freeze plugs pushed out |
Post Reply | Page 12> |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Posted: April-23-2015 at 12:55pm |
I dug my boat out of hibernation this morning and discovered that two freeze plugs on the starboard side were pushed out at some point during the off season. The manifolds and block were drained in the fall prior to the cold stuff. No antifreeze was added at that time as we normally don't need to do that in SC.
No attempt has been made to turn the boat over. What's the recommended course of action at this point? How do you reinstall the freeze plugs? I want to believe that the block didn't crack, but I suppose the only way of knowing is to get the freeze plugs back in and crank it up correct? Oil is clean at this time, but I'd guess that water would only show up after an attempt to crank and only if the block were compromised, yes? Suggestions? |
Steve
2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer Former CC owner (77, 80, 95, 88, all SNs) Former Malibu owner (07, 09) |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
Damn. Probe the drain holes and see if they were plugged up and failed to drain properly. The casting plugs can be hammered back in. I probably do that then run it and cross my fingers.
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6149 |
I betttttt it will be fine. We had a 94 sport that came in this winter after being frozen outside for literally months. It didn't even push all the plugs out somehow. When we pulled the block plugs there was literally ice cubes sticking out of the holes. The only thing that cracked were the manifolds and the bottom of the thermostat (manifold side) housing. Manifolds and a new intake and we were in business.
I have pushed me drivers read plug out a few times behind the starter with no issues. |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
We had that happen once with our 351 and there was no damage. The only thing I can think of is that because of the angle of the engine, not all the water drains out. I now add about a half gallon of anti freeze and pull the plugs to purge any remaining water out, after the block has been drained. We lost the freeze plug by the starter.
phatsat67
I nose mine all the way down on my parents inclined driveway with a floor jack. Plug has never popped since.
Swatkinz
thanks for the encouraging words.
One of the plugs is the one just over the starter, the other is the one just to the front of that. When you say push them in, do you mean manually? If not, how do you install? The one in the front, will be the most difficult to get at b/c of the motor mount. Should any type of sealant be applied around them? When I do get them in, I'll hook the hose up and give it a try. Is there any reason to be cautious at that point with cranking? If the block is cracked then it's cracked or would I not want to be quick to crank to save internals for a rebuild? |
Steve
phatsat67
Use some high temp copper seal. Works well with the rust that happens around there. Get a big socket the same size as the ID of the plug and a small hammer to tap it back in,
If you are feeling real froggy go to the auto parts store and get some new brass ones. |
Riley
We got a new brass one and tapped it in with a socket attached to an extension. We had to drop the starter to get at it.
Yeah, what Bruce and Zach said. I'd clean up the casting hole with emery cloth if it's rusty. No sealant unless the fit is loose... It should take a bit of force to go in, it's just a press fit.
KennyStar
Newbie Joined: September-15-2014 Location: mn Status: Offline Points: 8 |
sometime you can find plumber plugs , that fit the hole for testing. they have T handel to tight them., if there is a chance of water coming back up basement drains during flooding. you can buy kits with different sizes. ive used them on 283 chevy engines.. had two cracked blocks, in a 1963 chris craft roamer
kenny
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 832 |
for marine engines when i install freeze plugs i always put a light coat of permatex aviation form-a-gasket on them and hammer them in. its expensive stuff but greta to have around. i also use it on all of the manifold plugs when i replace them and any raw water elbos or nipples. its flexible but holds strong.
keep in mind you cannot just hammer in your old freeze pugs, buy new ones. they are cheap. I would do as everyone says. just put new ones back in and run it and hope everythings ok. they are there as a sort of fuse-able link that is made to fail before the casting does. but thats not always the case. so remember the fingers crossed part. |
1988 Barefoot nautique-454
74Wind
My 74 351 also had popped one maybe 5 years ago. Replaced and no trouble since.
1974 Southwind 18
1975 Century Mark II |
cboland
Senior Member Joined: July-15-2004 Location: Atlanta, GA Status: Offline Points: 185 |
This happened to me a few years ago. The engine was fine. I went to auto parts store and just bought the metal/ rubber replacement with the bolt in the center. Turn the bolt which compresses the rubber and forms a good seal. It's a lot easier than trying to hammer the original plug back in given the close quarters.
Bud
1999 Sport Nautique |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3620 |
The bolt in plugs are a very easy install but keep in mind they will eliminate the freeze plug function. Once bolted in they will stay in. I don't think they will push out like a real freeze plug does when the block freezes. The freeze plug may have saved your engine this year, Put one back in for future freezes.
gun-driver
Grand Poobah Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4117 |
After this last winters deep freeze and as far south it got I believe we will be seeing a lot of frozen blocks.
As I don't wish this bad luck on anyone I am sitting here grinning like a butchers dog waiting for the right boat to show up for sale with a cracked block as I happen to have an extra motor sitting in the garage |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Steve,
Do not reuse the original plugs - buy new and install as suggested above. I have always used a wood dowel or cut broom handle and hammer to drive in. Good luck |
'88 BFN |
Steve,
I suggest getting a couple new core plugs. They aren't expensive even in brass. New ones haven't been compressed so they will fit tighter. I don't suggest plumbers test plugs. They aren't designed for hotter engine temps. The rubber with the toggle that holds them in are better but should be only used for an emergency. Brass is permanent and rubber isn't!! It been mentioned that they also eliminate freeze protection. Well, keep in mind those plugs on the engine block are NOT "freeze" plugs and were NEVER intended to provide any freeze protection. They are there to plug the holes left over from the casting process used to hold the core to form the water cavity. |
MrMcD
The fact that Freeze plugs are pushed out when the block does freeze shows these plugs do offer some freeze protection, not perfect but better than nothing, regardless of why the manufacturer installed them in the sand castings when the block was cast.
It is still far better to winterize the engine rather than hope the freeze plugs save you when the cold comes. Many boat blocks have cracked in freeze conditions and the plugs did not save them but they do work sometimes Maybe it depends on how cold they actually get or how fast they get cold when the freeze does hit. |
lewy2001
We call them "Welch" plugs downunder
74Wind
Pete: that's funny, I was wondering yesterday when you'd pipe in with your regular " not really freeze plugs" reply
1974 Southwind 18
Funny Mark on how English is different all over the world. When I had a Triumph motorcycle the manual said to rinse an oil screen in paraffin,I remember thinking, won't that clog it up? I'll just use gas instead!
davidg
Grand Poobah Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
I had this happen a few years ago on my '76 Southwind. I fired it up in the driveway for the first time during the year without realizing one of the plugs had popped out during the winter. I just hammered it back in, and fired the engine up. No damage. I have to wonder if thermal expansion/contraction plays a role in this happening vs. water pushing it out!?!
lewy2001
Don't you mean Petrol |
Swatkinz
Thanks for the input fellas. This one is going to require more time, tools, knowledge and experience than I can allot to it so I'm going to let a professional handle it. One of the freeze plugs that popped out is right above the motor mount and I just can't get to it w/o removing that mount.
I suppose it''ll be a good time to have a few smaller things addressed while it's in for that. Many thanks for the assistance though. I'll report back, hopefully with good news, about the outcome. |
Steve
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
Sounds like I am on deck for this repair. |
NCH20SKIER
Steve
Any progress on the repair? |
'88 BFN |
Swatkinz
I was able to replace these with new brass plugs, seal with copper sealant and run it today. Ran it hard. No evidence of milky oil or anything else that might be amiss. Greatly appreciate all of the comments.
Steve
phatsat67
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6111 |
Got it fixed up just in time to sell? Sounds like a CCF intervention is needed. That one's a beauty.
