why does correct craft turn props rh rotation |
Page 123> |
snowalternative ![]() Newbie ![]() Joined: September-10-2007 Location: sanford fl Status: Offline Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: July-02-2009 at 12:17am |
does anyone know the reason correct craft used rh rotation motors alot of the older boats?
are there any adverse effects in handling/turning if one converts to a lh motor other than the necessary changes-seals,trans pump,cam,dist gear,starter,prop,crank,etc? Im just curious,it seems the lh parts are much less expensive as well as more choices available. i cant find any posts on this subject & i think there are more than a few older boats w/gt-40 motors in them which would make them lh rotation unless these are simply head/induction swaps on rh motors with out the blocks & valve train being used my apologies if this is a repeat post--i have a '83 2001sn which i'd like to freshen the motor (2000hrs) & am trying to find most economical way to refresh |
If you got into this sport thinking it was gonna be cheap, get out now..............
Now if you are here to stay, there are ways to rebuild on the cheap, but do not try to re invent the wheel.Both long and short block are available at a reasonable price.These motors are purpose built, and from the hours you listed it has done it's task well. If you must use a LH motor.aka car motor,a PCM 1.23 tranny will allow the use of your RH prop.But this will add about 2000.00, when all the extras are figure in. New drive shaft , with fitted coupling mated to that new tranny will handle 500 plus HP> YOU BUILD IT AND WE WILL COME |
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
This subject has been on here before many times. One reason for the RH rotation is to offset the weight of the driver. So if you put in a LH and the torque rotates toward the driver alone, it will tilt.
Tim D
62 wood ![]() Grand Poobah ![]() ![]() Joined: February-19-2005 Location: NW IL Status: Offline Points: 4527 |
OK here comes the proverbial "can-o-worms". Using this logic, which is what I think most arguments have been for the RH, why do boats with LH controls, like my Higgins, and some of the mid 60's CC's, still use RH rotation motors? Im not trying to be a smart-azz, just always been curious? Given that,my vote would still be to keep it RH. I think most of the GT motors on here are of the "head swap" type. btw snowalt., you ride sleds? |
it was back in the day, narrower boats and bigger props would torque the boat and alot of the boats back then would be flywheel forward, the trans was mounted to the front of the engine on some, normal rotation and at the back required a right hand prop. out of many ski boat manufacturers CC is the only one....so i go with the odds
Steve, The 60's CC's like the skylark with a port side helm ran LH engines! The V6 was never made in the RH/RR. Take a look at the props on a Higgins (from the factory). They are LH! |
Luchog ![]() Grand Poobah ![]() ![]() Joined: April-17-2007 Location: Argentina Status: Offline Points: 2135 |
I agree on the older narrower hulls but after the 90's first TSC hull the RH prop is no longer needed. I have been on the same hull with LH engines and it performs just the same.
C-Bass ![]() Platinum Member ![]() ![]() Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Maybe you just mis-spoke, but it's no shock that you've been on those hulls with LH engines, as that's what the all were. The still swing a RH prop because of the reduction 1.23 tranny reverses the input rotation, so the output ends up being RH. Now if you've been on one that truly was swinging a LH prop, that's a different comparison. |
Tomski ![]() Senior Member ![]() Joined: October-19-2006 Location: United Kingdom Status: Offline Points: 227 |
I've always heard it's to counterbalance the driver, but that makes no sense - the spotter does that. These are ski boats so are very rarely going to run with only a driver. Perhaps research showed that, statistically, drivers were very very fat and spotters were very very thin.
Just as i type this it occurs to me that you can sit tweo people on the port side of my boat, and most others, but only one on the driver's side, so on that basis the engine should go the other way to "balance". A cynic might wonder if it was just a way of making a bit more cash for PCM et al! |
Easily Parted From Money
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Online Points: 3337 |
I concur.
I think after '82 it was just for legacy. and wanted to be special, and angle on the copetition. Its not uncommon for CC owners to think their boat has "cop engine, cop exhaust, cop carb, " cop rotation.. If it were that critical, CC wouldn't have put the mac-daddy LH rotation Hi-po 454 in the 2001's and BFN's. |
I can only speak to my experiences as a fat guy with an 83 which I will in fact ride in by myself and from time to time use to pull a skier/boarder alone and has had both a lh and a rh hand prop on on said 83 SN, it makes a noticable difference. Not particularily at slalom speeds, but for boarding I used to put an extra 440lbs on the passenger side when I had a LH engine to keep the wakes both with a hitable peak don't really need to do that with the RH prop. Its not like the single spotter will push you too far to the LH side now as they can easily sit in the middle if need be. Now could CC have done the same thing with a little hook, shimmy, or other no doubt.
