2001v-drive |
Page <12345 21> |
storm34 ![]() Grand Poobah ![]() ![]() Joined: November-03-2008 Location: Dexter Iowa Status: Offline Points: 4492 |
Lookin good Ryan, You work in the dark down there or what?
Here's some pics of the boat I was telling you about. I think it looks sharp. ![]() ![]() ![]() ![]() ![]() |
form&function ![]() Senior Member ![]() Joined: August-21-2009 Location: OK Status: Offline Points: 342 |
I like the pick with the factory (correct craft competition ski boat).Looks classy all white with almost stock lettering.
Chris - Those jump seats are pretty trick. In windy conditions the stern seat can be a wet ride!
TRIP ![]() Gold Member ![]() ![]() Joined: December-08-2007 Location: Costa Rica Status: Offline Points: 629 |
Prettiest colorscheme I've seen on a 2001!
Got one floor stringer built and it only took four days.I built the entire stringer twice as thick as factory and added interlocking supports.I started by beding with long strand fiber and then locked it in with one coat of woven up the sides.I then went back and put another coat of woven encasing the entire stringer.Still looks thin to me,
MI-nick ![]() Gold Member ![]() ![]() Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 809 |
what is the purpose of the strap across the top??
Cheaterpete ![]() Senior Member ![]() Joined: March-20-2006 Location: Switzerland Status: Offline Points: 117 |
nice work! can't wait to see next...
Actual boat SANTE 210 from 2014
I agree. Most here (myself included) use at least 3 layers of glass on the stringers. In the past Ive done mat/cloth/mat, and will do mat/cloth/biaxial in the future. The mat and biax really add to the build up- it ends up being ~3/16" thick. |
Since you ask... sounds a little thin to me as well. What is the weight of that cloth?. Your changing the whole loading of that boat when you move the engine I wouldnt be afraid to throw a couple extra layers of cloth at it. For the "interlocking supports" I would be less worried. I set mine in with 2inch, 4inch, and then 8 inch type, no bedding and only three layers, however on the 4 stringers I go with a minimum 2,2,4,4,8,8,full layer 10oz cloth, fully layer epoxy mat. Areas with more stress or with no floor on top got an addition layer (s) of the 10oz cloth oriented 45 degrees from the first and then a cap of epoxy matt over the top that extends up to 6 inches over the floor. It takes a lot of woven cloth to build any thickness, and I do know the factory didnt always use the best materials or techniques but you will pull off areas of glass with considerable thickness, equal to a dozen layers of woven cloth or more. Also you doubled the thickness of the side stringer in the front where the v of the boat is taking more of the load but but cut it in half in the center of the boat where it is flatest, where the old motor load was and where the main stringers were cut down to allow engine installation. I dont think it is a big deal as long as you adjust your main stringers appropriately... |
if you build a nice aluminum cradle for the engine to rest on it will disperse the load, I actually seen my first engine torque, it ripped right from the stringers on power up, it was an IO, with rot...i didnt really think it was possible....but again it was a chevy lol
I think I will go over it once more just to be safe but my main concern is the engine stringers.I have a plan for the mains that consist of several braces you can't get away with on a direct drive.I also don't know how to deal with the blank spaces between the wood seeing there will be zero foam in my boat.
Fl Inboards ![]() Grand Poobah ![]() ![]() Joined: January-20-2008 Location: United States Status: Offline Points: 2075 |
Wow! building it for big seas are ya!
Nice work! Very much overkill though on the sub stringers, going to be one hell of a solid boat!! I agree about building a motor frame, distribute the load. Keep up the good work, keep up with the pictures. I have a 84 2001 and am getting some ideas!! Blown BBC, lenco and a 12 degree Casale V-drive!! Worlds fastest Ski Nautique,, Funny stuff!! |
Here is how I did it, although I did have some foam from the front bulkhead onward, several have used plywood floors, some with foam some without. I went a little overkill with the support spacing but my boat is rock solid going down the lake and the floor has zero flex. Floor with no foam |
Looks good Ryan, I agree with the engine cradle.
Where is your bulhead going to be? I'm guessing your going to put the tank in between the stringers up in the bow. You think you'll have enough room to put another tank to use as ballast under the mains? |
There was a guy on the v drive forum that built a drag boat out of a ski boat.When he would hammer on it the boat would jump out of the water and cavitate because skiboat propshafts have steep angles.Ten plus I think. |
Your floor is almost identical to mine with the water channels.Did you notice any extra noise with the foam missing? |
Chris,my design so far has two bulkheads with fuel in the center and ballast under the bow.As far as the cradle I plan to reuse the factory one. |
Sounds about right, mine will lift the back end out of the water if you hammer it with no one in the back, don't know if its the angle that is the cause but it does happen. There is no noise as a result of removing the foam on my boat, but coosa board is a considerably better sound insulator than plywood so your mileage may vary depending on what you use for the floor. |
Chopper ![]() Gold Member ![]() ![]() Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
Hey Joe,
I didn't think your hull was any more noisy than mine (stock). Exhaust was a different story ![]() |
Half way done with the stringers.I have to say it's getting really tiresome,
That framing looks really stout!
62 wood ![]() Grand Poobah ![]() ![]() Joined: February-19-2005 Location: NW IL Status: Offline Points: 4527 |
More ambition than me...
nautiless ![]() Senior Member ![]() ![]() Joined: June-30-2008 Location: South Africa Status: Offline Points: 186 |
Eagerly watching...
Wacko ![]() Senior Member ![]() ![]() Joined: March-21-2009 Location: BC, Canada Status: Offline Points: 293 |
Looks like it is coming along nicely
Keep on keepin on till its done
Looks to me like two people glassed the floor in.The guy on the left was very careful and clean but the guy on the right was a slacker.I found huge gaps and naked wood all over the boat,I even found a drain that was draining under the stringer.Steel construction nails holding the frame together.Pretty crazy stuff.Its all gone now and a distant memory for me.
If you look very close you can see that the floor sinks towards the center a quarter inch for proper drainage.
I did that as well and am glad I did. One thing to watch is engine cover clearance. |
WakeSlayer ![]() Grand Poobah ![]() ![]() Joined: March-15-2006 Location: United States Status: Offline Points: 2138 |
He is making a v-drive, he has to make a new one anyway.
Ryan, interesting run for the wires and cables. Curious as to why you don't just run them down the middle? Easier access for replacements like steering and such. |
Mike N
1968 Mustang |
Probably gonna be some kind of tank there?
Page <12345 21> |
