks" in place tight to hull and won't fall away from boat moving around on trailer/springs.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 2:14am
you still need to get that pulley aligned-whatever it takes
This is the life
