No Super Sucker needed |
Post Reply | Page <1 34567> |
My stop at Napa yesterday was primarily to get piston rings on order. I was pretty disappointed with my beloved Napa store. I'm getting the impression that it won't be too long before the sign out front is changed to read "Autozone"!!!
I went in with all the Hastings rings part numbers. This was after I called and spoke with Hastings tech service. I called because I couldn't find rings wide enough on their site to replace the original 3/16" wide rings. They make a oil control ring 3/16" but not a compression ring. I discussed with them the possibility of using ring spacers but the tech person felt it better to use two 3/32" ring per piston land. Purchases can't be made directly from Hasting without setting up a wholesale account so they told me any Napa would be a great choice. Well, none of the Hastings numbers would cross over to the Napa numbers in their system. None of the numbers would even cross over in Napa's master distributor system as well! No good old books anymore so if it's not on the computer these days you're screwed!! Seems no one can get on the phone anymore and make a purchase without having the damn numbers in the computer! The master distributor started from scratch and went back to bore size and ring width pulling up his own numbers. Surprisingly I do have rings coming in early next week but I'm going back in there with my dial calipers in hand! I also have no idea of the quantity I'll see. They were totally confused as to the "set" quantity being for 1 piston or a four cylinder engine and then thowing in the need for twice the amount of compression rings needed made it even worse. Considering the cost per set was $23, I think it's for 1 piston. I ordered two sets and will see when they come in. I may end up having to buy 6 more sets! And people wonder why it costs so much to rebuild a engine. Of course it's obvious not many do anymore unless that engine is old and rare. My Napa closed down their machine shop in 2002. No business! Before paying, I made sure that I could return the "special order" so it was noted I could on both the computer and the paper work. |
Your right Pete it does say 18mm,and now you mention it I seem to remember Warshawski used to sell a adapter for Model A Ford plugs.
Gary, I just came from Napa after getting plugs. First, I was surprised they had them and then I thought the D-16's (old Champ # 8 COM) looked small and they are! Thank's for trying but it turns out your tractors use the next generation plug which is a 18mm plug and not the 7/8-18 thread Champion "W" series (old Champ 0,1,2 and 3 COM). I'll take the plugs back, guess at the heat range and get them to order some. So, the tap you have is probably the 18mm. |
Charlie,
Now that you mention it, I do remember seeing one over at Watercraft. It must have been very short lived. I think the whole product was short lived and think it had something to do with the exhaust problem Chris mentioned. Chris, I don't know how they expected to suck in fresh air. On a calm day I'm sure it wasn't the greatest air going down to the diver. 2 stroke air as well!! |
I remember the aquanaut, though they were neat at the time!
How did they keep the exhaust from getting sent to the diver? |
Brady
Senior Member Joined: June-28-2008 Location: Lake Elmo, Mn. Status: Offline Points: 226 |
Pete,
If I remember correctly, Watercraft did have the Aquanaut for a short time, and I think they may have rented them. I do remember seeing them being used several times |
Charlie
Three Lakes, Wisconsin 69 Barracuda |
Wow, that's going back a couple! I always wanted to try the Aquanaut but up north the lakes are pretty dark due to the orange tannins so no one had one. You forgot a OMC product on your list. The Playmate. That's the small gull wing they used their outboard 90HP 2 stroke power head in hooked up to their out drive. |
Naw Pete I was thinking more of your Lawn Boy mower,your Johnson Skee-Horse and your Evinrude Aquanaut
Keegan,
Well you got me thinking so I went and bought a parts washer! Bid on/won a 20 gal. with stand, drying tray and pump off ebay for $75 and only $8 for shipping. My shop is really set up for woodworking but I figured why struggle with a oil drain pan, solvent and a brush cleaning parts so I'm expanding into equipment more for engine rebuilding. This is the 4th engine (all flat heads) I've done but the previous 3 were done when I did have the luxury of having a parts washer at work. Now it's onto what will go into it. At work we do use a citrus based cleaner in a production belt type aqueous washer that removes a grease based buffing compound. I'm going to have to sample a gal. of it and see how it works after playing with the water mix ratio. I'm on city sewer here so disposal won't be a issue. When the parts washer is moved up north then it will be a problem because I'm on a septic system. I'll need to look at spirits then. |
Keeganino
I would have done the same! You can buy new parts for that kind of money. I have a hazmat dump station close to my house but did not really think about what a pita and how expensive it would be to use a parts washer. |
1973 Skier |
Gary, What 2 strokes? The little 18 on the Alumacraft I grew up in? |
Pete, I normally buy Bug and tar remover for the tanks and 35 gallons was around 185.00, well i ordered some about 1 month ago and the guy personally delivered it in his caravan, he seemed in a hurry and i asked him how much the 35 gallon drum was.................................510.00, i told him put that mfr back in your van.
