ELECTRIC CHOKES! Holley Carb model 4160, electric |
82wake2001
Senior Member Joined: February-14-2008 Location: United States Status: Offline Points: 240 |
Posted: May-21-2011 at 12:59am |
After messing with the SN tonight i noticed the choke plate was not moving. When the boat starts keep in mind it was shooting to 2300 and them stalling.
Well held the butterflies shut with my hand and bammmmm it idles at 800. Two questions: 1. what should the two screws at each side of the carb be set at. someone said screw them all the way in then back them out a turn? 2. I looked on SKi Dim for my Holley Carb model 4160, electric choke replacement. I then looked at Summit Auto (which is about 15 minutes from my house) and found the same part. Can these be interchangeable. What are your guys thoughts??? Thanks Joe |
Joe
1982 ski nautique 2001 "Lady of the Wake" |
Luchog
I have the choke disconnected on mine, so it's always fully opened and it idles at 750rpms.
Having said so, I dont think the choke is your problem, have you messed with the carb or distributor lately? did you check base timing? are the secondaries fully closed at idle? how's the ralenti screw set? too many turns in maybe? Any other engine work when the issue started? edit: oh, just remembered your other thread, it seems your reluctant to follow advise, as you got pretty good responses over there and you never bothered responding my questions on your issue. So it's really up to you if you want to keep chasing your tail looking at what's not allowing you to enjoy the boating experience or listen to the more experienced guys here. I dont need to remember it's you having a boat issue, we just want to help you, do you want to be helped? |
lewy2001
Closing the choke plate indicates to me that you have a vacuum leak somewhere. I think Eric mentioned that in your original post(edit sorry it was Joe). Intake to heads or carby to intake are the most common places. Have a good look around spraying a bit of WD40 can help isolate the problem area.
82wake2001
Luchog: I have taken advise and I am extremely pleased with the feedback.I just took a glance at the previous post and I apologize I missed your comment.
-Rebuild was done by eric at FFM. -No back fire. -The issue started when the heads cracked. -installed GTP40 heads (Eric recommended checking for leak around intake. This is where my issue is I have no clue how to do this or where to start or look.) Eric was awesome had a ton of good information and if I had the money I would take it back. Great shop, quick and nice. I have changed the timing chain, changed the cap and rotor(checked the springs on the breaker less, and greased them), check anti siphon, and replaced fuel filter. I have done almost everything that has been advised to me. I am also going to check for vacuum leaks ( I have head carb cleaner or soapy water) tonight and someone said PVC valve. |
Joe
LaurelLakeSkier
Senior Member Joined: February-12-2007 Location: Wisconsin Status: Offline Points: 485 |
Carb cleaner OK.....Soapy water NO!!!! |
The world is full of youth—what we need is a fountain of smart!
Luchog
Joe, did Eric install the heads and intake? If not, first thing to do is checking for vacuum leaks. was it straight dropped over? did you follow the torque sequence?
Another place for vacuum leaks could be at the carb base, or the adaptor plate base. spray carb cleaner or WD40 over there too. Also check the secondaries are fully closed. |
82wake2001
Ok. I just got home and a few things have developed. First the screws on either side were turned out about 5 full turns. Second changed the pcv valve and noticed that line was really loose cut off the stretched out part.
So I got it to idle the boat to idle at 900. Squished some carb cleaner and found a massive leak on the starboard side of the carb. It has two new gaskets but looks like the leak is from the section of the base plate that meets the exhaust manifold. Now the questions. First with the leak. There is a new gasket present how do I seal the leak. Second the mixture screws on either side of the carb. Scew all the way in and back out one turn ok? I found zero leaks around the exhaust manifold FYI Thanks for the help guys. I think we are getting closer! |
Joe
Luchog
neither the PCV or the carb screws are the issue here.
The leak you found is. The carb plate doesnt meet the exhaust manifold, it's the INTAKE manifold. The exhaust manifolds are the 2 piramid like hanging on the sides of the engine. is the carb properly adjusted on the intake? there should be no leaks unless a surface is not straight or a gasket is bad. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5775 |
What intake manifold do you have on this motor? Aftermarket or stock?
82wake2001
I have the stock intake. You guys could be awesome and tell me to get an edilbrok performer intake :).
Do the spacers ever go bad at the base of the carb? |
Joe
eric lavine
how was the chain when you pulled it? no luch on installing the heads, i can faintly remember an issue with the intake and i felt with the hours we may have been chasing our tails because i vacuum gauged it and it was fluttering with low vacuum.
anytime i see a flutter in the gauge its hard to move onto the next step and you have to take care of the mechanical issues first....he is heading in the right direction |
82wake2001
Chain was ok. Little slack no broken teeth. I did put a double roller in :). Timing is now advanced to 10. I have a friend that has a vacuum gauge coming out Wednesday.
We are going to pull the carb off and reset it. any tips on sealing it so this does not happen again ? Maybe a thicker gasket (if they even make them) or double up. Any sealer I could add to the gasket? |
Joe
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3336 |
Double gaskets typically result in warped throttle plate. Just get a single nice thick Felpro
River Rat to Mole |
horkn
To be honest the stock intake seals better than even an adapter plate on an edelbrock with the holley. The performer is a great intake for a ski boat, but putting a squarebore on a spreadbore intake adds another possible vacuum leak. I could not get the stock pcv slaveries to seal properly, despite every combo you could try so I am running no spacer. |
charger496
Senior Member Joined: August-06-2010 Location: atlanta, ga Status: Offline Points: 157 |
Tom, with the Edelbrock and no spacer, do you feel you got any performance gain over stock with spacer? I'd like an Edelbrock as much for the better breathing as for the weight savings.
