  New Posts New Posts RSS Feed - Choice of sealant or epoxy
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Topic: Choice of sealant or epoxy
    Posted: March-20-2012 at 12:07am
What product should I use for attaching / sealing the following to the boat hull on the 63 SN?
Strut
Tracking Fin
Rudder Assy
Water Pickup
Drain Plug
Wood floor braces to stringers
Thanks,
Phil
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2012 at 10:19am
Floor timbers get tabbed with biax or roven.
All else on your list use 3m5200
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2012 at 11:20am
We used 5200 on all the through hull fittings on the BFN. It may be overkill, but works great. 3M 4200 or Life Boat caulk are also good choices, and may allow you to remove those fittings sometime in the future without pulling off the surrounding gel!
Id like to better understand what you have planned on the "wood floor braces to stringers" before commenting. I would say you will want to use some sort of fiberglass, but exactly how you install them will depend on what you are working with- glass type, etc.
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2012 at 12:40am
I was wondering if the wood strips that run perpendicular to and fit in the notches in the stringers should be epoxied and screwed in place or just screwed.
Thanks,
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2012 at 1:30am
I wouldnt screw them at all. I would bed them to the stringers with thickened epoxy. Even better, tie them to the stringers with a few pieces of glass afterwards as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2012 at 8:10am
Phil,
I agree with Tim - no screws. A screw is just a high stress point. Glass all the components together.
70CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70CC Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2012 at 8:51pm
Thanks Pete, Tim!
That's what I'll do.