Feeling guilty after all those years of running 2 strokes Pete ?
Keegan, I know there's plenty of washers out there that are real cheap. It's what you put in them that costs more!! Then, what do you do with the old dirty solution?? If a petroleum based spirits is used, I can't get Safety Clean to come to my house! If I used a aqueous solution it's more expensive plus difficult to control rust inhibiting. Then there's the disposal with it when dirty. The solution itself may be biodegradable but what's in it (dirt, oils, carbon) isn't. You just can't pour it down the drain. I still wish I had a washer but it's just not as easy as running out and getting one. Now I'm using a solvent, rags and a oil drain pan. Left over solvent is evaporated and the pan is wiped down with rags. |
Keeganino
Harbor Freight has a 20 gallon parts washer for around $180 bucks and a little 5 gallon for $45.
I am loving this history lesson Pete! |
1973 Skier |
I guess I should check the posts right before I go out and look---- I do have one if you still want,it's already in the car for the chicago beers
Eric (and Gary), No need to look for the tap. I made a "tap"! When I got the engine, someone had at one time made a lifting ring out of a old plug by removing the porcelain and welding a ring on it. It came with the engine so I chucked it up in the lathe and turned the shoulder on the body back a 1/2". This allowed the "tap" to enter the head all the way through to the other side. Then I got my Dremel out and put the cut off wheel in it. I ground "teeth" at right angles to the threads by cutting grooves across the threads. Worked great along with some Tap Magic. I did have to "resharpen it once - the cast iron is harder that the steel spark plug!! |
i might Pete, I'll check today
Gary, Or anyone?
You mentioned a Flex-hone (ball hone). I'm going to order one and was wondering about the grit size. 240? 320? Also, since you have the old tractors, you don't by chance have a 7/8-18 tap? I need to chase the threads in the head for the spark plugs! |
M3Fan
This is a really interesting thread. Keep it up!
I have been making some progress but with small things that really don't show much has been done. I spent lots of time this weekend with a good rough cleaning of most of the parts. Having the block and some other parts like the head, manifold, etc. boiled out is still a option. However, besides the cost of a couple hundred, I want to avoid the boil out because I don't really want to deal with the cam bearings. They need to be removed for boiling.
It's always amazing how much dirt and grime a old engine will accumulate. I wish I had a parts washer!! Here's the cast pan which had about a inch of sludge in it. It was real fun to get under the splash lube pan which is part of the main pan. It's the concave raised section with the four grooves in it for the connecting rod caps. As the cap is rotated through standing oil in the groove, the oil is forced into the rod journal. Then, on the top of each rod are two holes that spray oil up into the cylinder, inside of the piston and the wrist pin. On the right is the trans output shaft that's ready with the rebuild of the splines. The welding and regrind went smooth. Interestingly, when it was set up for grinding, one of the original splines was off .015"!! Guess someone wasn't watching the milling operation! On the left is the oil pump. It's not a rotary gear that you find now but rather a piston pump that runs off a eccentric on the cam. I've got some Kroil in it to see if I free it up. I lapped the valves just to get a good indication of their condition. Regrettably, at least the intakes will need to be ground. Valves aren't that bad but all the intake seats are pitted. This thing defiantly when under sucking water through the carb. I've got a friend with a valve and seat grinder that has offered to lend it to me. I hope I can remember how to use it - been 30 years since I've ground a valve or seat!!!! This picture also is a good shot showing the #3 cylinder with the pitting and ridge left from when it had water sitting in it. Close up of intake seat - foreground: It's always funny how such a small engine can spread out and take up so much space! |
I've been out checking a few things on the engine today. First I wanted to check for cracks in the block so did some cleaning and pressure washed the bare block after getting the valves and cam out. No cracks!!