Is the later hull different than the 83 in that there is absolutely no difference in performance between lh and rh rotation and luchog states, I doubt that too but I have no evidence to prove it. We do know that CC specifically stated in the literature for the later model boat that the rotation was to counteract the weight of the driver whom would often be the only one in the boat. Was my 83 with a LH engine unusable.. .heck no it did the trick and did it very well in particular at speeds over 25mph, biggest issue would be resale value. As for the big 425hp std rotation engine boats, with my experiences with LH and RH in the same boat if I was choosing between a 330 hp rh and a 425 hp lh it wouldn't take me long to index the pump and change the prop. |
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5313 |
I disagree with this statement totally Tom. I often run my 88 with just me driving pulling a buddy or vice versa. I have 2 88 lb lead weights that I place on the floor where a spotter would normally sit to evenly weigh the boat. I also have a another bud who uses 2 fat sac cubes filled and places them in the seat where the spotter would sit for the same reason. |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Has anyone ever asked Mr. Ralph?
where's the picture of 79 when you need it?
Riley, he will tell you he got a great deal on a hundred righties in the day lol |
Eric, I think that's more like it!
[QUOTE=eric lavine] where's the picture of 79 when you need it?
I have seen that picture. LOL !!!!!!!! ![]() Donald |
C-Bass, Ive been on the 90plus hulls with LH engines and 1:1 gears and propeller rotation makes no difference.
Thanks for the answers,facts & opinions. According to what i'm reading
if one did want or need to switch for whatever reason to lh from rh & had the needed components to do it,motor,raw pump,alt etc.,the pump can simply be reindexed (w/out switching gearboxes & shafts) & prop. Since the 2001 came w/lh bbc it must not matter too much which way the prop turns thx for the answers to my questions hey 62 wood-no sleds-i live in sanford florida just north of orlando & the only snow ive got here is melted & flowing north on the st johns;although i do frequent big cottonwood canyon in ut & rent several polaris rmk's to take up to the backcountry near brighton--thats where the name came from because there snowalternative (actually off a previous boat) |
Pete, My 62 Higgins has a RH prop, driven by a flywheel aft, "bacerds runnin", 135 Graymarine. I have no reason to beleive that it was ever anything but that. You got my curriosity going tho...I might have to check on a few of the other Higgins I know of. |
Donald, i think thats the most he ever got PO'd at me, I remember the post, it read "now I know why they need right hand props"
Where has 79 gone? The level of vitriol and spleen venting has dropped dramatically on here!
i think he is on "time out"
86BFN ![]() Gold Member ![]() ![]() Joined: July-28-2008 Location: Indiana Status: Offline Points: 882 |
Might of blew a gasket or had to have a valve job.
even though he hates me, i still miss him, he is one of those "to know him is to love him"
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5775 |
I started wondering the same thing a few weeks ago, not sure if I missed something and he got kicked off or if he was just busy at work so I checked his profile and he seems to log on just about everyday just isn't saying much...sort of like a big cat hiding in the grass. last log on was yesterday at 12:11 looking at the float adjustment thread so he's either trying to prove a point or he got his hand slapped. Either way 79 if we're wondering whats up that can't be all bad. |
he might be on the same island as MJ, maybe his assisstant?
Perhaps he helps it with a custome but I think 79's too grown up for MJ's taste. Also there's this other topic "ignition" I think it is, where a ***************ball is rolling downhill. |
kapla ![]() Grand Poobah ![]() ![]() Joined: March-27-2008 Location: BA, Argentina Status: Offline Points: 6148 |
yeap that ingnition post Is lacking of 79´s comments!!!LOL |
Eric, here's a pic of 79, perfect for this topic.
Tim D
adamt ![]() Gold Member ![]() ![]() Joined: July-18-2007 Location: Orlando, FL Status: Offline Points: 927 |
Speaking of the St. John's, what ever engine you decide on make sure you got all the kinks worked out by Feb 2010!!! We'll be expecting to see you at the reunion, if you live in FL there's no reason not to be there. |
-Adam
1973 Skier |
Page 123> |
