  New Posts New Posts RSS Feed - eBay finds
eBay finds
 Post Reply Post Reply Page    <1 3536373839>
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2009 at 2:40pm
Originally posted by Andy Andy wrote:
Ever had your arms pulled out of socket before getting out of the water?
blown BBC
That's a monster!
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2009 at 2:38pm
Andy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2009 at 3:50am
blown BBC
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2009 at 5:51pm
I was looking for some windshied brackets and ran across these. Not exact but close!
wing windows w/brackets
Edit: On second look, I think they are the same ones CC used!!!
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2009 at 9:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2009 at 11:17am
yea it's what I had on mine, all you have to do is drive out the roll pin with a punch and swap gears and install and set timing, Eddie, Keith or Mark should be able to hook you up on the swap.
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2009 at 2:14am
Thanks Chris...I was just wondering if this thing was something I needed.
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2009 at 12:32pm
Originally posted by SNobsessed SNobsessed wrote:
Might be a good deal for someone:
Mallory Distr.
if you have a standard rotation engine that is or want to swap gears on it to mkae it work on a reverse rotation engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2009 at 10:25pm
Mallory Distr.
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2009 at 2:00am
Originally posted by Terp Terp wrote:
Pete, here's one for you.
'56 Atom
I emailed the seller asking about the bottom. We'll see what he has to say!!!
Pete, this guy ever get back to you? Just curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2009 at 3:45pm
Looks like this might be a good buy if the bidding traffic is light:
'82
It sits high in the water so maybe the foam isn't fully soaked!
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2009 at 2:30am
My thoughts exactly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2009 at 9:26pm
This guy got carried away. $22K invested in an '81. Might be hard to recoup in this market.
'81 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2009 at 12:41am
8.7 hours on a 6 year old boat!
This guy could use punctuation check on his ad.
2003
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2009 at 6:25pm
'56 Atom
The biggest problem with this Atom is the bottom has been fiberglassed. You can already see that screws are pushing out on the glass (in the picture of the transom) from the wood being soaked with water. This is a ply boat and the wood should not be wet!! The hull being glassed tells me there's a much deeper problem. Most likely the ply letting loose from the frames and probably rot in the transom frame - a common area. Glassing is a "quick and dirty" coverup!!
Yes, the interior has been upholstered non original which is reversible. At least the paint scheme on the hull looks close although I would question the bronze bottom paint.
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2009 at 1:47pm
'56 Atom
h20loo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote h20loo Quote  Post ReplyReply Direct Link To This Post Posted: January-18-2009 at 12:38pm
Interesting trailer on this one.
'63 Skier
That's a nice clean looking boat and those twin carbs always look so "hotrod".
Someone must have worked in a mufflershop tho!!
70 Mustang project
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: January-18-2009 at 11:34am
'63 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2009 at 1:10pm
That is definitely a Barefoot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2009 at 10:49am
Does this look like an '83 BF? The hood scoop & hand rail look like a Martinique to me.
Just wondering.
83 BF on Ebay
75 stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 stang Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2009 at 10:09am
'08
Take your work seriously, not yourself.
Boat Pics
farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2009 at 8:35pm
Sean,what year is the GT500?
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 stang Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2009 at 10:32am
Careful Eric... although your kinda right, my wife drives a 90 mustang GT convertable and my mom drives a GT500 convertable....
Boat Pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2009 at 9:59am
Steve, they have to bring that Camaro out, lottsa r and d, it may be 2010
they need to compete with the challenger and the ford changeover (mustang) they changed that over to a womans car. dont believe me look who drives them
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2009 at 3:04am
$51 doesnt seem like much of a donation!
That'd be a nice motor in my skier!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 stang Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2009 at 11:20am
Fort Wayne Indiana Cuda
did'nt someone need a 318? $51... so far
Boat Pics
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2009 at 4:19pm
Originally posted by eric lavine eric lavine wrote:
wait till the 2009 Camaro comes out. no more rice diets...I think and hope that will give GM a boost.....Ive been watching and they are changing the way they are doing business and are starting to market to attract new buyers
Eric do you think that will ever happen. every year I here it will be out next year. LOL
I've got a 93 Z28 Pace Car with 4k on it if you know any interested.
👣 Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2009 at 1:45pm
Ok, I guess that's a common upgrade
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2009 at 1:19pm
Saw this on Ebay - I wonder why the electrical tape on the hour meter. What could it be covering up or why is it there?
Looks like velcro to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2009 at 12:15pm
Is this too good to be true? Buy it now for $9K. Looks like it has closed cooling.
99 SN