Now, not finding a crack I can move forward. I do not have a manual for this engine so the best I can do is to use clearance and torque specs from later flat heads. Plasigauging the mains both come out to .0015" which is the low end of the spec. Here's the check on the rod bearing. .002" which is on the high side of the spec. With the exception of pitting on the main journals, The crack assembly isn't in bad shape! I'll probably put it back together as is. Did some more honing on the one bad cylinder wall that was evident it had water sitting in it. I got it to the point where I feel it's acceptable without the engine going through too much oil and it is only about .002" over the other three. No out of round top or bottom. I won't know what the actual clearance is until I get the pistons cleaned up. Then I may put it back as is too. Next is to clean up the valves. Some look good and others I can tell are bad. I'll take it in for a grind job. Cam again except for some pitting doesn't look all that bad. Same for the lifters. The bearings do show scoring but I'll have to do some measuring and cross my fingers! The more I investigate this engine, the more I feel it went down! If I had been thinking ahead, I should have looked at the valve position on the water damaged cylinder when I pulled the head. |
I haven't welded up the grooves worn into the splines on the output shaft yet. Talking with the guys in the tool room, the subject of using hard face rod for the filler came up. They felt that the hard rod may flake off from any shock loading of the clutch plates. For our own info, we Rockwelled the original spline and it's soft! 35 on the C scale! So, the plan now is to weld up the grooves with stainless rod and then regrind the splines.
I dont know Paragons history but know they started out in Taunton Mass. but those plates look identical to Paragon plates
Eric,
Thanks for the phone numbers. I've written them down just in case. My plan is to recondition the shaft splines and then see how the plates fit. I don't feel blanchard grinding is needed. I cleaned up the stack last evening and held them up to the light. Couldn't see any warpage in the plates. I'll also lay them down on the granite to check as well. How far back in years does Paragon go? I know even though marine engine manufacturers would call their trans's their own, many did use the purchased paragon internals. But, who copied who?? |
they do look like Paragon internals
Ive even put those plates on a blanche grinder and skimmed a couple of thousandths off them, I believe TMI still has those plates 800-462-8848 or glpp 440-951-5111, i also flip them and remember square corners. but i think if you repair the hub and thats it, you'll get another 25 years from them....rebuilding is a loose term, clean and paint
Mark,
Thanks for the out of round warning. The hone is a best quality I got at Napa but I will be measuring as I go. When I checked to see if this engine had been bored and got the .005" to .007" over nominal, I also checked for out of round and taper top to bottom. None so as mentioned before, I don't feel this engine has much time on it. I haven't measured the actual piston diameters yet so the .005 to .007 may be misleading. I'm guessing at about a .0025" piston skirt to bore is the spec but will know the actual after I get the pistons cleaned up and measured. Keep in mind this certainly isn't what you would consider a high performance engine! 2500RPM max. red line, 4.1 to compression ratio, One spec says 20 HP but I also found another at 15! Also, I'm not worried if some of the pits are left in the one bore. This engine isn't going to be a daily runner and more show. If it burns some oil, it wouldn't bother me. They all did back then anyway! Gary, Thanks for the babbit link. That's one place I didn't find when I did the search. The others I found were out east. Boy, I sure hope I don't have to ship that block and rotating assembly someplace for babbiting. I brought my torque wrench home from work so I'll torque down some caps and see what the plastic tells me!! Oh!! A friend had a partial engine manual for the engine and it's got a paragraph on valve/cam shaft timing. Without the timing marks on the gears, here's their high tech answer: "In case it is necessary to remove the cam shaft, the cam shaft should be set so that the valve timing is such that the exhaust valve closes exactly at the upper dead center of piston on the exhaust stroke of that particular cylinder of which exhaust valve just closed." Well, that's a mouthful of a run on sentence but logical! |
Pete,Ball hones can be used in place of what you have,for reasons Lewey has said.
Also check here Egge Machine Company they do babbitting and I believe they make pistons,anyway some good reading. |
lewy2001
Be careful Pete if you go honing it too much you will get it out of round. Then you will need to bore even further.
How good is your hone some of those 3 leg hones are poor quality. |
